Question about Ovens
Maytag magic chef model #cgr3760adw oven lights on broil but not on bake I went to sears parts and got schematic but dont understand how this can happen
  • 1 more comment
  • rkraft44 Mar 18, 2011
    Hi replaced the igniter in the oven. when you set the control to broil i get 120 vac at the igniter. when it is set to bake no voltage. There is no "broiler" the botom section is just a drawer. here is a schematic..
    Model #CGR3760ADW - MAGIC CHEF Range
  • rkraft44 Mar 20, 2011
    REPLACED THE IGNITER STILL DID NOT GLOW TRACED PROBLEM BACK TO GAS VALVE BROIL SIDE WORKS. WHEN IN BAKE VALVE SHOWS 120VAC VALVE IS BAD. THANKS FOR YOUR HELP THIS IS A UNUSUAL SYSTEM WHERE VALVE MUST WORK FOR IGNITER TO FUNCTION
    THANKS FOR THE HELP FOUND THE PROBLEM WITH THE VALVE
  • Ovens Master
  • 43,501 Answers
The ignitor for the broiler is different then the one for the oven....
Your ignitor is bad and needs to be replaced for the oven burner...
here is the part you need...
http://www.appliancepartsworldwide.com/Store_Part.aspx?Id=452340
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Mar 18, 2011
  • 4,323 Answers
Hi
The issue seems to be with the igniter switch that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Magic Chef oven displays F3 everytime the bake or broil button is pushed. Not sure what the model # is. Electrical range.
this could be a an open probe or shorted probe connection.you need to check your temp probe harness to your main board.
there is a chance that you need to replace your temp probe.
last thing would be to replace the EOC
Feb 12, 2010 | Magic Chef Ovens
Oven will not light. The ignitor glows orange but still will not light. Thanks.
without being able to take ampers on the ignitor, im gonna venture to bet it is the ignitor
i know it sounds silly but most of the time these units go bad long before the go black
if its not golowing almost white id bet again its the ignotor
they are very common parts
i reccomende
www.appliancepartspros.com
type in your model number
for your model bake and broil should be the same
in a pinch you could just use you broil one
hope this helps
Nov 01, 2009 | Magic Chef 9112 Gas Double Oven
I'm getting an error message F2 and the broiler will not turn off. It came on bt itself while the bake was on!
F2 on most jenn-air ranges/wall ovens indicates a fault in the oven sensor or relay board. I'd first check the sensor, (part # 12001655) it should ohm out at approx. 1100ohm @ room temp. If it is OK, it's probably a faulty "broil" relay and suggest replacing the power relay board.
The board (usually seperate from the clock and just behind it), on earlier model jenn-air/magic chef/norge/maytag etc. where known to burn up. part # VO4100260. double check those numbers with your model number at your local parts depot or service provider, those are just the most common for maytag built units.
hope that helps,
good luck
Oct 03, 2009 | Ovens
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Gas range won't work
Hi, Even tho the ignitor is glowing, it can be bad. It has to pull enough amps to open the gas valve. This is very common problem. I can get you the part and or prices if you could get me the model#
If I can help further, please let me know.
Thanks
Vic
May 15, 2009 | Magic Chef 9122 Gas Single Oven
Won't heat up
You have two ignitors one for bake and one for broil your bake is not working
Nov 09, 2008 | Maytag CWG3100A Gas Single Oven
Maytag "Magic Chef" electric double wall oven
check the high limit swtich. You need to remove the back of unit to find it. replaced it part# is:w10175596
Jan 02, 2008 | Maytag CWE5800A Electric Double Oven
Ovens Logo
834 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
