Question about Acer Aspire 4520-5582 Notebook
I have Acer Aspire Model No. 4530. The hard disc has become corrupted and have to be replaced. Can I install 320 GB of higher Hard disc. What is the maximum capacity of hard disc can I install and the motherboard should support?
  • 326 Answers
It states within the Acer user manual located on their website that your computer supports up to a 320gb hard drive.
http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire4530/Aspire4530sp2.shtml
The user guide is available here for future reference.
If this information was helpful, please feel free to rate and comment on it.
Posted on Mar 18, 2011
  • 51 Answers
It looks like there's a 500GB drive out there for it, so I'm going to guess you can at least go to 500.
Take a look at this. They guarantee 100% compatibility it seems:
http://www.comptick.com/500gb-hard-drive-acer-aspire-4520-4530-4530z-4535-4540.html
Operating system not found
No, you won't get the OS to automatically install on the new drive. The OS is not stored in the BIOS chip (or a similar permanent location inside the computer). You will need an OS install disc (not an upgrade disc). Windows Vista Home Premium or Basic was the original OS on most of the Acer Aspire 4530 series. Acer appears to have drivers for the system for XP through Windows 7 to get the hardware to work. You will need to have these most of these ready before you install your OS. Put them on a flash drive or optical disc using another computer.
This computer may work with Unix as well. However, driver issues may be a factor. You can try most versions of Unix from a CD (LiveCD) to test it out.
When you get a new hard drive, install it into the laptop. Then put the OS disk in the optical drive bay. Boot to the optical drive. Follow the directions for formatting the hard drive and installing the OS. (Of course you will need a drive that doesn't have a higher capacity than the BIOS supports.) The motherboard needs to recognize the drive.
If you find a member of a Windows User Group, they may have Windows install discs available. The license number on the label of your computer will probably work as your license key. (The key for a computer like this is locked to the CPU and motherboard; unless someone upgraded the OS to Windows 7 or downgraded to XP, this should be the key you need.) Use the information on the label to obtain the correct version of Vista (the Basic install disc may not work for installing Home Premium). You also need to match the 32-bit or 64-bit install disc (and the service pack you need).
I hope this helps.
(An Acer recovery disc wouldn't help you. Most of those are completely locked to the original hardware (including hard drive) and look for the recovery partition that was on that hard drive.)
Dec 05, 2012 | Computers & Internet
is your Hard drive Detected by the computer? check it in Bios if it is detected or not,if it is detected then select first boot device as Hard drive. still you are getting the same problem then there might be chances that your OS is corrupted and you need to re install it.
Aug 24, 2012 | Acer Aspire 4530-5889 Notebook PC
Acer Aspire 5002WLMi Laptop won't recognize full 320 Gigabytes of new PATA hard drive. It's always been running a 80 Gigabyte 4200 RPM but that drive is old...a 2005 HD. New WD320 only reads 137...
The BIOS in the ACER determines the maximum size of the hard drive it can support.
Check the laptop's specification to see the max size you can install in this model laptop.
It appears that the max size your laptop can support is 140 Gb (unformatted). 137Gb formatted.
I suggest you install a hard drive up to 140 Gb capacity in your laptop and place the 320 Gb hard drive in an USB hard drive adapter case and when you attach this hard drive to the USB port in your ACER laptop then you will be able to get the full 320 Gb capacity after you delete the partition and create a 320 Gb partition and format the hard drive.
Nov 02, 2011 | Acer Aspire 5002WLMi Notebook
I have an acer aspire t180-oa7z. i want to put a new hard drive in. my current hard drive 80gb SATA. what hard drive would you recommend?
For your current spec hard drives can support up to 400GB. So I would like to suggest using 320 GB hard drives, and I see hard drives with this capacity still available on the market.
Aug 07, 2011 | Acer Aspire™ T180 PC Desktop
THE ACER ASPIRE 5735Z WITH WIN 7 WILL NOT FID IT
Hi, Thanks for using fixya.
Western Digital 320 GB Hard Drive Is for a pc not a laptop so it won't fit it.
Terry
Feb 14, 2011 | Western Digital (WD3200JS) 320 GB Hard...
320 gb seagate hard disc formating problem
Send your seagate back under warranty (RMA) they will send you a new one.
May 26, 2010 | Western Digital (WD3200JS) 320 GB Hard...
Error 0x00007b with acer aspire 4530
I think your Hard Disk is affected with some bad sectors. Try formatting the entire Hard disk. Remove anyother devices that you have, like any memory cards in slot or cds or USB drives etc.
Thank you!
Sabharish
Aug 15, 2009 | Computers & Internet
Upgrade Acer Aspire m1100
Is you are going to do a complete overhaul, you are better off going with a ASUS motherboard, with a processor, and 4 GB of memory. Here is a good place to get all these parts and your computer will run REALLY great.
www.computershopper.com
Feb 08, 2009 | Acer Aspire M1100-U1402A Refurbished AMD...
Acer Aspire 4520-5582 Notebook Logo
183 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
