Question about Altec Lansing : 5.1 Amplified Speaker System Computer Speakers
I recently upgraded my computer to Windows 7 Ultimate, and partitioned and deleted the Windows.old file that spawns from it. I haven't been able to hear sound from my speakers since I upgraded however. They are the 5.1 Altec Amplified Speaker System what else they are to distinguish, I don't know unless you tell me where to look. And it is set up properly as it worked a few hours ago. Anyway, any help you can give would be great. Thanks, Garrett
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 18, 2011
Is it possible to upgrade windows XP to windows 7
If you are asking could you upgrade directly from Windowx XP to Windows 7 as a direct upgrade, the answer is yes but it's not recommended.
The much better method is to use Windows Easy Transfer to move your important files from your computer onto an external hard drive. After all your files are backed up safely, it's best to start the Windows 7 install and when you get to the "Upgrade" or "Custom (advanced)" screen to choose Custom. This will open up the drive view. Click on "Drive options (advanced)" which will bring up the ability to delete the partitions.
If you find that you have more than one shaded area in the Drive 0 bar, you have more than one partition. Unless you have experience creating and modifying partitions, only delete the partitions on Disc 0 which are marked Drive (C:). Otherwise, you can decide what partitions you need to delete to make enough room for Windows 7.
I'm not sure if you've already done your homework or not but before you upgrade to Windows 7, run the update advisor to ensure your system and software is Windows 7 ready and make sure to collect the hardware drivers that work with the exact version of Windows 7 you are installing... 32 bit and 64 bit are totally different monsters!!!
Having all of your software install disks on hand, and all your backups (and a bootable copy of the backup software!!) and Windows 7 hardware drivers on an external hard drive is the best way to approach an upgrade.
Best of luck!! Hope this helps.
Mar 22, 2014 | Acer Aspire Computers & Internet
How do I recover or repair bootini and bootsect for Windows XP Professional after uninstalling Windows 7 Ultimate?
It's good that you have the recovery cds. Do NOT reformat the hard drive. Restore with the cds so you'll have a clean install . You will need to have any software cds that did not come with the original pc in order for them to rebuild the registry entries. That is the easiest way because there won't be any left over files from Windows 7 after you restore to XP.
Jan 24, 2014 | Computers & Internet
How to uninstall windows 7
Step 1:
Delete Windows 7 b> Released in October 2009, Windows 7 is the most recent Microsoft Operating system (as of September 2010). It offers several advances over previous versions of windows, including improved media functions and networking. Windows 7 is not for everyone, however, and there are instances in which someone may wish to remove Windows 7 in favor of an earlier version. There are three ways to delete Windows 7, and the method you use depends on how it was originally installed.
b>Back up the data on your computer. Go to the Windows Start Menu. Select "Computer" and right-click on the "C" drive. Left-click on "Properties" and write down the amount of free space on your drive. Close out of the "C" drive properties and go to the Windows Start Menu. Type "Windows.old" in the "Search Programs and Files" box. If the "Windows.old" folder does not exist, skip the rest of this section and go to the section titled "Remove Windows 7 from a Computer with No Previous Operating System." Right-click the Windows.old folder, left-click on "Properties" and look at the of the folder. Compare the of the folder with the amount of free space on your drive you wrote down in Step 2. The Windows.old folder contains compressed files; if the folder is more than two times the of the amount of free space on your drive, skip the rest of this section and go to the section titled "Remove Windows 7 from a Computer with No Previous Operating System." For example: If you only have 10GB of free space on your C drive and the Windows.old file is 22GB large, when it expands it may use up the remaining 10GB and then some. Insert the Windows 7 installation disc and reboot your machine. Select the option to boot from CD/DVD when prompted. Set the language, time and location-specific settings and click "Next." Select "Repair Your Computer" from the list of installation options. Select your version of Windows 7 and click "Next." Click "Command Prompt" to open the command prompt window. Type the following commands, and hit the "Enter" key after each: C: Md Win7 Move Windows Win7\Windows Move "Program Files" "Win7\Program Files" Move Users Win7\Users Attrib --h --s --r ProgramData Move ProgramData Win7\ProgramData Rd "Documents and Settings" Type the following commands and hit the "Enter" key after each: move /y c:\Windows.old\Windows c:\ move /y "c:\Windows.old\Program Files" c:\ move /y c:\Windows.old\ProgramData c:\ move /y c:\Windows.old\Users c:\ move /y "c:\Windows.old\Documents and Settings" c Restore the boot sector for the earlier version of Windows with one of the following commands: For Vista, type: D:\boot\bootsect /nt52 c: For Windows XP or Windows 2000, type: D:\boot\bootsect /nt60 c: Type the following commands and hit the "Enter" key after each command: Attrib --h --s --r boot.ini.saved Copy boot.ini.saved boot.ini Close the Command Prompt window and reboot your computer. b> Remove Windows 7 From a Multi-Boot System Boot your computer to the Non-Windows 7 Operating system and back up your data. Go to the Windows Start Menu, select "Control Panel" and click "System and Security." Select "Administrative Tools" and double-click "Computer Management." Enter your Administrator Password if prompted. Click "Storage" on the left and select "Disk Management." Locate the drive or partition that is running the Windows 7 operating system. If you have both operating systems on the same partition, skip the rest of this section and go to the section titled "Remove Windows 7 from a Computer with No Previous Operating System." Right-click on the Windows 7 partition, click "Format" or "Delete" to remove Windows 7 from that partition. Click "OK" and reboot your computer. b> Remove Windows 7 from a Computer with No Previous Operating System Back up the data on your hard drive and insert the desired Windows installation disk, such as Windows Vista or Windows XP. Reboot your machine and select the option to boot from CD/DVD. Press "Enter" to start the installation process. Hit F8 to agree to the "Microsoft Software License Terms" and select the option to install a new version of the software. Select the C: drive and highlight the option to format and partition the drive. Press the "Enter" key. Follow the on-screen prompts to install Windows. The computer may reboot several times during the installation process. Enter your product key when prompted.
b>
Feb 05, 2013 | Sony VAIO VPCEA25FX/WI E Series 14...
Want to restore previous "Windows.old"
you deleted the partition C that the windows old folder was on, you may try a windows restore, however....the files can be retrieved they are still there, you need YODOT HARD DRIVE RECOVERY PROGRAM to scour the old partition that was there previously and restore the folders that you wish to recover onto a new area of the new partition. PLEASE NOTE THE MORE YOU FORMAT OR CREATE AND DELETE NEW PARTITIONS ON YOUR OWN THE MORE THE RECOVERY SOFTWARE WILL FIND IT HARD TO RETRIEVE OLD FILES, SO BEST NOT TO TRY ANY MORE ATTEMPTS ON TRYING TO RECOVER THE LOST ARCHIVE YOURSELF LET YODOT RECOVERY DO IT FOR YOU FIRST. CHEERS
How to Recover Deleted Files using File Recovery Software
May 02, 2017 | Computers & Internet
I bought a new toshiba satellite laptop and there was 2 options to choose from . 1 - win 7 english 2 - win 7 french the english version didn't work and then i tried the french version to see what...
Hi.
To install a different language - Multilingual User Interface (MUI) - you need to have Windows 7 Ultimate.
Anytime Upgrade to Windows 7 Ultimate
Type Anytime Upgrade in the Search programs and files box in the Start menu and click on the Windows Anytime Upgrade icon. From there, you can buy an Anytime Upgrade to Windows 7 Ultimate. Then your can enter your Anytime Upgrade product key and perform a simple upgrade to Windows 7 Ultimate so you can install a different language.
If you are in Australia, Belgium, Canada, France, Germany, Italy, Japan, the Netherlands, Spain, Sweden, Switzerland, the UK, and the US you can use Anytime Upgrade. If not you will need to buy Windows 7 Ultimate, or buy Windows 7 in the language you need.
http://windows.microsoft.com/en-us/windows7/products/windows-anytime-upgrade
Install Language Pack in Windows 7 Ultimate
1. Start -> All Programs --> Windows Update --> Optional Updates.
2. Open optional Updates and go to the section Windows 7 Language Packs.
3. Tick the Language Pack you want and hit OK
4. Proceed with Install Updates
5. Depiction of Windows 7 downloading a Language Pack
6. Automatic install initiated after download
How to change the Windows 7 Display Language:
1. Go to Start -> Control Panel -> Clock, Language, and Region / Change the display language
2. Switch the display language in the Choose a display language dropdown menu.
3. Click OK
4. Log off for the changes to take effect (This will affect only the user profile under which you are currently logged on).
The only other way to get the English language is to use the recovery partition or recovery disk to start over from scratch.
If there is anything else please post back..
Good luck.
Jun 13, 2011 | Computers & Internet
I am working on a emachine desktop that had windows xp on it, I am trying to install windows 7 ultimate on it, after formatting the hard drive and setting up a partition, It installs about 81 percent then...
Your computer -may- be out of date. The visual hardware need to run windows 7 must be up to date, and not made before 2003. Depending on how old your computer is, Windows 7 may or may not run on it. It may also just as well be a problem with your monitor. Is your monitor very old?
Mar 15, 2011 | E-Machines eMachines Desktop PC
Unable to connect to internet on broadband, keep getting error message 651, Win 7. No problem prior to loading Win 7, used to have Vista Ultimate.
This a well known bug in Windows 7 specially when you migrate from Windows Vista to Windows 7.
The cause is a file "raspppoe.sys". This file will be found on the partition you have installed your operating system If it is C: partition then it is found on C:\Windows\System32\drivers.
To fix this bug simply rename it as shown as follows
(1)Rename this file from "raspppoe.sys" to raspppoe.old or any name it any name of your choice.
(2)Once this done simply restart
Nov 11, 2010 | Microsoft Windows Vista Ultimate Edition
Downloaded window 7 on my netbook and forgot to backup before installing i had xp
Sadly, there is no direct upgrade path for XP (pro or home) to Windows 7, only Vista. Windows 7 from XP requires a clean install.
Still, check the hard drive and see if Windows 7 moved the files to another location. It installs differently from XP or Vista and there may be a chance they are still somewhere on the drive. Use the search feature to look for a known file and see what happens.
Dec 06, 2009 | Gateway LT2021u Netbook
I have an acer 4520 with default OS as Vista home basic. I upgraded it to windows 7 ultimate. Now I can't revert back to factore defualt settings , ALT + f10 not working(after enabling from BIOS) and I...
Hi there, Do you have a backup of your vista ??
It would bee much easyer if you have such one.
Another thing do you have setup cd/DVD ??
Maybe you windows 7 have deleted your windows vista setup Partittion in your computer, if you not have the setup cd it must be in a partition in your harddirve, but maybe you have deleted it when you have installed windows 7 :O(
Take a look if you did get this DVD with your purchase
Hope that helps
IF not then return here
Have a nice day
Please rate my answer
Oct 24, 2009 | Computers & Internet
Altec Lansing : 5.1 Amplified Speaker System Computer Speakers Logo
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
