Question about Toshiba TDP-T45U DLP Projector
Good Eve., I have a Toshiba Projector TDP-T45, there is a glass between Lamp and the Lens and it is broken. I can not see color also the image is blured. Is the glass pn# is 23125963 ? What should I do, to not getting the blured image? Thanks, Bob
  • Toshiba Master
  • 17,130 Answers
For sure the broken glass bring about the blurringg image as the LCD image is not being projected with clarity.
You will need to use gloves to carefully remove the broken glass, remove then without damaging of the lens and the lamp.
Reset with the correct type.
Posted on Mar 18, 2011
The picture is still there but there is no color
The color wheel has probably been damaged or broken. Remove the lamp and look into the round aluminum housing. There should be a colored round glass wheel covering about 2/3 of the opening. If not there, you'll notice glass pieces on the bottom of the case. The part number is Toshiba MOTOR PJ TB30 CW 23125963 ~ $160. It is tricky to replace, so if your not used to working on electronic equipment, you would have to take it in for service. If the wheel is in place, It could also be a main board voltage problem. Good luck.
Aug 11, 2010 | Toshiba TDP-T45U DLP Projector
Toshiba TDP-T45 projector, groups of vertical lines across entire screen. Someone said try setup frequency to someone else with same problem but that person said it didn't work, then someone said replace...
the tube referred to is the light tunnel. which in your case is not the problem. unfortunately the only thing you can do is give it a good slap on the top 3 inches behind the lens for an unlikely long term fix, or try reseating the main board to the light engine. if neither work then the main board or the light engine is bad.
Aug 07, 2010 | Toshiba TDP-T45U DLP Projector
I have a toshiba tdp-t45 and a Dell D600 how do I get the image from the computer to display from the projector?
Connect the toshiba tdp-t45 to the back of the D600 and then hold down FN and tap F8. This will transfer the video to the tdp-t45. If this does not work for the first time try the Fn and F8 keys 2 - 3 times.
Rate if useful.
Aug 11, 2009 | Dell X2033 - Latitude D600 D500 Inspiron...
The color went out on my Toshiba TDP-T45 projector. Watching the projector and heard sound and the color went away. What is wrong?
Color wheel failed. Clean the glass pieces out loose in the unit and replace the color wheel assy with Toshiba part no: 23125963. No soldering is required, just a no. 2 phillips screwdriver and and a set of jeweler's phillips screwdrivers like Radio Shack has.
Apr 23, 2009 | Toshiba TDP-T45U DLP Projector
How to change toshiba TDP-S35 lens
i got a problem with my projector, the colored break up into pieces, i want to know if how much is the price to repair it.
Mar 19, 2009 | Toshiba TDP-S35 DLP Projector
I heard a pop and now the projector only shows black and white.
The color wheel has failed in youtr projector. There are 4 pieces of glass in the color wheel which fit togeter in a "pie" formation and they are red, blue, yellow & clear. This wheel is spun by a motor. The glass is glued to the motor's hub, and, when it fails the glass segments are thown off the hub. This gives you a B&W picture because all of the light is allowed to shine through the optics all of the time. Replace the color wheel with Toshiba part no: 23125963. It will be about $65. No soldering is involved, just use care with the ribbon cable to the motor. You will need a no. 2 phillips screwdriver and a set of jeweles screwdrivers to do this.
Nov 25, 2008 | Toshiba TDP-T45U DLP Projector
Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Dec 09, 2007 | Toshiba TDP-S8 Multimedia Projector
Toshiba projector TDP-T30
i have the same one but it needs a new lamp i will buy one of your lamps off of you let me know a price
Nov 12, 2007 | Toshiba TDP-T30U Multimedia Projector
Toshiba TDP-T45U DLP Projector Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
