Question about Nikon LS 2000 Film Scanner
Nikon scanner was unable to find active device
    Problem Solver:
  • 6 Answers
That problem usually occurs when the ASPI Layer driver has not been installed, or when scanner operation is attempted on a 64-bit OS.
Posted on Mar 24, 2013
5 Suggested Answers
  • 48 Answers
SOURCE: dell laptop wont recognize ls2000 scanner
The LS-2000 is a "legacy" device to XP and the Nikon software. It needs to be connected to a true SCSI bus adapter, and it's actually pretty finicky about which ones will work in XP. Sorry, you won't be able to use this with your laptop.
Posted on Mar 21, 2009
SOURCE: Nikon scan was unsable to find any active device
I may have a solution for the unrecognized film holder/clunking problem.  The fix is not for the faint of heart, but you can do it yourself and save a bunch of money.  The problem lies in the two rails inside the scanner that the film carrier rides on.  After unplugging you scanner, remove the 8 screws from the rear of the unit and slide the cover rearward about 3/4" and then lift it straight off.  Inside you will see two shiny machined rods running from front to back.  The problem is those two rods have dried up lubricant on them and the film carrier drags a bit during film carrier insertion and/or scans.  The easiest way I found to clean the rods is to remove the front cover (look for screws inside on each side), and then carefully slide those rods out (but NOT all the way) and wipe off what is exposed and then apply a little silicone lubricant to the rods (be very careful to not get any down into the lens area).  Then slide the rods back in and repeat for the portion that is exposed in the rear.  Carefully re-assemble everything and you should be all set.  This fix worked for me on an 8000ED that I purchased used on eBay.  Hope this helps someone.  Brian
Posted on Mar 22, 2009
  • 48 Answers
SOURCE: nikon scan was unable to find any active devices
The LS2000 is older than XP and has some fairly tight requirements to work. The recommended SCSI adapter is an Adaptec 2906, and you will probably need to backrev the ASPI layer driver files to version 4.7 (available on adaptec.com site). You may need to boot in Safe Mode to remove the later versions of the ASPI files before you can install the 4.7 files. You will also need to update your Nikon Scan software to version 3.1.2, available online by googling "nikon scan 3.1.2".
Posted on Apr 04, 2009
Coolscan 3 and Windows XP
Try a good scanner program called vuescan. Much better than Nikon software. I have been using on XP for a long time and no problems
Mar 25, 2009 | Nikon Coolscan III Film Scanner
Nikon scan was unable to find any active devices
Mar 22, 2009 | Nikon LS 2000 Film Scanner
Dell laptop wont recognize ls2000 scanner
Feb 28, 2009 | Nikon LS 2000 Film Scanner
Nikon Coolscan 9000 ED can not be recognized by computer
I am having the exact same problem...cannot get the Coolscan 9000 to show up in Device Manager. One thing I did try (to no avail) was to run the regsweeper.exe file that comes with the Nikon scan disk. It clears your registry when you reinstall. It still did not work though so I have a lovely "shoebox" sitting next to my computer that is worthless!
Dec 08, 2008 | Office Equipment & Supplies
Nov 24, 2008 | Nikon Super Coolscan 8000 ED Film Scanner
Nikon Coolscan 9000 not recognized by XP computer anymore....
I read and would like to thank, the person who mentioned this as a solution. It was stated that if you have more than one firewire on your computer, when you open the Nikon, both signals, or whatever happens in computerland, don't connect. Upon removing the drive in the other firewire, Nikon clicks in everytime. Answer: have only ONE active firewire at a time. You may need to unplug the cable to the scanner and reconnect. But that's it. I've not had any problems since
Jun 09, 2008 | Nikon CoolScan 9000 ED Film Scanner
NIKON SCAN IV ED
connect after PC start up
May 29, 2008 | Nikon Coolscan IV ED Film Scanner
Nikon Scan doesn't recognize scanner
I have the same problem (on XP, Nikon Scan 3.1.2) ... IF I turn the scanner on before the computer (or turn the scanner on and then reboot) then Nikon Scan recognizes it. Can't say I'm happy with the solution, but it works consistently for me.
Apr 18, 2008 | Nikon LS 2000 Film Scanner
Nikon LS 2000 Film Scanner Logo
114 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
David Darrow
Level 1 Expert
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
