Question about Digipower Canon BP-808 Battery BP-CN808
I use the charger for a cannon bp 808 battery pack, the light on the charger turns green indicating that it is charged after awhile. problem is once i load the battery its saying that battery the battery needs to changed and it seems like it never was charged. however the battery runs like it was charged
SOURCE: H700 no change
sounds as if you all have defective units
Posted on Jan 15, 2008
marked
  • 6487 Answers
SOURCE: My battery charger shows (green) fully charged when it is dead
THis is really a sign of a bad battery that is always being detected fully charge but its really drian , so it will be better for you to replace that battery.....
Posted on Dec 01, 2008
  • 60 Answers
SOURCE: peg perego 12v charger question
The green light means it is ready to use. If the battery is bad though, the light will still be green.
Posted on Mar 11, 2009
gewiz
  • 1271 Answers
SOURCE: Scooter batteries will not charge. Green light on
ok, this could be a dodgy connection with the batteries or the charger is at fault ?
1. try another charger
2. check the batteries if possible on another scooter.
3. check the connection on the battery and the charge socket connector.
Regards
GeWiz.
Posted on Oct 01, 2009
SOURCE: Canon FS 200 battery pack communication problem warning-BP 808 ba
You may want toget a battery that "New Canon BP-808 Equivalent Li-Ion Rechargeable Battery. Rated with 900mAh, the battery is made with info-chip, which can show remaining time on camcorder LCD. It also can be charged by Canon original charger and camcorder. It works wonderfully for and is 100% compatible with:
Posted on Apr 10, 2010
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
Jan 23, 2016 | Ryobi Garden
Do I have to take the batteries off the charger after they turn green?
No. Green light indicates that the battery is fully charged. You shouldn't take it out.
Gopakumar Gopalan Google
Apr 16, 2014 | Motorola Wpln4171ar Rapid Battery Charger
Green and red light comes on when i put battery in charger what does that mean?
Here is the manual:
http://toolboyworld.com/eBay/Ryobi_P120/P120_566_eng.pdf
Red = quick charge
yellow = evaluating
green = charged
If battery pack is within normal temperature range, the red LED on charger will come on.
Red LED should remain on for approximately 1 hour then the green LED will come on. Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode.
Feb 14, 2010 | Ryobi Multi-Volt Battery Charger
Feb 13, 2010 | Canon FS200 Flash Media Camcorder
Green & Yellow light on 14.4V charger
It sounds like your battery is bad.
replaced.
Nov 24, 2009 | Ryobi Multi-Volt Battery Charger
Both green and yellow light stay on and batteries will not charge 18v
replaced.
Oct 19, 2009 | Ryobi Multi-Volt Battery Charger
How to charge the battery?
You should have a battery charger for the battery pack. The charger has an indicator. While charging, the light is in red. Once the battery if full, the led indicator will turn green.
Oct 03, 2009 | Nikon Coolpix S550 Digital Camera
What does the charge plus+ light and the green light mean together
replaced.
Jul 11, 2009 | Ryobi Multi-Volt Battery Charger
Battery pack or charger
Hi!
When you insert the battery , plug the power into the charger and the light turns ON (red or green) - the charger is OK. One indication that the battery is dead is when you charge it, after just a few minutes the full charge indicator will turn ON ( with Canon chargers the light for full charge is green). If that's the case, purchasing a new battery is the only option.
Have a nice day!
Oct 02, 2008 | Canon PowerShot SD600 Digital Camera
Digipower Canon BP-808 Battery BP-CN808 Logo
Top Digipower Cameras Experts
Saleem Baig
Saleem Baig
Arthur Cowgill
Level 1 Expert
Are you a Digipower Camera Expert? Answer questions, earn points and help others
