Question about Maytag Electronic Portable Air Conditioner Heat
I have a portable M6o9P09D2B. ive had it for about two years. I runit constantly its a great unit. 3months ago its just stopped working it will blow cool for about a minute and then itbreaks down grinds and rumbles and out comes hott air. i truoble shot the problem. i icleaned the coils. i discovered the OUT blower is not functioning.I see a capaciter attached to this blower. could it have gone bad? the motor spins like a champ. if it were siezed itd be hard to move right? if it had stripped id hear it spining in place right? ican see the blower has lost a side. i removed it. how ever the blower on the bottom the one that blows the HOTT air out is not doing its job. helpme !
    Problem Solver:
  • 8 Answers
The capacitor may possibly be the problem. If you have a capacitor checker you can check it that way. If not, a capacitor is a low cost item and just cheaper to get a good capacitor and see if that solves the problem.
Posted on Mar 18, 2011
SPT WA-1220H Portable Air Conditioner stopped blowing COOL air?
sounds like the compressor has died and is tripping its overload protection. Give it a good funeral, and next time, buy a brand name model.
Oct 06, 2014 | Kenmore Ac Airconditioner Remote Control...
My tv has stopped working
If the TV is in warranty period, why do you bother too much? Contact the dealer to get it repaired for free.
Sep 13, 2012 | Televison & Video
My 2001 chevy cavalier was serviced last year for over heating and the a/c unit not blowing cool air. It has a new radiator but the fan has stopped turning and the a/c blows hot only. Ive tried re-charging...
might just be a bad engine coolant temp sensor , it tells car computer engine temperature and computer controls fans , as for recharging a/c , did you pull system under vacuum ? to check for leaks ? vacuum also helps remove air to get a better charge because air expands
Jun 27, 2010 | Cars & Trucks
HAIER 1 YR. OLD A/C UNIT BLOWS ONLY WARM AIR
well it sounds like the compressor is not turning on. does it have thermostat? if so turn it way down. clean any filters. is it a window unite or portable most of them are too costly to repair unless you do it your self.
Jul 06, 2009 | Heating & Cooling
Portable Air Conditioning unit no longer blows out cold air
Bit late I know, but for others having same issue, ensure that it doesn't need draining - use black tube at bottom left when viewed from behind to drain any excess water.
Jul 01, 2009 | Heating & Cooling
Schwinn S400 no power
The batteries are dead. The battery in these scooter need to be kept charged or if not in use for a long time charged every 3months. Otherwise, like what to you, they will go dead. The chemicals in the battery have deteriorated to the point where it won't hold a charge. Replacement batteies are probably available at:
http://www.electricscooterparts.com/schwinnscooterparts.html
Jun 17, 2009 | Transport Schwinn Rechargeable Portable ...
Heat worked fine all winter. Turned on A/C and blew a fuse. Replaced 3amp fuse and worked for a few minutes and blew another fuse. Checked all connections, filter, obstructions, need help...
If your blowing fuses then you have something grounded or shorted. By grounded I mean a wire has come loose and is touching the cabinet or a part that allows it to go to ground or your motor, capcitor or compressor is shorted.
Apr 25, 2009 | Heating & Cooling
NO HEAT
Les, it sounds like your blend door actuator has failed, it is a small vacuum operated diaphram up under the dash that controls a flapper that switches between the cool air and heated air. Good news is that it is an inexpensive part, bad news is pulling the dash out to get to it.
Oct 02, 2008 | 2001 GMC Jimmy
DeLonghi portable airconditioner leaking water
nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
Aug 26, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Maytag Electronic Portable Air Conditioner Heat Logo
Top Maytag Heating & Cooling Experts
Rick Johnson
Rick Johnson
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
