Question about Speed Queen AES68AWF Dryer
My speedqueen dryer model AES68AWF has stopped working. 1st the dial was making an odd noise, then no heat, and then I tried again and had heat, dried some clothes, and then the next day when I went to use it, no heat again. I turned the dial to turn it off, and it make a odd noise and then went completely dead. Now nothing. Don't know what to check 1st. We could replace parts if we would know what to replace. Any help would help. Forlands
  • Speed Queen Master
  • 1,830 Answers
How old is it?
Posted on Jun 25, 2017
  • 61 Answers
SOURCE: Speedqueen Commercial Dryer trips electricity
there is moisture in there and it trips off the safety switch. some refridgerator points are not connected to the safety switch, this can dry out the moisture and this safety switch is there to save lives, don't touch the appliance when on and do at own risk because i am covering myself, you shouldn't have any problems but i have to cover myself. there is leakage from probably the element to earth which is the reason i sugest to try and dry it out. your element could be blown as well? you might need a sparkyto replace element
Posted on Jun 01, 2009
SOURCE: Dryer is not drying clothes dry
My Maytag Neptune isn't drying my clothes
Posted on Oct 14, 2009
  • 84 Answers
SOURCE: sounds like something is loose inside the dry drum
Unplug dryer!!
There should be 2 5/16th screws on the bottom panel in front. Then there are 2 more on bottom of top panel. Take off wires to door switch. Take off 4 screws to front bulkhead. Pull it off. Note how belt goes on. Take it off and pull drum.
I would first rotate drum by hand and see where noise is coming from. If inside one of the baffles in drum, you can easily lossen up screws to remove baffle to get things out.
Posted on Jan 12, 2010
  • 77 Answers
SOURCE: dryer will not heat up Does run
It's probably the thermostats that are normally attatched to the element or it could be the element itself. They are nprmally placed in the rear of the appliance.
The thermostats will only cost a few pounds.
Posted on Mar 12, 2010
  • 205 Answers
SOURCE: gas dryer won't dry clothes.
Hello- You most likely need an ignitor or thermal fuse if you are getting no heat at all. Depending on you exact model and if you are electrically handy and have a multi-meter you can test these components and replace them. If you are at all uncomfortable have a Tech come out, they should have the parts on hand and it should be a fairly easy fix. Hope this helps, best regards.
Posted on Sep 27, 2010
Frigidaire model fex831cso serial xe34800123
Hello friend, we appreciate your post!
It appears you have a laundry center FEX831CS0 and that your dryer is not working. Can you provide me more specific details? Is your dryer not heating, not turning on, or not completing a cycle? For instance did you notice any strange functions or odd noises prior to this issue? With this information I can better address the issue at hand. Thank you - Matt
Jul 19, 2014 | Frigidaire FEX831CS Top Load Stacked...
Dryer model lgs37awf is making alot of noise when turning
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 07, 2011 | Speed Queen AES68AWF Dryer
I DONT HAVE A GAS DRYER AND I JUST BOUGHT A HEATER ELEMENT JUST DON'T KNOW WHERE TO PUT IT ON MY SPEED QUEEN DRYER
If does vary by model of SpeedQueen dryer,but typically the heat element fit in the bottom or the rear plate the supports the drum..reply with model number and i will tell you where yours goes.
GENE
Sep 04, 2011 | Speed Queen AES68AWF Gas Dryers
My speed queen model# AES68AWF doesnt heat what could it be?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 16, 2011 | Speed Queen AES68AWF Dryer
My speed queen dryer model #AES68AWF doesnt heat what could it be?
heatman101';
Jul 16, 2011 | Speed Queen AES68AWF Gas Dryers
I have a speedqueen gas dryer model AGM499w iGNITER LIGHTS BUT NO FLAME
heatman101';
May 24, 2011 | Speed Queen AGS28AWF Gas Dryer
Need heating element for AES68AWF Dryer
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Feb 13, 2011 | Speed Queen AES68AWF Dryer
I have a speed queen gas dryer model number Aqm499w2 that will not heat up.
Better give technicians a call your problem seems the igniter is busted.
Nov 06, 2010 | Speed Queen AES68AWF Gas Dryers
Jun 01, 2009 | Speed Queen AES68AWF Dryer
Speed Queen AES68AWF Dryer Logo
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
danoyachtcap
danoyachtcap
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
