Question about 2wire Computers & Internet
I'm receiving a message stating that I have limited Internet access and I don't seem to be getting any service. My 2 wire router has only a red power light showing with no other green lights. I have unplugged it for about 2 min. And plugged it back in to no avail. Please advise. Thank you.
  • 51 Answers
You may be having technical problems. Make sure all of the wires to and from the router are securely seated and power off/on again. If no lights show up again, you will need to call your DSL provider's technical support line for more help.
Posted on Mar 18, 2011
Router can't detect wired connection
Try this:
1.turn off power and disconnect all wires and cable to and from modem.
2.re-connect after 2 minutes.
3.do the modem buttons light up, including internet.?
4.now check if you get internet connection. you don;t need the wiz because you are hard wired thru cable from ISP?
GOODLUCK
Jan 24, 2014 | Asus US RT-N65U dualband wirelessn750...
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
When i my pc on it show me generic host problem after this msg windows stop network services?anyone tel me
You may occasionally get an error message that reads "This connection has limited or no connectivity. You might not be able to access the Internet or some network resources." It indicates that your PC is having a problem trying to access your network device to connect to the Internet. Very often, a bug that typically affects Windows XP Service Pack 2 causes this error message. This bug causes a loss of your network connectivity in workstations that use Microsoft's L2TP-based VPN (virtual private networking) client to connect to the NAT-based networks. You can fix the "Limited or No Connectivity" problem in a few steps. (If your connection works but you still get the error message, go to Section 2 to learn how to disable it.)
Review the following symptoms and determine if you experience any of them after you install the Windows XP Service Pack 2:
You get the error message "Limited or No Connectivity" when you attempt to connect to your network.
You have a problem connecting to your local area network or to the Internet.
You keep on receiving an error message: "Acquiring IP Address" message. If you experience these symptoms after installing Windows XP Service Pack 2, then this bug is causing the problem. In this case, go to Step 2; otherwise, skip to Section 3 Download the Microsoft patch (KB884020) from the Microsoft website. Run this update to install it. Create a registry fix by launching Notepad and typing: [HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Services\\IPSec] "AssumeUDPEncapsulationContextOnSendRule\"=dword:00000002 Save the file as FixReg.reg to your desktop. Double-click the saved file to install it into your registry. Restart your computer and the error message will likely be gone. If you still see the error message, follow the steps in Section 2. b> If Your Connection Works But You Still Get the Error Message b> Navigate to the "Start" button and select the "Control Panel." Double-click on the "Network Connections" icon. Right-click the "Local Area Connection" icon and select "Properties" from the popup menu. Click on the "General" tab. Uncheck the option that is labeled "Notify me when this connection has limited or no connectivity." Click "OK." b> If the Patch Doesn't Fix the " Limited or No Connectivity" Problem b> Check your DSL router for any malfunctions. Re-configure or power cycle your router. Check your computer's network card configurations and network cabling to ensure that the problem does not lie here. Check your firewall to determine whether it is blocking you from connecting to the network or to the Internet. Disable the firewall and attempt connecting to the network or Internet while with the firewall is disabled. If the firewall is causing connection problems, then reset or uninstall and re-install the firewall. Reduce your connection speed to 10 Mbps and test this to determine if it fixes the problem. To do so, navigate to the "Start" menu and select the "Control Panel," "System" and "Device Manager." Review the properties of your network card. Click the "Advanced tab." Locate the "Link Speed and Duplex" section. Change the settings from "Auto Detect" to "10Mbps/Full Duplex." Hope this helps.
Dec 24, 2012 | Computers & Internet
My router is DG834G v5 and it shows a red light for internet and does not connect ,there is no problem with my pone connection as the old modem is working fine, what do i do?
I understand that you are not able to connect to internet through DG834Gv5 as the internet light on the router is RED. I would suggest you to reset and reconfigure the router using the below steps:
RESET:
1. Press and hold the Wireless On/Off and WPS buttons simultaneously until the Power LED turns red (about 6 seconds).
2. Release the Wireless On/Off and WPS buttons. The LED blinks red three times and then turn green when the router has reset to the factory default state. Wait for the router to reboot.
CONFIGURATION:
1. Connect the cable/phone line coming from Internet Service Provider to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports.
3. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
4. Access the router's GUI by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
5. Login to the router (username = admin password = password unless you have changed it).
6. Click on 'Setup Wizard' at the top of list from the left menu.
7. Select Yes and click Next.
8. It should give you 'PPPoA Detected' and then click on next.
9. Enter the login and password of the ISP and then click on Apply.
10. Once the settings are updated click on 'Router Status' and click on 'Connection Status' button (at the bottom of the page).
11. Click on Connect button.
12. Connecting to server should show 'Connected'.
13. If you receive 'CHAP authentication failed', close the 'Connection status' window and click on 'Basic settings'. Verify the login and password for ISP and apply the setting again.
14. Open up another browser window and try to access internet.
Please do visit http://kb.netgear.com for any technical queries regarding NETGEAR products.
I hope this information allows you to resolve this issue.
Regards
Anand
Feb 25, 2011 | NetGear DG834G Router
Hi! I can't connect to the internet wirelessly using a WRH54G. connection status is "limited or no..." when on dynamic IP. status says connected when a static ip is assigned. tried pinging the router and I...
"Limited or no conenctivity" means that the network key(security password) that you typed when connecting to the wireless network is incorrect. Try connecting the laptop to the router using an ethernet cable to check whether you can get online. Access your router's setup page to check your network key.
How to access the router's setup page :
1. Using a wired computer, pull up internet explorer or any browser.
2. On the address bar, type in 192.168.1.1 (default IP)then press enter.It will then ask you for a username and password. If you havent changed the settings, username should be left blank and the password is admin.
3. On the black bar on top of the setup page, click on the Wireless Tab. Then on the purple bar, click on Wireless Security.
4. On the Wireless Security page, you will then be able to check your network key.
Jun 02, 2010 | Linksys WRH54G Wireless Router
It is dhcp server issue.
For that connect your router to computer with ethernet cable then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then go to advanced and enable dhcp .
Then save settings and then restart .
Also you can set ip addrese manualy but make sure it is in range with router.
Let me know if you need more assistanse.
Thanks.
Sep 08, 2009 | NetGear WGR614 Wireless Router
Hello I am having problem with the router wireless connection that always is with limited access and my vendor always says be happy if you can get on the internet. But limited accecc and a research...
limitings access means just jive the ip adress in your computer or laptop manual go to the right clik on the my network place then go to the properties if you using wireless then go to the wireless right click or u using the lan cable then go the right click in the local area network then agian properties then go the tcp/ip option in that using fellowing ip address in that give your ip address then you get the connect full
Apr 03, 2009 | Linksys WAG200G Router
ATT Yahoo Internet Installer does not recognize the DSL modem
If you can, pls post the exact errror message that you receive and which specific application are you trying to install?
Jan 12, 2009 | 2wire HomePortal 1000HW DSL Modem and...
Computers & Internet Logo
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
