Question about Canon MP520 All-In-One InkJet Photo Printer
My Canon MP 520 will not print on A4 paper but does so on A5. It used to print on both. My computer is unchanged
  • allanblack Mar 22, 2011
    Thanks. However I cannot find "Device Settings" or similar on my printer. I have tried likely alternative settings without success.
  • Canon Master
  • 32,281 Answers
Go to Printers and Faxes - right click on the Canon printer - click on Properties - click on Device settings ans select the paper size you require for each tray.
Posted on Mar 18, 2011
Canon ip3600...printing from micro soft publisher it reverts to default paper size A4. How to correct this.
Select what you wish to print, go to printer settings, select paper size and the print.
Dec 09, 2017 | Canon Office Equipment & Supplies
OKI 461 error C531dn LED Colour printer.Says the paper is wrong but it isn't! It's suggesting I have to load A5 paper although I am printing A4 and it's an A4 tray. Done loads of printing before.
I suspect you have sent the job to the MP ray and it wants you to put paper in it. Cancel the job and go back into the driver and make sure paper source is set to the cassette.
Aug 17, 2017 | OKI Office Equipment & Supplies
Load A4 paper in the multi-purpose tray again,and then press [paper] to print. error shown in LBP2900B
If you normally print on letter sized paper, then some program you are using is trying to print on A4 paper (PDF files often the culprit) and the default on most printers is that if they do not have the paper loaded it will ask for it from the MP tray. You can check your printer settings as you may be able to tell the printer to automatically sub letter paper when A4 is requested.
Sep 20, 2015 | Canon LBP2900
Oki - how to print booklet?
The paper you have inserted into the printer, and your page size settings have to match. You can't load A4 paper and tell it to print A5 size. This is why it is printing so small on the A4 paper. It assumes you need to trim it down to A5 size after printing.
Jul 15, 2012 | Office Equipment & Supplies
I have a canon mp 240 and it Prints fine if you only need half of the document. It cuts everything in half! Like it reads the header wrong or blows up the words or make extra spaces. How can I get it to...
I thought maybe you have the paper size set to Landscape rather than Portrait. If not, then you might look at:
http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#ServiceAndSupport
I did some searching on that site and it yielded the hlep below which may give you some help.
Issue: How do I set my printer so my printout fits the paper size I am using?
Solution: Use the recommended Print Area MP240
Printing Area title-bar.gif To ensure the best print quality, the machine allows a margin along each edge of media. The actual printable area will be the area inside these margins.
Recommended printing area (dark blue):
Canon recommends that you print within this area. (o_darkblue13.jpg)
Printable area (light blue):
The area where it is possible to print. (o_lightblue14.jpg)
However, printing in this area can affect the print quality or the paper feed precision.
o_area15.jpg i_note.gif Note
Borderless Printing
By selecting the Borderless Printing option, you can make prints with no margins.
bullet_s.gif When performing Borderless Printing, slight cropping may occur at the edges since the printed image is enlarged to fill the whole page.
bullet_s.gif For Borderless Printing, use the following paper.
- Glossy Photo Paper "Everyday Use" GP-501
- Photo Paper Glossy GP-502
- Photo Paper Plus Semi-Gloss SG-201
- Photo Paper Pro Platinum PT-101
- Photo Paper Plus Glossy II PP-201
-Photo Paper Pro II PR-201
- Matte Photo Paper MP-101
Performing Borderless Printing on any other type of paper may substantially reduce printing quality and/or result in printouts with altered color hues.
Borderless Printing on plain paper may result in printouts with reduced quality. Use them only for test printing. You can perform Borderless Printing on plain paper only when printing from your computer.
bullet_s.gif Depending on the type of paper, Borderless Printing may reduce the print quality at the top and bottom edges of the paper or cause these parts to become smudged.
See A5, A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide.
See Letter, Legal.
See Envelopes.
sikaku.gif A5, A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide
Size
Printable Area (width x height)
A5*
5.56 x 7.95 inches / 141.2 x 202.0 mm
A4
8.00 x 11.38 inches / 203.2 x 289.0 mm
B5*
6.90 x 9.80 inches / 175.2 x 249.0 mm
4" x 6" / 10 x 15 cm
3.73 x 5.69 inches / 94.8 x 144.4 mm
4" x 8" / 10 x 20 cm*
3.73 x 7.69 inches / 94.8 x 195.2 mm
5" x 7" / 13 x 18 cm*
4.73 x 6.69 inches / 120.2 x 169.8 mm
8" x 10" / 20 x 25 cm*
7.73 x 9.69 inches / 196.4 x 246.0 mm
Wide*
3.73 x 6.80 inches / 94.8 x 172.6 mm
* This page size can be used only when printing from your computer.
o_ap_069.jpg o_darkblue6.jpgRecommended printing area
o_lightblue7.jpgPrintable area
sikaku.gif Letter, Legal
Size
Letter
8.00 x 10.69 inches / 203.2 x 271.4 mm
Legal*
8.00 x 13.69 inches / 203.2 x 347.6 mm
o_ap_074.jpg o_darkblue4.jpgRecommended printing area
o_lightblue5.jpgPrintable area
sikaku.gif Envelopes
Size
European DL*
4.06 x 7.12 inches / 103.2 x 180.8 mm
US Comm. Env. #10*
3.86 x 7.96 inches / 98.0 x 202.1 mm
* Envelopes can be used only when printing from your computer.
o_darkblue8.jpgRecommended printing area
Jun 30, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Kyocera 3800N Defaulted To MP Tray
paper guide was set at A5, then this allowed menu to change feed tray selection
Apr 29, 2009 | Kyocera Mita FS 3800 Laser Printer
Lines through photos
you'll have to clean the printer head. It's possible that your driver can do it automatically. It happens after a long time whitout using the printer. The ink can become dry and solid.
Feb 04, 2009 | Canon MP520 All-In-One InkJet Photo...
How to print envelopes on my printer
Use The Recommended Print Area For the best printing results, adjust the top and bottom margins of your document to within the recommended printing area shown below. Click on the paper size listed for the recommended print area settings: A4 / B5 / A5 / 4 x 6 / 4 x 8 / 5 x 7 / Credit Card, Letter and Legal, Envelopes (DL / COM#10)
Caution: When printing is performed outside the recommended printing area, the top and bottom edges of the paper may curl, the print quality may deteriorate, or the printed side may be smudged.
The printer has both the recommended print area and the printable area, according to the paper size.
05sj00144_01.jpg Recommended print area: This indicates the recommended print area.
05sj00144_02.jpg Printable area: Although this indicates the printable area, degradation of print quality may occur.
Note:
  • Set Borderless Printing to print without margins.
  • In Duplex Printing, the printable area of the paper's header is approximately 2 mm narrower than usual.
05sj00084_03.jpg Letter / Legal
Envelopes ( DL / #10 )
Nov 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Manual Feed Issue
will not pick up envelopes to print
Feb 09, 2008 | Lexmark C530dn Laser Printer
Card making
This machine will only print certain sizes as borderless. A5 is not one of them. You can use the following media with this feature: Matte Paper - Heavyweight: A4, Letter Premium Glossy Photo Paper:A4, Letter, 5 x 7", 10 x 15 cm/4 x 6", 8 x 10" Photo Paper:A4 Premium Semigloss Photo Paper:A4, Letter, 10 x 15 cm/4 x 6" Glossy Photo Paper:Letter, 10 x 15 cm/4 x 6" As you can see A5 is not in the list, therefor you will not be able to print A5 borderless via the normal means.
Aug 21, 2007 | Epson RX620 All-In-One InkJet Photo...
Canon MP520 All-In-One InkJet Photo Printer Logo
29 people viewed this question
old marine
old marine
