Question about Canon Office Equipment & Supplies
How to hook up a wireless printer to a computer
    Brigadier General:
  • 10,406 Answers
Does the printer also have some "wired" interface (parallel-port, or USB-port)?
If not, then you need to purchase a router with wireless capability:
1. Connect cable-modem (or DSL-modem) to the 'WAN' (or 'IInternet') port on the router.
2. Connect one of the 'LAN' ports on the router to the network-port on your computer.
3. Configure the wireless-adapter inside the router:
* set an SSID -- the "name" of your wireless network
* encryption-level -- use 'WPA' or 'WPA2'
* a password for your network
4. Configure the wireless printer to connect to that SSID, using the password
5. On the computer, click "Add Networked Printer"
6. Print a "test" page: computer -> wired -> router -> wireless -> printer
Posted on Mar 18, 2011
Canon PIXMA MG6320 works via USB but not wirelessly
first you must have a links sys.
go to your control panel on your computer and go to view network
status and task, there you can see if your are connected if not set up a new wireless connection.
Mar 05, 2014 | Canon PIXMA Office Equipment & Supplies
Hi, can you help? I am trying to hook up the
Since you changed from Wireless to USB I would recommend either reinstalling or selecting "add a printer" and allow the computer to automatically add the local printer.
Thanks,
Jun 07, 2010 | Brother HL-2070N Laser Printer
I recently purchased an acer computer that has windows vista. I have a hp2200dn laser jet printer and I want to hook it up by ether net into a wireless router. Unless this printer is wireless. I have a...
All you should need to do is connect the HP printer to your wireless router via Ethernet cable (which should be included with the printer). Follow the instructions that came with your printer to set it up on your computer.
May 13, 2010 | HP LaserJet 2200dn Printer
Can i hook my printer to this router Linksys wireless-g 2.4ghz
You want to connect a printer to the network.
If you have Ethernet port on the printer then you can connect it to the router with the ethernet cable. IF it is wireless printer then you will need to connect to the wireless network on the printer. In both the cases you will need to set up your printer as a network printer. If you contact the manufacturer of the printer they will tell you how to do it.
If you do not have ethernet port on the printer and it has only USB port and it is not a wireless printer then you will need a print server. You can purchase a wireless print server and you can set it up so that all the computers will be able to print onthe same printer.
If you have only the USB port and you don't want to use print server, then you can connect your printer to one of your computer. Enable File and printer sharing on all the computer. If you go to microsoft.com and search for file and printer sharing, you will get steps to enable file and printer sharing.
If you want to check the wireless settings of the router, you will need to open the set up page of the router .
Click here for more information about router and networks
Mar 21, 2010 | Linksys Wireless-G WRT54G Router
Wireless hook up
make sure you have a wireless network at your premises and that both computers are connected to the same network
Jan 17, 2010 | Brother MFC-5840CN All-In-One InkJet...
Hooking up wireless computer to printer
HP has a problem solving or troubleshooting software you can use. Also maybe your port settings changed. 168.06.01 is a typical port. Check that. Also use the WPS method to connect.
Apr 16, 2017 | HP Photosmart C5180 All-In-One InkJet...
How to hook up this printer wireless to my main computer
Hi jjank740;
First off, did you try to recycle your printer? Turn it off and back on again. Sometimes power outages can disconnect that printer. If that doesn't work. Go to the printer and access the system network configuration on the led panel. Type in the WEP number and password again, and let it search for the connection. That should do it. Once it's connected you'll see the blue wireless indicator turn on.
Good Luck
Mark
Please don't forget to leave a rating.
Feb 19, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Hooking a Linksys wireless router and SpeedStream router together
Connection should be from LAN port of Speedstream going to Internet port of Linksys router. That should be it.
Oct 25, 2008 | Computers & Internet
We cannot connect the pro l7680 printer wirelessly. Connect the printer to the router via ethernet cable and connect the desktop to the router wirelessly.
May 24, 2008 | HP Officejet Pro L7680 All-In-One Printer
238 people viewed this question
old marine
old marine
