I have a maytag peforma 2 speed 10 cycle top loader washer and rinse and spin cycle just stoped working but it work on delicate but still will nit drain or spin out i have cheked the door switch and the timer + motor but i still can see any thing wrong its drivin me crazy plezz help b4 it lands it the middle of my yard
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine BUT if it won't drain I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 18, 2011
GE GFWN1100LWW. Can the high speed spin work on the lower wash cycles?
From my experience, the lower wash cycles are set to only do certain things. For example: the Delicate won't do a high speed spin, even though a high speed spin wouldn't really be destructive to delicates, but would force more water out of them! I usually just run a "Drain/Spin" after the Delicate cycle.
Nov 27, 2015 | GE Washing Machines
Washer won't do spin mode
Repair Clinic solved the problem for free and I'll be buying the part from them. Thank you!!
Dec 30, 2009 | Washing Machines
Spin and rinse cycles won't work
spin and rinse cycles on most top loaders need to have the lid switch to be working properly. on front loaders the door latch needs to work if not the speed control board is at fault and needs to be replaced
Nov 05, 2009 | Kenmore Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Washer won't drain/rinse/spin
it may be a pressure switch fault. Remove the top cover (lid) and look for a round object with a small rubber pipe coming of it and a electrical connector with 2 or 3 wires, replace this part.
Apr 12, 2009 | Maytag MAH8700A Front Load Washer
Kenmore washer quit working
it may be waiting for a faulty heater to kick in. try it on a cold water wash, no heat and see if it continues the full wash. if it does not then it may have a faulty timer.
Mar 16, 2009 | Washing Machines
Maytag Top Loader won't work on Regular Cycle
I suspect bad motor windings. it has enough power to run delicate but not other cycles?
Nov 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
MAYTAG PREFORMA 2 SPEED 10 CYCLES 2004 TOP LOADER
Check your lid switch, some machines stay running when you add clothes when it agitates, but will shut off if you lift the lid in rinse and spin, lid switch may be broken.
Jul 15, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Service Mode
System Diagnostics
SERVICE MODE
The service mode provides service personnel the
ability to verify the operation of the washing machine.
The service mode can be entered in the middle of
any wash cycle. While in the service mode, the
servicer can start a variety of special service tests.
Accessing Service Mode:
Pressing down the delicates and heavy soil keys for
3 seconds places the machine in the service mode.
Motor speed will be displayed when started. To exit
Service Mode, press delicates and heavy soil keys
for 3 seconds again.
Troubleshooting
December 2004 4 16025861
©2004 Maytag Services
Stage of
Wash Cycle
Advances To
Presoak End of Presoak
Wash Every 5 Minutes of
Wash Time
Spin/Drain Every Step of The
Spin Profile
Rinse End of Rinse
Speed Range Displayed
a) 0-99 rpm 0-99 (actual)
b) 100-999 rpm Speed / 10
Quick Service Cycle
While in service mode, pressing the delicates key
will start a quick service cycle. This will be a quick
check of all systems.
The following steps will be followed.
1. Energize the cold and bleach water valves. Fill to
Low level, then turn bleach and cold off.
2. Energize the hot and fabric softener water valves. Fill
to high level, then turn all valves off.
3. Lock the door.
4. Tumble using 7/3 tumble pattern for 12 sec.
5. Turn the drain on.
6. Spin to 800 RPM using default rates.
7. End spin and coast down.
8. Unlock the door when the RPM is zero.
9. Display a ‘PA’ (Passed) on continuously for 10 seconds
if no diagnostic codes were logged during this
test.
The up arrow if pressed will advance to the next step.
The right most dot will be turned on as an indication
of failure and stay on until quick service cycle test
has reached the end. Any diagnostic code logged
during this test will result in failure of the test, but will
not necessarily stop the test. While in quick service
cycle, the pressing of the hand wash will suspend
the machine at this step for 30 minutes until the
Hand Wash key is pressed again. All LED’s will
flash on and off while the cycle is suspended, or on
hold.
Motor Drive System
To check the system, check the board for proper
output to the motor control. Performing a board
output test does this. Then perform the Motor
Control Board Output Test.
Motor Control Board Output Test
1. Disconnect power to the washer.
2. Remove the front panel and pull the JP4 Connector
from the motor control board.
The following Quick Spin test steps are as follows:
1) Lock the door.
2) Spin to 350 rpm and hold for 6 seconds.
3) Spin to 550 rpm and hold for 6 seconds.
4) Spin to 600 rpm and hold for 6 seconds.
5) Spin to 650 rpm and hold for 6 seconds.
6) Spin to 800 rpm and hold for 6 seconds.
If the Spin key is pressed again during the Quick Spin
test, the current speed will be held indefinitely. Pressing
the Spin key again will allow the quick test to
proceed as listed above.
When the washer is in the Service Mode, the speed
will be displayed as a two digit number or a letter/
number.
Quick Spin Test
While in service mode, the pressing of spin key shall
start the washer in the quick spin mode.
3. Reconnect the washer power cord to supply
voltage. Make sure the door is closed.
4. Press delicates and heavy soil keys for 3 seconds
to activate Service Mode.
Jan 23, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
