Question about Panasonic DMR-E55 DVD Recorder
The problem is it says non recordable disc cant read those are the Panasonic discs that came with it how much is a new laser if i need one
  • Panasonic Master
  • 508 Answers
I love these sorts of problems. The typical estimated cost to replace the laser (which may also contain the spindle motor in the same block - as one part) and labour including alignment, firmware, etc. is around $200 - $300 approximately at an authorised Panasonic service centre. You would need to take the unit to a repair centre for a quote on the relevant repairs/parts etc., involved. This way you can make a decision as to whether or not to go further.
However, if the discs you got with the recorder are meant to be recordable, and it can't record them, chances are the laser could just be dirty (factory dust if you bought it new or general dust if you got it secondhand) or it may need refocusing/aligning, or the discs are defective.
These are good units, but keep in mind the DMR-E55 is a 2004 model and does not feature a built in HDD or digital tuner - it is not unfixable though. The other thing you can do which is cheaper, as well as using a DVD lens cleaner disc, is to use a different brand of blank DVD-R/RWs - it might not like the discs you got with it. Have you tried different discs? have you tried to play a shop-bought DVD movie in it? if so, does it read the disc?
Try the lens cleaner disc and different blank DVDs first. If neither fixes the issue, consider the above option - take it to a workshop for analysis/quote.
Posted on Mar 18, 2011
When I load a disk I get 'Read', then 'No disk'. I have tried several commercial disks, and have tried with each side up. I have looked into the disk slot and cannot see anything which might have been...
If u can't play many of the DVD discs from Hollywood movies,Useally the disc itself the problems or the DVD recorder laser eye it bad.Tries websites like Amazon.com,Ebay.com buy a DVD cleaning kit.Put the disc in follow the directions,clean the laser eye data reader.50/50 chances will solved the disc not reading problems.If not the Laser eye is problems the unit not worth fixing buy a new one.DVD players are not woth the fixing of the Tech. prices.
Dec 15, 2010 | Panasonic DMR-E30 DVD Recorder
My LiteOn LVW-1101 Erasing DVD's Hi, Hope you can help me with this problem as Im not techically minded? I own a LiteOn LVW-1105HC and after recording DVD's(even DVDR's) I put the disc back in to...
Your lite on has lost its mind and needs replacement.
Meanwhile a non rewritable disk cannot be erased. If not finalized it may not be read on another machine but the originating machine can read it.
May 08, 2017 | Lite On LVW-5115GHC+ DVD Recorder
Since it went into "disk recovery mode" it now will not play dvds
Got the same problem. Happened 2 months after guarantee expired. **** machine. The only good thing is the harddrive and that is made by HITACHI not Panasonic! I go Sony next time. Panasonic quoted £200 plus to fix the problem. I only paid £220 when I bought it new.
Sep 13, 2009 | Panasonic DMR-EH65 DVD Recorder/HDD...
Will my non finalzied discs play on a panasonic ez 28 or ex 768
You will have no problem playing your non finalized discs on any of the Panasonic DMR range including the DMR EZ28 series. The DMR E55 can also easily be repaired if you can use a soldering iron and a little care. Please checkout my other postings for full repair details.
Cheers...
Oct 08, 2008 | Panasonic DMR-E55 DVD Recorder
PANASONIC DMR-ES35V CANNOT READ ANY NEW RECORDABLE DISCS- HAVE RESET MACHINE - TRIED TO DOWNLOAD FIRMWARE- WOULDNOT READ- PUT IN OLD AND NEW DISCS AND WILL NOT PLAY- DOES NOT RECOGNIZE NEW OR OLD DISCS.
i thing its a laserunit you need open that dvd and try cleen laser,but very very easy,its a little pot on back laserunit its can be set to,but if that not help,find laserunit number and try find new on internet :o(
Aug 14, 2008 | Panasonic Televison & Video
Panasonic DMR-E55 DVD Recorder won't read most dvd-r brands
Hello jancinn,
This might be due to a dirty pickup or scan laser head, or the optics as a whole might be going bad (both are common problems). A qualified TV repair person should be able to determine if the scan laser or pickup head are bad by doing a laser power test. If the optical devices are dirty it is just a simple matter of cleaning them with a DVD cleaning disk, however if the optics are bad, then replacing them is actually cost inefficient, and you may want to think about getting a new DVD player/recorder.
I hope this helps,
Thank you,
Shuttle83
Jun 02, 2008 | Panasonic DMR-E55 DVD Recorder
I have the panasonic DVR-255. after about 20 months of recording on DVD-R discs it reads some un-finalized discs as unreadable, won't finalized some discs that have just been recorded (displays...
With use, the laser tends to weaken. It is possible that it has reached the end of its lifespan. It is also possible that with use, the tracking alignment has drifted off specs.
You can call Panasonic to find out where their service rep is located for you to have a quotation for repair. If it is only tracking alignment that needs to be re-set up, the repair cost would be an hour or two for the work done. If the laser is defective, then the repair will be fairly expensive.
Jerry G.
May 26, 2008 | Panasonic Televison & Video
On my DMR-ES35 Panasonic after perfect operation for 18 months, I'm getting a NO READ message, on disks already recorded on this unit,and several new disks of different makes. The main sympton now is
Same problem. "NoREAD" after about 15 months of moderate usage. Cleaned laser eye thoroughly. Solution is a class action lawsuit against Panasonic.
Jan 21, 2008 | Panasonic DMR-ES35VS
Won't read DVDs
Hi, Ive just repaired several liteon's ( incidently they are identical inside to some philips models ). In most cases the non writing or non reading problem is caused by dust on the laser glass. You have to open the unit then remove the dvd drive then remove its covers and just give a wipe of the laser with a clean non fluffy cloth. If theres lots of dust in other parts of the drive then this will need to be removed also as it could easily get onto the laser when in use. Even almost new liteons can suffer the problem , it only needs a little bit of dust to top the laser shining onto the dvd , instead the dust just reflects the light back. Hope this helps.
Oct 27, 2007 | Lite On LVW-5115GHC+ DVD Recorder
Panasonic DMR-E55 DVD Recorder Logo
176 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
