Question about Pioneer VSX-819H-K A/V Receiver
My Pioneer vsx-819h seems like it's not displaying the dolbytruehd on the display panel when playing blu ray movies which has this logo and both my blu ray player and reciever has the ability to decode this digital sounds but for some reason when a dolbytruehd movie is being played it's annoying just to see dolby digital on the display panel.Could it be my reciever is defective? I tried playing other movies with this DTHD and some do work but for some movies like "Sweeney Todd and the Transformers which is DTHD it just doesn't register on my reciever but instead shows Dolby digital.can you explain?
You must be using an HDMI cable to get Dolby True HD.
Posted on Mar 18, 2011
How too reset pioneer 4800
Check page 69 of the manual :
Resetting the main unit
Use this procedure to reset all the receiver's
settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the BAND button,
press and hold the STANDBY/ON button
for about two seconds.
3 When you see RESET? appear in the
display, press 'AUTO SURROUND/STREAM
DIRECT'.
OK? shows in the display.
4 Press 'STEREO/A.L.C.' to confirm.
OK appears in the display to indicate that the
receiver has been reset to the factory settings.
http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-819H_OperatingInstructions0508.pdf
Jun 15, 2014 | Pioneer VSX-819H-K A/V Receiver
Why will my pioneer bdp-lx70 play only cd's and blu ray discs but not any ordinary dvd's ?
Check and replace its laser pickup unit. If you wish to get some details; check the site linked here. Pull up older posts.
Nov 26, 2012 | Pioneer BDP-LX70 Installed
How to reset pioneer vsx-819h
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx819hk.html
It's in the manual. Page 12.
Resetting the Main Unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel controls to do this.
2 While holding down the BAND button, press and hold the STANDBY/ON button for about two seconds.
3 When you see RESET? appear in the display, press AUTO SURROUND/STREAM DIRECT.
4 Press STEREO/A.L.C to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory settings.
Sep 08, 2011 | Pioneer VSX-819H-K A/V Receiver
On my pionneer VSX-820-K the dts light is not comeing on when i watch a movie with dts
You may have tuned in a program that advertizes DTS, but, the local cable company may not send it through their atiquated cable network.
Feb 26, 2011 | Pioneer VSX-819H-K A/V Receiver
The display does'nt show the 3d logo so is this a fault because i'm not getting any effects from the 3d glasses and they do work (glasses)
U also must have a LED 3D tv for the 3D DVD movie play on a Blu-ray player to play to get for the 3D movie effect.U now that wright?
Nov 24, 2010 | Samsung BD-UP5000 Blu-ray and HD-DVD...
Twice now my Pioneer VSX-819H has shut down. Can not get any power to it. The first time I'm sure the phono pre-amp caused a surge. I no longer have it hooked up. The servicer said nothing was wrong and...
I found this for the VSX918, 818. Perhaps it's similar.
The power does not turn on. • Disconnect the power plug from the outlet, and insert again.
• Make sure there are no loose strands of speaker wire touching the rear panel. This could cause the receiver to shut off automatically.
The receiver suddenly switches off and the power indicator
blinks.
• After about a minute (you won’t be able to switch the unit on during this time), switch the receiver back on. If the message persists, call a Pioneer authorized independent service company.
Use this procedure to reset all the receiver’s settings to the factory default. Use the front panel controls to do this.
2 While holding down the ADVANCED SURROUND button, press and hold the
STANDBY/ON button for about three
seconds.
3 When you see RESET? appear in the display, press ‘
ST –’. OK?
4 Press SOUND RETRIEVER to confirm.
OK
Mar 02, 2010 | Pioneer VSX-819H-K A/V Receiver
Pioneer vsx-819H: MCACC setup won't display on tv
I would say check the cable version not everyone knows this but there are different version HDMI cables such as 1.0,1.1,1.2 and the newest 1.3 cable these are band-with depended cables and if you use a lower version this should work if not you might have a issue with video.
Other then that you might have a issue with the unit if all other signals are working on the monitor.. Ruling out this will be hard if you do not have another monitor to test it on. I would be conducting a test on other output monitors and see if you get any results.
please press the accept button as I worked hard to answer you question.
Oct 24, 2009 | Pioneer VSX-819H-K A/V Receiver
Cant play blu-rays on lcd hdtv connected with hdmi
The software playing the bluray disc (PowerDVD) will only play it on the primary display. You will have to set your tv to be your primary display in order to watch the movie.
This only happens with bluray and HD-DVD discs.
Dec 06, 2008 | Sony VAIO Notebook
Vsx-94txh
If I'm not mistake, it's dependant on you monitor's ability to display 1080p. I believe the defaul setting on the 94TXH is to read the TV's max resolution and anything above will not feed.
Dec 22, 2007 | Pioneer VSX-94TXH
Pioneer VSX-819H-K A/V Receiver Logo
207 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
