Question about Kenmore 72602 Gas Dryer
I owe a Kenmore Gas Dryer- model #110.72062101 ( white colored) learned that my (Belt, Drive) Part # 3387610 has snapped and broke. My question is, which way I should appoarch this if I am planning to fix it myself? Can you give me any easy tips how to replace this? Thank you for your time! Tom
TheMobilian
  • 8220 Answers
SOURCE: kenmore gas dryer is not giving out heat
Check the fuse and control thermostat on the blower housing. They provide power to the gas assembly.
If all of that is good then check the flame sensor. If the flame sensor is open then no power will get to the then the common wire to the coils and ignitor will be open causing no heat. Read more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 19, 2009
jumptrout51
  • 3361 Answers
SOURCE: kenmore gas dryer model 97284100
The door latch is about $5. Replace it.
Any appliance parts store has them.
Posted on Mar 27, 2009
Fame_Guru
  • 483 Answers
SOURCE: How to get into the cabinet?
Kenmore dryer belt
  • UNPLUG DRYER
  • remove lint filter
  • remove two screws in lint filter panel securing cabinet lid to filter frame
  • with putty knife or other blunt blade, depress clips ~2inches in from the front corners of the lid to release cabinet lid
  • tilt lid up
  • remove 1 screw from each side 1/3 the way down
  • remove cabinet front and door
  • motor bearings tensioner are all visible
  • lift out drum forwards
  • check support rollers felts and nylon glide bearings for wear
    (worn bearing surfaces are the most common cause of belt breakage, and you dont want to do it again next month)
  • make sure tensioner is still installed in cabinet base, sometimes breaking belts pull them out
  • loop belt around drum at prior wear marks
  • reinsert drum
  • pull tensioner to end of travel against spring
  • loop belt around motor pully and tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off.
Thanks
Fame !
Posted on May 04, 2009
Ben-mrfixit
  • 68 Answers
SOURCE: Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
Posted on May 05, 2009
erpaalai
  • 999 Answers
SOURCE: I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Eric
Posted on Jan 24, 2010
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
This dryer won't start
there are thermostats that will pop if the dryer runs to hot,a dryer needs to be pulled apart at least once a year to be cleaned out,all it does is move air,if the vent line is blocked or lint builds up in the duct that the lint filter slides into the thermal fuse or high limit thermostat will pop as a safety,if you don't clean the dryer and vent line the new part will pop again.also the door switch could be broke or the belt could have snapped,some dryers have a safety switch,if the belt snaps the switch will open and the dryer won't start.so first thing you'll need a meter,unplug the dryer,remove the bottom panel,pull out the lint filter,remove the metal duct that the filter slides into,on the top of the blower wheel housing you'll see a white part,this is the thermal fuse,you have to remove at least one of the wires,check it with the meter,if you send the full model number i can look up your dryer,most likely the fuse will be a 3392519 thermal fuse,like i said if the fuse is bad you have to clean out the dryer and vent line or the fuse will pop again.and check the door switch,open the door,push the switch in and out if it makes a clicking sound most likely it's good.let me know what you find and send model number.
Sep 02, 2014 | Kenmore Elite 45986 Front Load Washer
Kenmore elite front load dryer has power but won't turn on. It beeps once like OT is going to start but nothing
check to see if the belt broke,there's a switch on the belt pulley on some models,if the belt snaps from to large a load the pulley doesn't have any tension on it and the switch opens so the dryer won't run.when you put the belt back on the pulley sets the switch so power will go tough it again and the dryer will run,also check the door switch,if someone shut the door to hard and broke the switch the dryer won't run.these are the easy things to check without needing a meter.hopeit helps,if you're in mass. and need a tech you can call peter de's appliance 781-438-9442 very good techs
Jan 26, 2014 | Kenmore Dryers
Dryer belt keeps breaking
Did you check the idler pulley to be sure it wasn't damaged in some way, like a break in the plastic wheel or metal causing it to cut away at the belt until it breaks
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 25, 2012 | Kenmore Dryers
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
I need to replace a dryer belt on a Kenmore gas dryer model number 110.73032102. The belt part number is 2925.
Not sure where you got that part number but the true part number for the belt on your dryer is 3387610
The service manual detailing the disassembly and repair of your dryer can be downloaded at link below. Be sure to unplug dryer before proceeding to disassemble::
http://www.mediafire.com/?5gmg0jyji4t
Nov 05, 2009 | Kenmore Dryers
A circular belt came out of the back of the dryer?
The drive belt broke. ou need to replace the drive belt. Remove the back panel and you will see a motor and a pulley, attach the new belt there and it will work just fine. Here is a website to get the belt that is right for your unit.
http://www.repairclinic.com/Kenmore-Dryer-Parts?s=a8b6
Feb 10, 2009 | Kenmore 63942 Dryer
Kenmore 72602 Gas Dryer Logo
64 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
