Question about Dryers
My dryer keep shutting off.It will run about 10-15 mins and shut off then i will have to wait about 5 mins and cut it back on.The dryer is hot when it shuts off.
The first thing to do is clean both the inlet and outlet filters.
Posted on Mar 18, 2011
Ge adora dryer model dhdvh52ef0ww runs for about 5 minutes then cuts off
Inside the back and the bottom of your dryer are several ( From 2 to 6 ) "overheat thermostat switches".
One of these is doing it's job really well.
These are designed to prevent your dryer from overheating and catching fire.
I suspect one of them is failing, and needs replacement.
Someone handy with electrical testing tools and mechanic's tools need to take it apart and check these to find the "bad" one.
While they have it all apart, it should need a really good cleaning inside.
Be blessed.
Mar 22, 2013 | Dryers
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Dryer keeps shutting off
If it's shutting off while it's running, it's probably the thermal overload fuse tripping and cutting off the power. This could be caused by a number of things, so if you can post back with the following information, I can assist you further more easily.
1. Your brand and model of dryer
2. Does the dryer turn back on quickly or do you have to wait about 15-30 minutes?
3. Is it making any unusual noises?
Thank you.
Oct 19, 2010 | Bosch Dryers
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Dryer shuts down within 5 mins of running
your vent is plugged up move dryer away from wall and allow room for vent
Mar 25, 2009 | Whirlpool Dryers
Dryer makes squeaking noise ,then dryer shuts off. mdl.#CYG4000AWW
Hello, sounds like the rear drum rollers are in need of replacement which is causing the motor to get hot and cut out on the thermal cut out. It can be tricky to service if you not handy. Good Luck
Oct 19, 2008 | Magic Chef CYG4000AWW Gas Dryer
Power Working fine but keeps shutting off
Hi jenniferlahm,
This type problem usually shows it mean head when your motor is going bad. The motor will run for just a moment then it gets really hot and shuts off till cool. I bet when you start the dryer you hear a unusuall humm as the motor starts. If you are not hearing a hestating humm as it starts then the problem may be elsewhere. Other possible problems that casue this would be. the tub rollers. To check the rollers reach inside and try to turn the tub with your hand. you should be able to turn the tub. if not you may need new rollers, or pads. Good luck and I hope its not a bad motor, but if it is let me know and I can have you one there in no time.
Mike Anderson (Owner)
Anderson Appliance
(865)945-3808
Sep 24, 2008 | GE DBSR453EBWW Electric Dryer
TDC 30 Dryer starts but after 5 mins "clicks and stops"
its probably the relay (brown plastic box at the front under lid)! Symptoms are usually.... the dryer will go for a few minutes then shut down.... then you have to wait for it to start
May 23, 2008 | Hotpoint TDC32 Electric Dryer
Dryer keeps blowing the fuse in the fuse bow
check your venting going to the outside it sounds like it is clogged run a load with out the vent connected to the back and see if it works ok if so you need to brush clean the vent to the outside
Jan 21, 2008 | Kenmore 63932 Electric Dryer
Dryers Logo
316 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
