Question about Kenmore Dishwashers
My kenmore dishwasher has no power. all lights on control panel are out. we have power to the power cord.
  • 77 Answers
Check to see if your dishwasher has power going to it. If you confirm the power supply is good you likely have a bad fuse. Go to the link if you want to download a video so that you can see how to access and replace the fuse.
Appliance Repair
Appliance Parts
Posted on Mar 18, 2011
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
My dishwasher wont start after the power outage. all the lights are working fuse box is checked also.
please follow this steps and fix it. God bless you
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer or Control Electronic
Replace if defective (note: uncommon problem).
4. Selector switch
Jul 30, 2013 | Kenmore 24 in. 15689 Built-in Dishwasher
Will not turn on
2. Door switch
3. Timer
4. Selector switch
Read more: http://www.appliancepartspros.com/repair-help/dishwasher-repair-help.html#1#ixzz2YZQClslt
Jul 09, 2013 | Kenmore 15899 Built-in Dishwasher
Kenmore 66517514202 dishwasher has no power dead no lights nothing
Does the wiring come up through the door at the bottom to the control panel? Check for a broken wire
May 21, 2012 | Kenmore Dishwashers
Error 1 on kenwood dishwasher
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 05, 2011 | Kenwood KDW243A Builtin Dishwasher
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher seems to not be getting any power and no lights are lighting up. It is still plugged in and I already tried resetting breaker. Any suggestions?
HI. Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
If everything checks out ok with the above suggestion, the main control sector(timer or control board), will be the culprit.
The control sector must be replaced, in this case.
Dec 11, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore dishwasher no power
Check the following areas for faults.
2. Door switch
3. Timer or control board
4. Selector switch
Jun 14, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwashers Logo
185 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
