Question about Seagate Barracuda 7200.10 ST380815AS 80 GB SATA Hard Drive
I bought a 1T 7200 as a second drive. I was sold a sata cable only do i need a power cable also?
  • 51 Answers
All SATA drives need a signal cable and a power cable, but usually these cables already exist inside your computer waiting for you to use provided that your motherboard allows for an additional drive.
Posted on Mar 18, 2011
  • 356 Answers
It will depend on your computer's power supply and how many SATA devices you have currently versus how many SATA power plugs your power supply has.
Most power supplies have enough SATA power cables for adding an additional device.
Please leave feedback if this was helpful. Thanks.
MSI 760Gm-p23 version 3 Fx Desktop athlon II 640 cpu ,deskstar 500 gig 7200 3.5" sata II 16 MB cache hdd, mushkin 8 gig pc3-10600 essential ram, LG L49-8020 oem sata dvd rom post no issue but wont boo
make sure that the cables are right and are good make sure that the power cables are in the dvd and hard drive two cables to each one for board and one to power supply each
Mar 06, 2013 | MSI 760Gm-p23 Fx Desktop Motherboard Amd...
I think my Hard drive has firmware problems or a virus, i connected it to my computer and it wouldnt appear on the list of hard drives and devices on "my computer" how do i resolve the problem?...
Check power connector of hard disc is in correct socket. Check if there is 5V and 12V in power connector.Try to replace SATA cable of your hard drive. If your hard drive is still not appear on your computer try to determine if your motherboard is already installed the sata software of your motherboard.
Jul 13, 2011 | Samsung Spinpoint F1 HD102UJ 1TB 7200 RPM...
The hard disk not detect in my compter
Hi Good day!! try to re-plug the sata cable and power adaptor of your hard disk and see if it is detected if not try to replace the sata cable. please reply if you have a question i will help you more.
Thank you for using FixYa
Nov 09, 2010 | Seagate 25PK 160GB ST3160215AS SATA 7200...
How to connect between sata hdd to sata motherboard
You need a SATA "data" cable, and you need to connect one of the power-connectors from the power-supply to the power-socket on the disk-drive.
Oct 30, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have an asus motherboard. I bought a 1T sata hard drive. does this motherboard PTN-D support it
Hello
sata is the standard now,so your motherboard should support your drive.
Your part# does not match any asus numbers,im giving you a link to asus.
If this is an older mother board it may not support sata.Also you will see sata connections on the motherboard.
If you do not then its not supported.
http://usa.asus.com/ProductGroup2.aspx?PG_ID=mKyCKlQ4oSEtSu5m
Apr 12, 2010 | ASUS Computers & Internet
How to install a 2nd sata disk drive - do I need a 2nd sata cable?
Yes you need one SATA cable for each SATA device.
Biggest thing is to make sure that your motherboard has enough SATA ports available to accomidate another SATA device
Sep 27, 2009 | Western Digital Caviar SE WD1600AAJS 160...
Can I replace drive with a 500gb
Yes. Judging form the picture you bought the drive in the last year. Any SATA drive will work. I suggest tigerdirect.com . If you are doing video editing WDC WD3200BJKT-00F4T0 is a nice 7200 RPM drive. But, if doing HD video editing you should get a esata output card, run an esata cable directly to the external hard drive, and you will get a 3 gig transfer rate, which is quicker than the 400 megs a second firewire.
Jun 24, 2009 | Western Digital My Book (WDG1U2500)...
SATA HDD make SLAVE
IDE Cable with 3 connectors (you have 1 or need to buy 1) :
- blue: conn to motherboard
- black: conn to master HD
- grey: conn to slave HD
Cable (select:) cable will auto detect with most modern HD's from same type (SATA it was i think) and you need to go to you're BIOS, set up cable select for the HD's. Maybe best to set up master first, not both at same time. If you have a SATA and ATA set up the master first, then other. So if SATA is slafe but it in grey connector, otherwise black. For an ATA you might need a converter cable for the power, most motherboards don't have 1.
Oct 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I've just bought a 500GB hard drive seagate sata-II , and it doesn't come with the installation cables, or screws or even the intructions of how to install it. So I don't really konw what cables or things...
All you need is a SATA cable. Can be bought anywhere PC parts are sold or on eBay. You can use the screws from your old hard drive. The SATA drive will only work if your motherboard is current. Older M/Bs only accept IDE drives.
Apr 18, 2008 | Computers & Internet
SATA II HDD instaling on ASUS P5LD2
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed) http://uk.asus.com/products1.aspx?l1=3
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
Seagate Barracuda 7200.10 ST380815AS 80 GB SATA Hard Drive Logo
73 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
