Question about As Seen On TV Clapper Plus
I have the clapper plus with the remote control. and i had 2 lights plugged into them. however, after 2 weeks the clapper stopped working. i believe that a fuse might have been blown; when i plug in only only light that is 120 watts it does not work, the 2 of the 3 red lights on the front light up when i clap twice, but then the middle of the 3 lights just lights up on it's own and the light that i plugged in does not go on. also the orange lights on the bottom do not light up at all!!! PLEASEE HELPPP MEE! ASAP!
3 Suggested Answers
SOURCE: Does not work
open it up. Insert an ear plug into the hole for the Mic. I got mine to respond to the distinct claps and not be confused by the noise caused by women's shoes forexample... The Radio control works by HOLDING the button for 1 sec not more. Test it with any LAMP.
Posted on Jan 14, 2009
SOURCE: clapper goes off every few minutes with no stimulus to do so
While in the Away setting, the clapper will turn on when it detects any noise over a specific threshold. After ten minutes of inactivity, it will turn off. This setting is meant as way turn on the lights as soon as you walk in the door or to startle might be intruders. If you slide the switch to Lo or Hi mode, the clapper will respond to your claps or any loud noises that sound similar. Hi is high sensitivity, for quieter rooms; Lo is low sensitivity, for louder areas.
Posted on Apr 01, 2009
I plugged a heating system into my clapper and now it is not working. The lights on the clapper don't go on when I clap. I think it glitches out but don't know how to fix it and now I'm really upset. What...
Clappers are only designed to manage less than 500 watts. Heaters are typically much more...greater than 900 watts. You likely burned it out and will need to send it in for replacement. good luck
Feb 01, 2015 | Miscellaneous
How do I turn on without the remote control
If you have a switched outlet you can plug it into that and operate it with the wall switch. There are also many products like the "clapper" out there that work great as well.
May 18, 2014 | Dryers
When LED lights are plugged in and the clapper is off - some of the lights still glow - not as bright as when on, but still appears as if power is seeping to them (just a little). Help - really wanted to...
There's nothing wrong with your Clapper. LED's have very low current draw - under that which is required by the Clapper to function. You can add a small nightlight to your lights which will up the draw for the Clapper to work properly.
Dec 18, 2010 | As Seen On TV Clapper Plus
My Clapper Plus works fine, except that when it is off, some current still leaks through. I have Christmas tree lights plugged into it. When the Clapper Plus is off, the lights are dim, but are still on.
You obviously have a faulty Clapper. They are supposed to work just like a switch...ON or OFF. If you are getting dim lights, it is bad. Take it back where you got it or call the company.
Thanks for using Fixya.
Wayne
Dec 11, 2010 | As Seen On TV Clapper Plus
While playing any game on Wii Sport Resort: my 2 controllers seem to be synced ok, I re-synced several times. Both controllers work fine at menu levels. But after choosing a game, number 2 controller...
I had this problem and it was down to be, me plugging the motion plus into the wrong controller.
I have one control with intergrated motion plus and the other uses a plug on motion plus. I accidently plugged the plug on one into the already intergrated control leaving the one control with nothing. Hence that control could not be recognised.
Hope this helps
Dec 06, 2010 | Nintendo Wii Remote Controller
I have a Hunter Ceiling Fan Model # 23529. The remote control works for the fan but not the light; ;I believe I need to replace the Remote Control Receiver 85112-04-000. Can you please tell me where I...
The receiver part #8511204000 and runs like $50 plus shipping....if its the remote the replacement part# 23529-300 and it runs like $40 plus shipping. You can order it from Hunter or other Hunter dealers.
Aug 26, 2010 | Hunter Ceiling Fan Light Remote Control
Direct TV RC64 Remote ''Up'' button stopped working.
Sounds like the box. try to reset the box and hopefully it will solve the problem.
Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
Clapper goes off every few minutes with no stimulus to do so
Jan 27, 2009 | As Seen On TV Clapper Plus
Does not work
Dec 27, 2008 | As Seen On TV Clapper Plus
Clapper plus
Sliding the switch down to the HOME (LO) position will put the Clapper Plus into the low sensitivity mode. This is helpful if there is a lot of external noise in the room. By placing the switch in the HOME (HI) position it will put the Clapper Plus into the high sensitivity mode for quiet clappers or if you are far away from the Clapper. In the AWAY mode appliances will turn on with the detection of any sound but will only stay on for 10 minutes.
Dec 06, 2008 | As Seen On TV Clapper Plus
As Seen On TV Clapper Plus Logo
206 people viewed this question
Top As Seen On TV Toys Experts
ray gallant
Are you an As Seen On TV Toy Expert? Answer questions, earn points and help others
