Question about Casio FX-9750GPlus Calculator
Casio fx-9750gII looking for factorial function (x!)
    New Friend:
  • 15 Answers
Press Option, F6, F3, F1 to find the "!"
Posted on Mar 18, 2011
Testimonial: "Thank you very much I finally found it after searching and searching through the manual!"
  • Anonymous Jan 07, 2016
    Thank you so much, just spent 20 mins watching BS youtube videos and no one explained on a fx-9750GII calculator, only the TI-83 one :). Made my day!
2 Suggested Answers
  • 7993 Answers
SOURCE: How to find zeros of
First you can use the Solver found under the EQUA menu.
You can also graph the function, then use the G-Solve feature.
See the sequence of screen captures below.
Press Menu then Graph to open the Y= editor.
Type in the expression (without the =0 part) and
Press the F6: DRAW tab.
While the graph is being displayed press the F5:G-Solve key.
In Gsolve screen press F1: root.
The calculator hopefully finds a root (here at the left)
Press the right arrow to find the root at the right.
I will not guarantee that it will always be this easy.
Posted on Aug 16, 2011
How are factorials represented and calculated?
Factorial Calculator "A factorial is a function that multiplies a number by every number below it. For example 5!= 5*4*3*2*1=120. The function is used, among other things, to find the number of way "N" objects can be arranged."
Oct 13, 2015 | Casio FX-9750GII Graphing Calculator
I do not know what a range is and where to find it on a Casio FX 9750GII Calculator
In statistics, the range of 1-var a data set is the difference between the largest value and the smallest. R=Xmax-Xmin
In functions: the range of a function is the interval (or the Union of intervals) of the real line where the dependent variable takes it values.
Ex: sin(x). Whatever the value of the independent variable x, the values of the function sin(x) are in the closed interval [-1,1]. The range of the functions sin(x), and cos(x) is [-1,1].
No use of a calculator for finding the range of functions.
Feb 04, 2014 | Casio Calculator Graphing FX 9750GII...
How do I graph sinx on my Casio fx-9750GII calculator?
Turn calculator ON
If you see no icons, press Menu
Press 3 (Graph) draw your function. (more on that later).
If the first line of the display show Graph Func : Y= you should be able to draw your function.
If it says anything else, press F3 TYPE to select the graph type and select functional by pressing F1 key Y=.
After the graph type is set to Y=, type the second member of your function y= f(x) on the first line. Make sure the = sign after Y1= remains highlighted after you move cursor. Otherwise select the function by pressing F1:SEL. Press F6 Draw.
Be careful with trigonometric functions. If angle unit is radian, set window Zoom to standard. If angle unit is degree, you must open the Window utility and set Xmin=-190, Xmax = 190 to see at least a period.
Feb 21, 2013 | Casio CE CASI FX-9750GII-L-IH GRAPHING...
I can't find the matrix button on my fx-9750GII
In the Run>Mat screen there is a tab at the bottom left of the screen. If you press F1 it opens the tab and shows you other tabs for the matrix functions.
Nov 14, 2012 | Casio FX9750GII Graphic Calculator
My Casio fx-9750GII wont dispay a table
The message dimension error usually refers to instances where two lists do not have the same dimensions (number of elements)
I checked and the calculator gives condition error. Check the type of function you are creating a table for. Choose the type y=
Nov 05, 2012 | Casio Calculator Graphing FX 9750GII...
Where is the math button on the casio fx-9750G11
It is a calculator and prqactically every button is a MATH button. It depends on what MATH you intend to do. Put the calculator in Run/Mat screen then press the OPTN key. You will see several tabs. Press the function key under a TAB and explore what is offered. Go through all the keys (F6 also) and see what the new tabs do.
In general it is most helpful to read the manual that shipped with the calculator.
Oct 16, 2012 | Casio Calculator Graphing FX 9750GII...
How do i graph piecewise functions on the fx-9750GII
You must graph each part as a whole function and just pay attention to the one section in the bounds that it is active for. There is no way to only graph part of a function.
Sep 13, 2011 | Casio FX-9750GPlus Calculator
I have a Casio fx-9750GII, how do i switch my radians to degress?
From the Run Mode (select it and press exe), enter Setup (Shift Menu) and then highlight Angle. Press the function key that correponds to Deg and then press Exit.
The manual for the Casio Fx-9750GII is here: http://support.casio.com/manualfile.php?rgn=1&cid=004002013 . Other calculator manuals are here: http://support.casio.com/manuallist.php?rgn=1&cid=004 .
I hope this helps.
Jan 19, 2011 | Casio FX-9750GPlus Calculator
How do i use the fx-300es to graph
Sorry but you cannot do that. This is not a graphing calculator. However you can generate a table of values for your function (MODE TABLE) and use it to graph the curve by hand (pencil and paper).
If you need a Casio graphing calculator, one of the cheaper ones is the Casio FX-9750GII. Equivalent Texas Instruments calculators are the TI83PLUS/TI84PLUS.
Aug 31, 2010 | Casio fx-300ES Calculator
Casio FX-9750GPlus Calculator Logo
10,631 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
