Question about Canon Elura 60 Mini DV Digital Camcorder
CONDENSATION DETECTED - Canon Elura 60 Mini DV Digital Camcorder
    Sergeant:
    Champion:
  • 269 Answers
It's because the camera has been taken from a heated room to a cold external.
This is normal and is to protect the camera and tape.
You have to wait until the camera acclimatizes, about an hour or so.
Posted on Mar 18, 2011
I have a JVC recorder that shows an error message of condensation being detected. How do i get rid of the condensation?
i'll give you a tip. place the camcorder in a large box of uncooked rice for a day or two. the rice will take all the condensation from your camcorder.
Apr 15, 2013 | Video Cameras
HI, When turn on BetacamSP PVW-2800P, i get message: "Error10". How can i fix it, help me, please! Thanks
  • An Error Code 10 indicates that condensation is detected. There is a condensation sensor in there and it's detecting to much condensation. Take it to a dryer room and put a fan on it for a bit to get the condensation out of it. When it dries up the Error Code 10 should go away.
Regards, Tony
May 28, 2011 | Sony PVW-2800 VCR
Condensation operation paused how do I fix this?
If the camera is working correctly it's to protect the camera and tape.
The camera has detected condensation inside it's body due to a large change in temperature. eg. when you take the camera form a heated room to an external environment that is very cold.
You simply wait until the camera acclimatizes.
Al
Feb 13, 2011 | JVC Cybercam GR-D70 Mini DV Digital...
I push the tape in as to load it and it immediately pops back out.
Your camera is experiencing condensation - your LCD should have a flashing image of a red droplet (this is a condensation warning). REMOVE THE CASSETTE to avoid damaging it.
Another cassette CANNOT and SHOULD NOT be loaded when condensation is detected.
Leave the cassette compartment open - its takes an hour until the water droplets evaporte. After the condensation warning stops flashing, wait for 1 more hour before resuming use.
Jun 22, 2010 | Canon XL2 Mini DV Digital Camcorder
Flashing drop sign, will not load a tape
Condensation has detected by your camera, leave it on for few hours until moisture dries gone. Hope this helps
Mar 08, 2010 | Sony Handycam DCR-PC101E Mini DV Digital...
Message in my camcorder says condensation detected how do i clear screen
yes. dew sensor problem. open all doors and panels. get hair dryer and blow in and around the unit for 5 minutes with batteries taken out of unit
Nov 15, 2009 | Canon ZR20 Mini DV Digital Camcorder
Dew detected
This may sound stupid, but it worked for me.
Turn your camera on. When you get the dew detected warning, take your battery off and just hit the spot where your battery was a few times with your palm, not too hard, but not really soft. Put the battery back on and it should be fixed unless you actually do have a dew problem!
If that doesn't work, try drying it out with a hair dryer.
Dec 28, 2007 | Panasonic PV-L680 VHS-C Analog Camcorder
Condensation
Just switch it on and leave it like that for about one hour.. it will clear by itself..
Dec 08, 2007 | Canon MV800i Mini DV Digital Camcorder
Remove tape error message
  1. Condensation is detected – If condensation is detected by the camcorder, the “Remove the Cassette” warning may occur.
  2. Component failure – If an electrical or mechanical component in the camcorder fails, the safety mode may activate to prevent any further damage to the camcorder.
  3. Sand or grit damage – The camcorder’s tape drive mechanism consists of many tiny gears. Sand or grit can cause a gear to jam and stop turning. This will cause the camcorder's safety mode to activate.
  4. Impact damage – If a camcorder is accidentally dropped or bumped against a hard surface, it is possible that a misalignment of the tape drive mechanism may occur.
  5. Liquid damage – If either the camcorder or the tape is exposed to water or any other liquid, a variety of malfunctions may result. Please avoid this situation.
  6. Improper videotape insertion – If a tape is forced into the cassette compartment, or if the cassette compartment is pressed down while the tape is loading, damage may occur to the tape drive mechanism. Please refer to the User's Manual.
  7. Damaged or defective tape – If a tape becomes damaged, please discontinue its use.
Operational Recovery Steps
Depending on the conditions that caused this message to appear, it is possible that the camcorder operation may recover. Please follow these steps:
  1. Eject the videotape
    Insert a new or known good videotape. If the message does not persist, it is possible that the tape was damaged. If the camcorder still displays the message with a new tape, please proceed to step 2.
  2. If condensation had been detected causing the Remove the Cassette warning, remove the cassette, and allow at least one hour for the moisture to dry.
Nov 19, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Condensation
When pouring a chilled beverage into a glass, water droplets may form on the surface of the glass. This happens because the air around the glass is rapidly cooled down, and moisture in the air adheres to the surface of the glass. This phenomenon is called condensation. This kind of condensation may also occur with camcorders. If you continue to use the camcorder with condensation on it, it could damage the camcorder. Condensation may form on the camcorder in the following cases: (1) When being moved from a cold place to a warm place (2) When being used in a rapidly-heated cold room (3) When being used in a humid room (4) When being moved from an air-conditioned room to a warm, humid place When condensation occurs: The camcorder stops operating automatically after its power lamp flashes. The warning message "CONDENSATION HAS BEEN DETECTED" appears and the condensation-warning icon below starts flashing. Condensation-warning icon If a cassette is loaded, the warning message "CONDENSATION HAS BEEN DETECTED" and "REMOVE THE CASSETTE" appear and the cassette-warning icon starts flashing. Cassette-warning icon If a cassette is loaded in the camcorder, remove the cassette immediately and leave the cassette compartment open. If condensation is detected, the POWER switch and cassette-removing switch will be activated. Leaving the cassette in the camcorder may damage the tape. A cassette should not be loaded into the camcorder when condensation is detected. How to avoid condensation Unload the cassette and place the camcorder in an airtight plastic bag when moving to locations where temperatures vary. Allow time for the camcorder to adjust to temperature changes slowly before removing it from the bag. Resuming use Allow at least one hour before resuming use; more time may be required for heavier condensation. When condensation has been eliminated, turn the camcorder on. After the condensation-warning icon stops flashing, wait one hour before resuming use.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Canon Elura 60 Mini DV Digital Camcorder Logo
128 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
