Question about EuroTech 24 in. EDW194E Built-in Dishwasher
Dishwasher will not run. I press On. The little window lights upp with P4 flashing. I press AO Then I press the farthest button on the right and the minutes show up. I shut the door and turn on the faucet. If the minute shows 54, the washer starts up for about 5 seconds then stops. If I open the door, the minutes go down in number and unless 54 is showing nothing will work. The washer also keeps beeping.
2 Suggested Answers
Rotu
  • 175 Answers
SOURCE: Pump in tank wouldn't turn on
Sounds like you've already figured ti out. The pumps on these fail regularly. I would bet youve got a bad one. If you want to know for sure, check for 110 volts across the two wires at the pump when it is running and supposed to be draining. If voltage is there, but no pump run, order a pump and you'll be back in buisness. Good luck!
Posted on Jul 18, 2007
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Runs for a few minutes then stops and the program and top right light flash, if i press the power button off then on it runs again for a while then stops again with the flashing lights.
The electronic portion of the dishwasher is going bad. Could be a resister or any other issue..I would check with the manufacture Tech support they will advise you what your options are.
Mar 27, 2012 | Zanussi Dishwashers
Dishwasher will not turn on, clean light is flashing
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Mar 05, 2011 | KitchenAid Dishwashers
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Dishwasher (Whirlpool ADP 952) not working
I have a whirlpool ADP 952 and the start button is flashing and it won't work
May 25, 2009 | Dishwashers
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore ultra wash dishwasher control lock light flashing
Just press the 'Air Dry' button for 5-6 seconds....I have an ancient Kenmore Dishwasher (ULTRA)
Oct 02, 2008 | Kenmore 15899 Built-in Dishwasher
Error code. F14.
Check the motor circulation impeller, if you not maintain the unit is gonna be clog by impeller. it need to be clean.
Jan 11, 2008 | Miele Premier-Plus Built-in Dishwasher
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
EuroTech 24 in. EDW194E Built-in Dishwasher Logo
59 people viewed this question
Top EuroTech Dishwashers Experts
Tony Houde
Tony Houde
Tom Chichester
Dave Glabb
Are you an EuroTech Dishwasher Expert? Answer questions, earn points and help others
