Question about Smeg Dishwashers
We have had difficulties with our older SMEG dishwasher model no. PL 672 EB. The timer would stick on one position indefinitely and my wife would have to manually turn the knob to advance the cycle to the end. I ordered a new timer (being located far outside the city - virtually no service out here) and have installed it. I disassembled the old timer and found some stripped gears explaining the failure. Problem: the new timer also seems to have stopped mid cycle. Started at 7 AM on normal cycle and setting the rotary switch to 2, the unit was still running with hot soapy water at 10 AM with the rotary switch at 4 where it would normally stop. The operating book is not very helpful saying nothing about how long cycles should run. I need some suggestions to help troubleshoot. I am a retired engineer, and so can speak the language of a maintenance technician. Any assistance would be most welcome.
3 Suggested Answers
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
SOURCE: Problem with ASKO 1385 dishwasher. Unit has
Hi Richard, it seems like I have the same problem as you did. How do you go about fixing this? Can it be done on your own, or do you have to call someone in? Thanks
Posted on Jun 14, 2010
The timer .how do u use it
Turn it to start and lock the door.
Jan 09, 2014 | Smeg Dishwashers
Smeg pl 512 manual
Here is the site for smeg usa, you should be able to locate a manual for your appliance there. You will need to double check the model number of your appliance.
http://www.smegusa.com/user-manuals/
Dec 17, 2013 | Smeg Dishwashers
Re: SMEG Integrated Dishwasher ST663. I'm having
usually a screw on the striker (the bit sticking out that goes into the door) it will be a slotted adjustment so just loosen (not remove) the screw and pull it out a mm or 2.
retighten and test.
Also, clean the seal. While your at it, the sump filters and spray arms.
Oct 18, 2013 | Dishwashers
Smeg ST660 not starting
Switch the power off. Remove the 'built-in cupboard' panel from the front of the dishwasher and you should see the end of the timer spindle. With the power off you can turn this clockwise using another appliance knob or carefully with pliers. I think one 'start' position is with the flat section below the centre and horizontal. If the two lights are not on then try the 'start' button second from left to advance the timer.
Jan 13, 2010 | Smeg Dishwashers
Smeg integrated dishwasher continually washing - won't move to drying cycle.
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Nov 02, 2009 | Smeg STA4645U 18" Fully Integrated...
Kenmore Dishwasher 587.15163401 knob stuck mid-cycle
See if it is stuck on a water heat cycle. if the heater circuit or the thermostat is not working properly it will continue to run looking for a rise in temperature. If these are in working order the timer it self could be sticking and not advancing.
Eric
Oct 23, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
My SMEG Dishwasher is not cleaning my dishes, I put the wash on and it cleans it but when I come to take the dishes out they are still dirty
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
75osrha
Oct 12, 2009 | Smeg 24 in. DWF612WH Free-standing...
Smeg oven SA 392 EB - technical difficulties
first of all the yellow/orange light glowing is a known fault. it needs a slight wiring modification to fix it, however it dose not affect the operation of the oven nor is it dangerous.
now to the heating problem, there is a round element at the rear witch surrounds the fan. is this element getting hot? if not then it most likely needs replacing. it could be the thermostat but more likely the element.
Mar 05, 2008 | Ovens
Dishwashers Logo
50 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
