I connected my LG 22LD350 to my hard drive, and both the sound and picture work, after I selected "RGB-PC" on the monitor. But I don't see a connection anywhere on the TV for my keyboard and mouse. The owner's manual doesn't address that in any way.
  • Computers & ... Master
  • 5,159 Answers
You connect the keyboard and mouse to the computer, not to the TV. If you are connecting your TV to the CPU (which the RGB-PC (VGA) input suggests you are using), keep the keyboard and mouse connected to the computer. If you have removed them from the computer, then reconnect them to the appropriate ports of your desktop (or laptop if you use an external keyboard and mouse instead of the touchpad and regular keyboard).
If you are connecting an external hard drive to the TV's USB service port, follow the directions for the firmware update from the LG site. (I do not know of any updates for the LG 22LD350.)
If you have a remote/keyboard like the Logitech Revue with Google TV, consult that manual.
I hope this helps.
(This TV does not have a USB hub but there are some monitors with USB hubs built in to the monitor. These are obvious. You will have a set of USB A ports and one USB B port for the connection to the computer. Keystrokes and mouse clicks will only have an affect on the computer if you change the input source.)
Posted on Mar 18, 2011
    Genius:
  • 1,189 Answers
Hi bpollen,
you will use the computer for {GUI} Graphics User Interface!
The TV is a "secondary visual device, or monitor"
The TV "cannot give instructions or commands."
"You not be able to "tranfer information from the TV.
You will use the "Computer for [Input and Output] transmissions.
The "Keyboard and Mouse" stay 'connected to the computer!"
You will "control all functions for the TV; by using the computer."
"I hope this information solved some issues?"
!"Take a moment to rate the help."
Thank you! paul7of9
LG HDTV Monitor Permenantly switched on but no display white screen with V.2.0.0 moving around the screen
sounds like you are possibly over resolution (setting resolution higher than the monitor can show. Try setting to low resolution and see if it shows up. Try VGA first and move up if it shows.
Jun 21, 2014 | LG Flatron N1910lzbf 19 Led Lcd Monitor 43...
Ibm thinkpad wont connect to LG TV
Lower the screen resolution to 720 dpi.
Another issue is the reference to RGB. Is it the 3 cable (YPBPR) or the standard 15 pin VGA? You may need a converter.
Oct 08, 2012 | IBM ThinkPad T40p 2373 Notebook
Connecting Samsung T27A300 to laptop
did you go into the t.v. setup and it should list pc. there you click on it or just click on tv in put and select hdmi port 1 or select the rgb selection. one of those will work
May 26, 2012 | Samsung T27a300 27" Class Led Hdtv And...
Trying to hook my home PC into my LG TV gets me the message Invalid Format, what can I do to get the signal or can i use this tv for my monitor with a dell PC
Connect VGA (D-sub 15 pin) cable from PC to TV (RGB PC) input jack. Connect audio cable from PC to TV. Set screen resolution on PC to be compatible with TV, such as 800 X 600 or 1024 X 768 etc. Select on the TV, the PC INPUT using the TV remote when ready to use as monitor.
Under PICTURE on the TV select SCREEN (RGB-PC). You can AUTO-CONFIG or you can set resolution manually to the same you set PC to. Other adjustments can be done here as well to get optimum picture on TV from PC.
Mar 01, 2011 | LG 26LG30 26 in. LCD TV
Hello. i have problem with my monitor. when I plug it into my computer monitor doesnt working have only white screen with moving words "v3.08.0" and i dont know what to do. its monitor tv ...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
or if this fail to fix the problem
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
don
Feb 18, 2011 | LG Computers & Internet
So my brand new LG 22LD350 will not play games from the Nintendo Wii's Virtual Console. It just goes black and says "Invalid Format." Anybody know how to fix this?
The tv firmware must be updated,this prcess are problemmatic,might work might not.New tv take it back and exchanged it for another tv.
Feb 14, 2011 | LG 22LD350 22 in. TV
When I turn on my PC Windows starts fir 4 seconds then I see on flat monitor LG "Analog Power Saving Mode" and LG monitor goes off (yellow light on monitor panel). Please help.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to fail to detect a hard drive continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 11, 2010 | LG Computers & Internet
I'm trying to view my monitor on my LG 32" using the RGB port but can't get it working? I've connected the monitor cable to RGB port, selected the RGB menu in Imput and keep getting "NO...
I too am having the same problem. It works fine on my Samsung TV but no signal on my32lG60. If you find anything let me know. Larry mebehe.Larry@gmail.com
Dec 01, 2010 | LG 32LG30 32 in. LCD HDTV
I Just connect My pc via 15 pin RGB cable to LG 32R50xx lcd tv,it show the picture but no sound. Than i connect the audio cable to the tv use 3.5mm j. it only has sound when I use input and select AV3 but...
You probably need a audio cable that runs from the pc audio out to the TV audio in. Radio shack has them so do a lot of hardware store and best buy.
Aug 08, 2009 | LG 42LG30 42 in. LCD HDTV
Connecting to pc
in the menu screen you will see RGB DTV Highlight that setting and use the right arrow on the remote and you will come across RGB PC. Make sure that is selected and " back out " of the menus. Enjoy
Aug 30, 2006 | LG 42PX5D 42 in. Plasma HDTV
Computers & Internet Logo
442 people viewed this question
David Payne
David Payne
