Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
I get error message Unable to print 32 MFC-495CW. Please can you help
pineworks
  • 4041 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
SOURCE: Error message ''Unable to Print 4F''
How to repair error "print unable 4F" in the Brother dcp-135c .
thank alot.
Posted on Jan 14, 2009
eagle338
  • 4889 Answers
SOURCE: MFC-665CW "unable to print" 50 error
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment. You will need to turn off the printer and then push it back into slot to fix it. Let me know if you need more help. Sai.
Posted on Jun 11, 2009
komguy
  • 2306 Answers
SOURCE: Print unable 32 ?
Print unable 32 is dirt or scratch on the transfer belt assembly. There's a timing mark on the belt that a sensor must read. If the belt is damaged, you will need a new one.
Posted on Aug 07, 2009
  • 159 Answers
SOURCE: Have Brother MFC-495CW, and I recently changed
It's not your ink. Error 36 means either the printhead carriage is unable to travel back and forth properly, or it does, but the machine can't get the proper feedback from it. It might be an easy fix, once you get the top cover off the printer section. (Start by prying the narrow covers out of the main cover, then unplug the cables under those covers.) Often it's a small scrap of paper that got into the path of the head. If so, it's probably black with ink and hard to see, but fishing it out with tweezers should fix it.
The machine keeps track of where the head is by counting nearly-microscopic stripes in a quarter-inch strip of film that runs across the printer section. That strip should be oriented vertically and sitting in a slot in the head. If it's stretched up across the top of the head instead of down in the slot, the head can't see the stripes and panics, giving the error 36. Gently lift it and drop it into the slot. If it's smeared with ink, gently clean it with a wet cotton swab.
Posted on Apr 07, 2010
What is error 32
The message "Print Unable 32" or "Machine Error 32" will appear on the LCD display if paper or labels are stuck inside the printer or drum unit.
May 20, 2011 | Brother MFC-5890cn Color Flatbed...
I installed a new black ink cartridge(lc61bk) on a brother mfc-495cw and now nothing is printing.
Check out if you've installed it correctly. Also check out other ink cartridges, are they empty? If yes you won't be able to print anything. However, if all ink cartridges are OK then try to reset the printer or reinstall the drivers. You can find help in MFC 495cw users manual
Feb 27, 2011 | Brother MFC 490cw Color Inkjet...
Get Unable to print 32 error message. Can I fix this or does it require a tech?
http://www.youtube.com/watch?v=6Bob34TLrPQ&sns=em This YouTube video shows how to fix this problem with a small piece of tape!
Jan 03, 2011 | Brother MFC-665CW All-In-One InkJet...
Print unable 32 error message
Follow the below link to fix Print unable 32 error message on Brother MFC-9840CDW Laser Printer
http://tinyurl.com/print32
All the Best...
Dec 09, 2010 | Brother MFC-9840CDW Laser Printer
My brother mfc 495cw keeps giving an "unable to init." error message. chris.iya@lausd.net
Hi. my machine model MFC 495 CW. I did any step but my machine till show up unable to Init. 4 F. please can you help me about that. thanks you very much
Tien
Sep 07, 2010 | Brother MultiFunction Center MFC-440CN...
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Print unable 32 ?
Aug 06, 2009 | Brother MFC-9840CDW Laser Printer
thank alot.
Jan 06, 2009 | Brother MultiFunction Center MFC-440CN...
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
426 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
