Question about Dirt Devil Easy Lite Quick Vacuum
Dirt devil doesn[t hold charge - Dirt Devil Easy Lite Quick Vacuum
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,001 Answers
  • USB quick charge 2.0 charger,you can get 75% power from empty in 30 minutes. It also charges your non-QC2.0 devices at up to 2.4 amps.ideal for travel use.
Chornic Quick Charger 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
Posted on Dec 16, 2016
    Sergeant:
    Champion:
  • 250 Answers
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Posted on Mar 18, 2011
M0944 charging circuit board diagram for dirt devil hand vac
Request the diagram directly from Dirt Devil.
Oct 17, 2017 | Dirt Devil Vacuums
Dirt devil easylite 7.2 v does not hold charge. Can you suggest any fix? Thanks
Sorry to say that the batteries seem to be worn out. Usually this is caused by using it for to short a time each time you use it. Batteries develop a 'memory' after several short time uses, and can only be charged the time it 'Thinks' is a full charge. You can try running it until it almost stops. Then let it sit for about an hour turned off, then turn it on again, and run it till it almost stops. After doing that put it on the charger for 8 hours. Then run it until it almost stops again. then charge it again. That process sometimes breaks the memory problem. If not, you need new batteries- or a new dirt devil.
Jul 02, 2017 | Dirt Devil Vacuums
Won't hold a charge
this is a problem that all cordless power tools that have an internal battery in them face eventually , the battery goes bad and without tearing it apart you cant replace them
make sure its the battery went bad , verify that charger is working and charge lite is on
Jul 22, 2015 | Dirt Devil 9.6V Gator Hand Vac, BD10085
Hand vac doesn't hold power
Mostly likely it needs a new power pack, but you could try cleaning off the contacts first. Use a pencil eraser and clean the metal power contact on the charging unit and the vacuum. Then charge it over night. If that doesn't help, charge the power pack.
Oct 15, 2014 | Dirt Devil Gator 18V Cordless Hand Vacuum...
Battery does not hold charge I have followed all directions.
Check power supply if there is any voltage coming out (LED indicator),check charging terminals for corrossion or dirt.If not,you need new battery.
Aug 22, 2011 | Dirt Devil M0914 Extreme Power Handheld...
Dirt Devil Easy Lite Quick Vacuum Logo
886 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
