Question about Kenmore Refrigerators
I have a side by side refrigarator kenmore that every 3 weeks I have to shut off and defrost for several hours to get the frost off the coils. I even remove the panel on the back of the freezer that is covered with frost. How could I solve this problem? And is there a tray on the bottom of the refrigerator that I'm unaware of? I can't locate it if there is one. Thank you~
Call your ex to come look at it... ;-)
Posted on Sep 24, 2012
  • 531 Answers
SOURCE: defrost timer location on Kenmore model 106.56542400
carry control board part#2149705
Posted on Apr 06, 2009
  • 25 Answers
SOURCE: Freezer not freezing
your defrost timer or defrost heater could be bad,
Posted on May 21, 2009
  • 3 Answers
SOURCE: My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Posted on Jun 16, 2009
  • 245 Answers
SOURCE: Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Posted on Jun 26, 2009
woodchuck789
  • 4070 Answers
SOURCE: My Kenmore refrigerator coldspot #70192001 is not
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Oct 01, 2009
Kenmore Freezer 106.727581: The freezer ices up and the temp goes up to 34 degrees. If I manually defrost it, it goes to 5 below zero in about 6 hours. How can I determine which of the below need to be...
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater. To determine if the defrost heater is burned out, watch this part testing video
Aug 21, 2011 | Kenmore Freezers
Freezer is not freezing and refridgerator is not cold enough
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Sep 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Defrosting Problem
HI,
Did you try unpluging all the cords from back for 3 hours and then plug it back in.This is know as a hard reset.
Jun 13, 2008 | GE Monogram ZICS360NRRH C... Bottom...
Fridge works for about 3 weeks then freezer freezes up and fridge stops working i unplug it for 24 hours and it works for another 3 weeks same story??? what do i dooo? it is a ge side by side newer...
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts check if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Apr 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Kenmore Side by Side with the ice maker and water on the freezer door. I just hear water dripping and then running, and used a flashlight to look under it. There seems to be a driptray under the...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Feb 04, 2011 | Kenmore Refrigerators
I HAVE A KENMORE COLDSPOT 106.56542400 MODEL.THE REFRIGERATOR DOES NOT GET COLD AND BOTTOM FREEZOR SECTION FROSTS UP.IF I UNPLUG REFRIGERATOR FOR A DAY,EVERYTHING WORKS OK FOR ABOUT 2 WEEKS AND THEN...
We had the same thing and the problem was the frost sensor on the coils inside the freezer. It is behind the metal cover that gets all frosted up. When it works it senses frost on the coil and tells the control panel to activate the defrost wire which heats up the space melting any frost and then shuts off.
Our issue was the frost sensor but it could also be the heating element or the control panel. Anything in that little system.
Sep 21, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Model #596.58642890 Side by side refrigerator is not cooling. the compressor is running and the defrost timer works. How do I check the climate controls to see if they are working properly?
Hello. Thanks for choosing fixya! Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: 1. The defrost timer 2. The defrost thermostat (also called the bi-metal switch) 3. The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor.
Hope this helps, Regards, Joe
Nov 22, 2009 | Kenmore Refrigerators
Side by Side Kenmore Elite
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
  • The defrost timer
if this helps please vote me a fix ya
Jul 18, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Defrost thermostat connector
Where is the defrost heater? If it is below the problem area, I don't think it is a defrost problem. This sounds like low freon. The symptoms of this are heavy frost on only part of the coils. Try deforsting with a hair dryer and putting it back together. Wait about 3 hours and look again. If there is frost only on part of the coils that is bad. The most this unit could defrost is every 4 hours, most are on 8 or 12 hour cycles. On most units the defrost timer shuts off the compressor and gives current to the defrost heater/s through the defrost thermostat. This thermostat is closed below 15 degrees and opens at a much higher temp after sensing the heat. This shuts off the heat usually before the timer and lets the water drip down where it should go. Then the timer turns the compressor back on and removes current from the defrost system. A common defrost problem is if the doors are left open for a LONG time or not shut all the way. Sometimes it causes so much ice that it can't melt with just one defrost cycle. This problem builds as if air flow is restricted it causes even more frost and gets worse. If this ever happens , just find the defrost timer and turn it very slowly click by click just until the compressor stops. Let it defrost , then do it again in about 2 hours. If it is a low freon problem there may still be a partial warrenty left sometimes the sealed system is guarenteed ror 5 - 10 years. Sometimes if it is not covered it is not worth fixing.
Jul 04, 2008 | Refrigerators
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
