Hello
Unplug your Mitsubishi DLP TV and position the unit so you can easily access the back
Locate and remove the screws for the back panel. Do not remove the entire back of the TV but the lower panel only. The screws will be located in the edge of the panel.
Locate the projection box in the center of your DLP TV. The projection box will have a series of wires coming out of it and be attached to the speaker housing with four screws
Remove the four screws holding the projection box in place and slide the projection box out. It will not come all the way out but will slide out like a drawer. Disconnect the electrical wires at the projection box by pulling the connectors apart. You should now be able to see the projector lens itself.
Facing the back of the DLP TV, the lamp box is on the right side of the projector lens. Pull the lamp box to the right and it will slide away from the projector lens
Grab the top of the lamp box firmly and pull it out of its spring holding clips. Replace it with your new lamp box by pressing the new box into place in the same manner as the old one. Finish the job by reconnecting and installing everything you opened or removed
