Question about Creative Technology SBS 245 2 Speakers
I have ceative SBS 245 speakers.2 das ago i did format my pc and install win7 .i have n sond.poblem find that no audio output device is install.please help us.
  • Creative Tec... Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 18, 2011
Hi there ive got wharfedale lcd dvd 19" and on the t con board a ic has blown but i carnt see number
It is likely a proprietary wharfedale chip and no info will be available. you will need to purchase a board assembly or replace the device.
May 06, 2014 | Creative Technology SBS 245 2 Speakers
My sbs 245 jack is unconnected to cpu. how do i connect it again
plug the green jack in the green inlet at the back of your pc and there wil be music
Nov 26, 2013 | Creative Technology SBS 245 2 Speakers
Polarity
usuall on speakers it does'nt matter other than both must be the same. If you do connect them incorectly 1+- other -+ you will notice a loss of bass but should not domage the speakers. However are you talking about connection to a power supply?
Sep 14, 2012 | Creative Technology SBS 245 2 Speakers
I am recently upgrade win7 hp nx9110 audio output device not installed msg getting how to resolve
Ok this is kind of common with Windows 7. Although everyone thinks its new its really not just a fairly bug free OS. The HP models running Win7 actually are using the Vista or XP driver for audio. I just ran into that issue a few months ago when upgrading a Pavillian model.
Aug 13, 2010 | HP Compaq Business NX9110 Notebook
Yar i have formatted my pc and i have installed driver but no osund is comimng in headies and 5 speakers?
did you set it up under your sound device's in the control panel may need to set default sound device so it knows what to be using for a sound device this happens some times. for output to speakers it needs to be set to the speakers as default you should see you audio card and any other output hw
Jul 01, 2010 | Creative Labs Sound Blaster Live! 5.1...
Can't hear playback. Windows Vista - Playback device says usb Audio Codec
here is what ION is telling people (short version) this is for vista or win7
1. Visit www.ionaudio.com/ezvc to download the latest EZ Converter software.
2. install new software if needed,
3. connect ION Audio USB. make sure its ON (if it has a switch)
Setup Procedure
1. Start then Control Panel.
2. double-click Hardware and Sound.
3. double-click Sound.
4. At top select Playback tab. choose the audio output device.
Don’t chose “speakers-usb audio codec” (that’s your ION) don’t chose modem
5. click Set Default.
6. select Recording tab at top of Sound Control Panel. choose "Microphone – USB Audio Codec" as the default device. (that’s the ION)
7. Click Set Default.
8. click Properties. select Advanced tab
9. set the Default Format setting to 2-channel, 16 bit 44100 Hz (CD Quality).
10. Un-check the two boxes under Exclusive Mode. Click Apply
11. select Levels tab from the top of the Sound Control Panel.
12. Set the level slider to 4. Click Apply, click OK to close the window.
Have everything set up and running, if you have to call this number for help.
401-658-3743 ext. 1405
Jun 25, 2010 | ION Audio iTTUSB Turntable
Speakers not Working :(
The Problem might be that the speakers have an internal problem or that the wires are messed up inside. What I suggest you to do if you can is to return them to the store where you bought them.
If you need more instructions on how to try to fix the speakers, please feel free to contact me and I will Be GLAD to help you.
Thank You and have a good day!
Jun 18, 2008 | Creative Labs SBS 330 Computer Speakers
No sound through speaker or headphone
double check the speakers connection. Make sure you plug it in the right hole.
May 06, 2008 | Fujitsu LIFEBOOK S6010 Notebook
Creative Technology SBS 245 2 Speakers Logo
152 people viewed this question
Top Creative Technology Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Creative Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
