Question about Brother XR7700
I have a Brother XR7700 and the bobbin case keeps jumping over the stopper and the bobbin caseing turns all the way around and then my needles hits it and breaks but there is nothing wrong with my stopper, no broken parts or anything, is there something I need to adjust?
bbtoast
  • 319 Answers
SOURCE: bobbin case
Please see the authorized instruction manual here. Page 57 and 58 relate to your problem. If you need further help, please reply with updates!
Thanks
Posted on Feb 17, 2008
SOURCE: bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
Posted on Aug 07, 2008
SOURCE: Bobbin case keeps breaking after minimal use
Nope...it didn't work...I got the new case...and still keeps breaking needles...ready to throw the machine right out the window...3 floors up...I think they sent the wrong case...and on e-bay...another vendor wants 36.95 for a case...don't think it is worth this...only paid 150.00 for the machine at Walmart...personally...plastic parts are terrible...I still have a Singer from 1953...and it still sews like a charm...but just goes front and back...no frills...but the oldies are better!
Dee
Posted on Oct 07, 2008
Mimito7
  • 128 Answers
SOURCE: Needle hitting bobbin case and breaking off
It sounds like the machine is out of time.. However, it is not an easy fix at home.
Posted on Apr 19, 2009
SOURCE: Bobbin Case Spins - in Huskystar C20
I had this problem when I first bought my machine. I took it in and they told me it was a recall problem. All the machines were having the same problem. They fixed it and I have not had the problem since. I bought mine at a Joanne fabrics. Hope this helps.
Posted on May 28, 2009
Keep the thread from collecting on the arm that holds the bobbin case in? My Brother LB-6800 sews quilts, and embroiders great until yesterday, The thread wraps around this small arm every time now.
Try taking the bobbin case out and re-insert. It sounds like the case that holds the bobbin is not inserted correctly. You might also try checking to be sure that the needle is inserted properly. Sometimes the needle gets loose and drops down too low. unscrew, push the needle up as far as it will go, then tighten the screw.
Jan 24, 2015 | Brother LB-6800PRW Project Runway Limited...
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Brother CS-6000
I have a brother SE-400 and it sounds like the bobbin case is grinding.
I have a Brothers SE400..while free motion quilting, it sounds like the bobbin case is bouncing around. A lot of clanking noises. Does anyone know what I need to do to adjust this problem? It also seems like my stitches are very small and tight. I do see the top thread overlapping with my bobbin thread on the backing...what do I need to do to adjust this problem
Feb 10, 2011 | Brother XR7700
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
My needle keeps hitting the bobbin casing...have switched needles incase bent....have tried moving needle position..still hitting casing
Your timing is off. There should be a ruber belt behind your hand wheel, if you take off the case around it; you should be able to adjust your timing of the bobbin casing.
Jul 31, 2009 | Kenmore 15208 Mechanical Sewing Machine
Top thread keeps getting wrapped around bobbin case on LX-3125
You should hold the end of the thread coming through the needle until the thread has grasped the bobbin thread.
Jun 30, 2009 | Sewing Machines
Bernina 180 Bobbin case spinning
Its called the bobbin stopper. Pop off your needle plate by pressing on the marked corner. In the back on the left you will see a small allen screw which must have come loose. Position the bobbin stopper in place and tighten that screw. If it already is tight, loosen it and reposition the bobbin stopper in the notch and tighten it back up.
Good luck.
Oct 04, 2008 | Bernina Artista 180
Brother XR7700 Logo
76 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
