Question about Hamilton Beach BrewStation 47224 Coffee Maker
I have had my coffee pot for 3 months, it makes coffee fine, but after awhile i find a whole bunch of leakage on counter. Leaking from coffee container. I took bottom apart and didnt find nothing wrong with seal, hope tightening screws up helps after putting back together
  • 5,603 Answers
I have a different brand but mine has a thermos inside of the coffee pot itself. The seal at the top kept leaking. Solution was to put some food-safe grease on the seal AND most importantly was putting some on the plastic parts of the screw on the bottom that puts pressure on the bottom of the thermos. The threads gaul and one cannot tighten the screw to put enough pressure on the bottom of the thermos to get a good seal at the top.
Not sure if yours is this type, but if it is this might be a solution to try.
Posted on Mar 18, 2011
I made a normal pot of coffee this morning. The clean light came on, so I cleaned it. The coffee pot is only 2-3 months old. I know the process of cleaning it can take up to an hour. After about 30...
I think there is a real problem with the whole cleaning system with the Mr. Coffee Pot. I have one and after making only a few pots of coffee, the light starts blinking. I have cleaned it over and over and still get the same alert. My son had the same problem you have with his, it wouldn't finish the cleaning cycle. He'd had it awhile and ended up tossing it because it was beyond the warranty and store told him too bad. I've had other Mr Coffee makers and like them, but they didn't have the irritating "clean" alert OR the obnoxious BEEPING to let you know it's done brewing. If I knew this was going to be an issue - I would never have bought it. Why do they have to screw around with a good thing - more buttons and thing cycles to cause problems.
Sep 04, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
I have a Black 4 cup Mr Coffee with luminate lighting and time display programer so that I can have coffee brewed in the morning when I get up for work at 4:30am my problem is the coffee pot has started...
I had a black and decker coffee pot do same thing and it was brand new. here is how I fixed it.
make sure the filter seated down good. If you look at the top of the coffee pot it should open up the little valve of the coffee filter holder. also mine had a little water spout above the coffee filter that swings over the filter. make sure it is over the filter. I know my coffee pot is different, but I think the problem is the opening from filter to coffee pot is not open some how so the water is flooding over the filter and going out the sides onto counter
hope this helps
Jan 28, 2011 | Microwave Ovens
While the coffee is brewing without using the grinder feature, coffee overflows onto the counter. About 1/2 of the coffee goes into the pot while the rest spills over. I have cleaned residue from the lid...
overflow problem possible causes: 1) water is over the "10" marker, 2) no filter in basket 3) too much (or too fine) of coffee in the basket -- does not drain. Also make sure the "spring" on the bottom of the basket is not stuck (the one that lets you remove coffee carafe without dripping coffee.
Jan 17, 2011 | Cuisinart Thermal DGB-600 Grinder
What is the best way to remove lime scale and other mineral build up from a Bunn VPR coffee maker? Water flow has been reduced to a trickle even though we used filtered water.
I always use CLR to clean my coffee maker. You don't need much more than 1/4 cup and mix with 8 cups of water and brew it like you would make a pot of coffee, then dump it out and run 2-3 more pots of just water, that should work fine. Also, run vinegar thru the machine once in awhile to help keep it clean
Apr 13, 2010 | Bunn VPR Coffee Maker
My coffee keeps ending up all over the counter! Some of it still makes it into the pot but I don't know where all the excess coffee is leaking from
A common problem is incorrect assembly of the top for the pot or the filter. Sometimes the parts fit even in the wrong order.
Oct 16, 2009 | Cuisinart DGB-600 Coffee Maker
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
Coffee pot leakage
Have you contacted Hamilton Beach to file a complaint? Or the BBB website? If there is a manufacturer defect with the unit and enough people complain they will need to remedy the problem or refund money. If you have been reading that there are other people with the same problem and it is not isolated then I would return the cofee pot and get a different model/brand. Check a site like www.epinions.com that allows people to rate products they are using. I use them all the time before I purchase a product.
Oct 03, 2009 | Hamilton Beach BrewStation 47214 Coffee...
My Brunn coffee maker is leaking from the bottom also.
I have the same problem and I took the coffee maker apart to find out why. The fitting for the hold in the black pastic that the water flows through to get into the stainless steel tank may not have a tight fitting with the plastic and that's where I had water leakage. I used some silicone sealant to fix the leak and the water stopped leaking!
Sep 28, 2009 | Bunn 10 Cup Home Coffee Brewer
Leaking coffee pot
Mine did that too... Only suggestion is to place a towel on the counter...
Mar 07, 2008 | Cuisinart Thermal DGB-600 Grinder
Hamilton Beach BrewStation 47224 Coffee Maker Logo
151 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
80stech
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
