Question about Nokia 6600
Auto shut-off - Nokia 6600
  • 356 Answers
There's a solution for this issue at:
http://www.nairaland.com/nigeria/topic-9552.0.html
Basically soft format your phone. There's instructions there. Please back up everything important first!
Please leave feedback if you find this helpful.
Posted on Mar 18, 2011
Bizerba SE12 slicer with the auto slicing. When on manual it runs for 30 seconds and shuts off. Start it again right away, after 30 seconds it shuts off. Manual slice it does not shut off Suggestions?
turn up auto operation time (knob on side) not thickness knob to a time more acceptable to you (or it can be malfunctioning too) just by noting auto slice mode tells you it runs on a timer , as it auto advances product to make even thickness slices each time
Aug 13, 2016 | Kitchen Appliances - Others
Tip
Copiers Sharp AL-1631 AL-1641CS DESCRIPTION OF SPECIAL FUNCTIONS
Toner save mode
Reduces toner consumption by approximately 10%.
Power save modes
The unit has two power save modes of operation: preheat mode and auto power
shut-off mode.
Preheat mode
When the unit enters the preheat mode, the power save indicator will light up
and other indicators will remain on or off as before. In this condition, the fuser in
the unit is maintained at a lower heat level, thereby saving power. To copy from
the preheat mode, make desired copier selections and press the start key
using the normal copying procedure.
Auto power shut-off mode
When the unit enters the auto power shut-off mode, the power save ( ) indicator
will light up and other indicators except the ONLINE indicator will go out. The auto
power shut-off mode saves more power than the preheat mode but requires a
longer time before starting copying. To copy from the auto power shut-off mode,
press the start key. Then make desired copier selections and press the star key using the normal copying procedure.
Auto clear
The unit returns to the initial settings a preset amount of time after the end of copy, or
scanner job. This preset amount of time (auto clear time) can be changed.
Stream feeding mode
For description of the stream feeding mode, see "Stream feeding mode".
Resolution of AUTO & MANUAL mode
You can set the copy resolution used for AUTO and MANUAL ( ) exposure
mode.
on Mar 14, 2010 | Office Equipment & Supplies
Where is the auto shut down relay on a 1999 dodge durango
The auto shut down relay is located in the fuse box that is located under the hood of the Durango. The auto shut down relay should be marked for location on the underside of the lid of the fuse box.
May 17, 2014 | 1999 Dodge Durango
Shark g1468 auto shut off (iron won't come/stay on)
First let me say I HATE AUTO SHUT OFF!!! It sounds like it has wore out. the computer part that tells it when to shut off it not working. It would be cheaper to buy a new one vs fixing yours. If I were you, find an older iron that has LOTS of steam vents and NO AUTO SHUTOFF at your local goodwill, thrift store or garage sale.
Jan 06, 2014 | Shark Euro Pro GI468-FS Rapido...
Power save mode
Enter in the User programs and select the auto power shut OFF setting.Use this setting to enable or disable auto power shut OFF,press 0 to OFF or 1 to ON.The program name is auto power shut off setting and the program number is 5.
Nov 19, 2009 | Sharp AR-M205 Copier
I have a Rowenta Pro. Iron, model DE-86.1A with auto shut-off. It sticks on auto shut-off. I have to move it around for it to heat up, as indicated by the sensor light on the top.
I believe that is how the safety feature works.
Once the iron detects no movement for a certain period of time (the iron assumes you have finished ironing) the iron will shut of the heating element.
One you have moved it around, the timer should prevent it from auto shutting down for a period of time.
Jul 22, 2009 | Rowenta Irons
Blowing smoke immediately prior to auto-shut-off
Try a new CAD falme sensor, or high limit control, both very cheap.
Jan 07, 2009 | Reddy R155D Utility Heater
Hello - Canon ZR80 - auto shut off
If you're trying to use the camera as a webcam, just remove the tape. The auto power-off is a safety for keeping the tape from getting damaged.
Nov 18, 2007 | Canon ZR80 Mini DV Digital Camcorder
Nokia 6600 Logo
49 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
