Question about NEC PlasmaSync 61MP1 61 in. Television
61MP1 turns off after 5-10 minutes
When powered on, the monitor will display a picture for anywhere between 5-10 minutes before shutting off. After powering it off and unplugging it for 20 minutes the unit will work fine again. Emailed NEC and they said that it's possibly an overheating issue. Has anyone had similar issues?
  • Ryan Oct 03, 2008
    I was able to fix this issue after replacing some capacitors on one of the display boards. Found out that the board had been previously repaired and actually repaired with the WRONG parts. after putting the correct parts back on the tv, it has been working fine for a while now.
  • 3 Answers
Ryan
I have a 61MP1 that wont turn on. I get the green flashing light to signal power but nothing happens with the plasma. You seem to know a fair bit. A guy in UK said he'd supply a new power board for $500 but wants my old one in return. Sounds like it might be something I can fix here. Any suggestions. Barry
Posted on Jun 09, 2010
61mp1 nec plasma keeps shutting down after 5 minutes, when switch on picture ok
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 23, 2016 | NEC PlasmaSync 61MP1 61 in. Television
NEC plasmaSync 61mp1 problems
Here is the link for the user manual if you need it; http://www.necdisplay.com/Documents/UserManuals/PX-61XM1A_MAN_2ed.pdf Check page 54 of the manual (61 of the pdf) right at the bottom. The lights you have indicate that either the power supply citcuit, the screen, or one or more fans have been damaged. If you are sure all the fans work, then the power supply is the only repairable posssibility. replacing the screen is not worth it. The fact that the fuse blew but doesn't blow again makes me suspect one of the transformers or capacitors in the power supply has blown, causing the short that blew the fuse, but also then melted the short so it no longer blows the fuse. If you have a multimeter, and ideally an ESR meter, with a good photo of the power supply unit we can hopefully talk you through what to check - otherwise get a repair shop to look at the power supply. Hope this helps :)
Aug 31, 2007 | NEC PlasmaSync 61MP1 61 in. Television
Monitor displays half screen sometimes and goes back to full screen later. Some days you get the full screen but today it is half screen one time and then full screen another time. It finally quit...
The monitor have problem in vertical section of the board.Maybe the vertical output or any parts around the vertical ic is loose connection circuit,what we called,cold solder so its better to resolder the board at the vertical section.
Jul 11, 2011 | NEC PlasmaSync 61MP1 61 in. Television
Mx4000 128mb on xpsp3 problem
in windows power settings, you ajust the time the monitor runs and shuts down one setting is do you want the monitor to stop after 5,10 or so mins you answer never that will cure the shut down
Jul 06, 2010 | XFX GeForce MX4000, (64 MB) Graphic Card
Monitor starts, about three minutes no picture but
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | Proview PL926WBi 19" LCD Monitor
Tv shut off on its own
Replaing the lamp will fix this problem most of the time.If not count the blinks. This is an error code.
Apr 01, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
My gateway monitor shows a picture for about 1 second then turns to blacked out screen with power light still on. I can shut the power off on the monitor then turn it back on only to have it do the same...
Your power settings may need to be changed, it appears to be going into sleep mode or power saving mode.
If you are using Vista, Click Start> Control Panel > Power Options > "choose when to turn off display" (in the left hand pane) and check that it says at least 10 minutes. Click apply and then ok.
Alternatively, right click on your desktop, select "personalise" and click on screen saver - then select "change power settings" to bring you to the same thing.
If you have xp, right click on your desktop and select "properties" then "screensaver| > "Power" and change it to turn off the monitor after 10 minutes. Click apply then ok.
If your monitor is going to sleep, either press a key or wiggle the mouse to wake it up.
Hope that helps.
Nov 01, 2009 | Gateway HD2201 22" LCD Monitor
Guru
turn the power off to the monitor for 30 50 minutes buy the power point then back on let me know how that Geo's it should reset the monitor
Sep 10, 2008 | Proview Computers & Internet
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
NEC PlasmaSync 61MP1 61 in. Television Logo
249 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
