Question about Targus USB Ultra Mini Keypad Keyboard PAUK10U
My Tarsus Keypad works fine on my on local laptop(Lenovo Thinkpad, Windows 7) However, when I use VPN and Remote Desktop to get to my desktop computer at work(Windows XP) the keypad only does the lower case functions(down and up arrow etc.) not the numbers) The numbers only work when I hold the button down and then it displays the numbers multiple times. Do you know what might be the problem ?
Not to be smart, but the same thing was happening to me and I realized the Num Lock needs to be activated on the keypad AND on your laptop. I did not have it activated on my laptop and I was realizing the same problems.
Posted on Mar 20, 2011
Copy windows 7 and apps to Parallels desktop
First you create bootable windows disk, and then you try it. Bootable Disk insert to DVD rom drive and follow instruction on setup.
More info please visit this link.
http://www.lgsolutions.com/ftgsoftware/downloads/Windows_XP_Installation_Guide.pdf
Thanks,
Apple Support
May 30, 2014 | Apple MacBook Pro Mac Desktop
What is turned off on my keyboard to cause my Lenovo Idea Pad P500 with 8.1 to stop working when I wy-fi out on VPN to a remote site, while my Dell works fine.
you have to have your wirless going or a conecion first to internet for a VPN to work,,, start with your internet conection then your wireless connection. if they are fine and you still can't connect 1. vpn softare is corrupt. 2. setting in vpn on your laptop got changed 3. turn your caps off , for singing into vpn 4. unlock your keyboard number pad there really isn't much ona keyboard.
May 14, 2014 | Lenovo Computers & Internet
Sharp aquos lenovo sl410 hdmi cable
I would look for a newer driver from lenovo. Has 8.1 got a fix?
Jan 19, 2014 | Lenovo ThinkPad SL Series SL410 (2842F7U)...
How can I use my second monitor on the iMac via VPN/RDP?
Hi Jessiejeh55,
It sounds like you are using the Microsoft Remote Desktop Connection client for Mac.
  1. Open Remote Desktop Connection
  2. Select the connection you wish to use with both displays
  3. Right-click and choose Edit
  4. Check the "Use all monitors" box at the bottom
Thanks
Aug 01, 2012 | Apple 24" iMac Desktop
I'm having trouble with Age of
Hello just curious did you pirate the game it could be corrupt if not try this, set your task bar to classic and right click on the short cut to the game on your desktop, bare with me i am using linux, look through the tabs and there should be an option to run in windows 98 compatible mode or something then try it, i hope this sorts the problem out.
Jul 16, 2011 | IBM Lenovo ThinkPad R60 Notebook
Is there any software by which i can work on my computer when i am away from my home ?
Hello,you can work with your pc even away from it without a software.. In Windows, Remote Desktop allows you to access your computer from a remote location. To enable Remote Desktop, you must have administrative rights on the computer you want to use as the host (i.e., the computer to which you will connect from a remote location), which must be running one of the following versions of Windows: Windows 7 Professional, Enterprise, or Ultimate Windows Vista Business, Enterprise, or Ultimate Windows XP Professional The Remote Desktop Connection client software (for the computer from which you want to connect) is installed by default on all computers running Windows 7, Vista, or XP. Enable the Remote Desktop feature on your host computer From the Start menu, select Control Panel (or Settings, and then Control Panel). Double-click System. In Windows 7 and Vista, click Remote settings. In the "Remote Desktop" section, select one of the two options to allow connections from other computers. In Windows XP, select the Remote tab. Select Allow users to connect remotely to this computer. To choose which users will have remote access, in 7 and Vista, click Select Users... or in XP, click Select Remote Users... . Typically, all administrators of the computer will have access by default. Each user must have a password before you can allow remote access. When you are finished, click OK. Your computer will now be able to accept incoming Remote Desktop connections. Open a connection If you have configured your computer to accept remote connections, to establish a Remote Desktop connection: Depending upon your network configuration and system requirements, you may first have to establish a VPN connection to your host computer's network. From the Start menu, select Programs or All Programs. Select Accessories, and then Remote Desktop Connection. In the space next to "Computer:", type the name or IP address for your host computer. Click Connect. Note: If you would like to adjust any of your connection settings such as screen size, login information, availability of local hard drives and printers, or keyboard and sound behavior, click Options before clicking Connect. In the Log On to Windows dialog box, type your username, password, and domain (if required). Click OK. Once you are connected, you can use your remote computer as if you were sitting in front of it. When you are finished, in the Remote Desktop Connection window, select Start, then Shut Down. In the Shut Down Windows dialog box, from the drop-down menu, select Log Off username, where username is your username on the remote computer. Click OK. goodluck!don't forget to rate,thanks'''''****
Feb 21, 2011 | ViewSonic VG2230WM LCD Monitor
SIte to site vpn/remote desktop
Open up the vpn client any any of the working machine, and then
click on
file>>save Prfoile>>give a name
Take a copy of that and paste it in your machine.
On your machine install the vpn client (Straight Forward Installation). Then
Click on Import Profile , Identify the location where you have pasted the profile (Which is copied from other machine).
You are done with that.
Mar 13, 2009 | Cisco PIX 501 Firewall
VPN connects Remote desktop will not
Make sure that the firewall doe's nt block tcp traffic on port 3389.
Hope this help.
Usually all the traffic should be allowed thru the tunnel.
Sep 03, 2008 | Computers & Internet
Targus USB Ultra Mini Keypad Keyboard PAUK10U Logo
326 people viewed this question
Top Targus Computers & Internet Experts
J John
Laxman Bisht
Laxman Bisht
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
