Question about Maytag MAV7700 Top Load Washer
I have a MAV7700AWW model machine that has developed a leak when in use, and it makes a thump noise when the spin cycle stops.
  • 641 Answers
SOURCE: Washer makes loud thumping after finished spin cycle
Remove washer cabinet (easy to remove)and check that "base pads" (there are 3 pads, located under the main tub)are not worn. In case they are worn (even one of them), you should replce them all. Good luck !!
Posted on Jun 07, 2006
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
jsrock516
  • 5911 Answers
SOURCE: MAYTAG Wahing machine model MAV6000AWQ
I believe your machine is equipped with a "snubber plate" under the transmission. A lot of Maytag top-loaders are. This is a white teflon ring that is used as the wash tub and transmission support and assists in dampening vibrations during the spin cycles. It's located on the inside case of the machine under your transmission. When the snubber goes bad they generally start to squeak. They cannot be lubricated and must be replaced. If you try to oil them, they will eventually disintegrate. The snubber costs less than $10 to purchase. I hope this helps.
Posted on Apr 29, 2007
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
SOURCE: Noise at end of spin cycle
No question in my mind that it is the drive block.  Just replaced mine.  Spin tube "ears" had some how chewed up the keys on the drive block and the tub would not stop when the braking system was engaged.  This resulted in the tub spinning (along with it's drive block) over the spin tube "ears", making the thumbing noise.
Posted on Oct 13, 2007
GLEH1642DS1 FRONT LOAD STACKABLE WASHER MAKING LOUD THUMPING NOISE IN SPIN CYCLE & SQEALS WHEN i STOP IT
Sounds like you have an unbalanced load. I know this sounds too easy but lots of times this is the issue. If it doesn't help then you could have a bearing issue where the belt goes around a pully under the tub itself. If so you will have to replace the pully itself and perhaps the belt if it's gotten worn too much.
Nov 15, 2013 | Washing Machines
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Makes loud noise when on spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 09, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Loud thumping while stopping after spin cycle.
make sure the shiping rod is out it will do that if it,s not out
May 29, 2009 | Kenmore 22422 Top Load Washer
Rattling noise during spin cycle
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Kenmore 110-91564100 Top Load Washer Problem
Sounds like my 91 Geo Merto LOL! Anywho when it washes the pump spins one way and water is basically thrown back into the tub, then when on spin it spins in the opposite direction and if there is a hose leak past the pump or the pump itself leaks it will come out of the drain system. As for the thump, check under the unit for anything that shouldnt be under there getting caught up in the mechanics. Let us know :-)
Sep 14, 2007 | Kenmore 23822 Top Load Washer
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
