Question about Toshiba Satellite 1415-S173 Notebook
Toshiba Satellite 1415 CD/DVD Rom Drive
I up-graded my OS to Windows XP Pro, Now my CD/dvd does not read or write on the drive. I wanted to reinstall the original software and even on boot up the system does not read from the drive. I have already changed the boot sequence in the bios to read from the CD. NO luck here
Drivers de red
Posted on Aug 13, 2008
Drivers de red
Blu-ray won't play
If your Toshiba Satellite Pro isn't reading your DVD-ROM, it means that the DVD-ROM of your computer has been disabled. If your DVD-ROM drive has accidentally been disabled, enabling the DVD-ROM drive is quite a simple task to complete, even for individuals who have little to no experience working with computers.
Click on the "Start" menu and then "Control Panel." Click on "System and Maintenance" in the control panel. Click on "System." Click on the "Hardware" tab and then click "Device Manager." Click on the CD/DVD-ROM drive option and click on it so that it is highlighted. Right-click on the CD/DVD-ROM drive option, and then click "Properties." Click "Enable" in the properties menu and then click "OK." Restart your computer by clicking "Start" and then "Restart." Once your computer has booted, your Toshiba Satellite Pro DVD-ROM drive will be enabled. if still no joy
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it Hope this helps.
Jan 24, 2013 | Toshiba Satellite M645 S4114 I5 2.66ghz...
Which drive on my satellite A 100 is the dvd or cd drive?
Your Drive : CD-RW/DVD-ROM COMBO DRIVE
This CD-RW/DVD-ROM drive is designed to read DVD-ROM discs as well as CD-ROM, CD-R, DVD-RAM discs
Oct 10, 2012 | Toshiba Satellite A100-S8111TD Notebook
How do you reinstall Windows XP on an Toshiba Satellite A60 PC Notebook?
1. boot your PC or laptop from the Windows XP CD (To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer).
2. You will see "Press any key to boot from CD" displayed on the screen, at this point press any key to start the computer from the Windows XP CD.
3. You will see the Welcome to Setup screen, press ENTER to start Windows XP Setup.
4. Read and agree to the Microsoft Software License Terms, and then press F8.
5. Follow the instructions to select and format the c: partition where you want to reinstall Windows XP.
6. Follow the remander of the instructions on the screen to complete Windows XP Setup
7. Reinstall any drivers which are required.
8. Reinstall any software programs which you need.
9. copy your data back to the drive.
Jan 07, 2010 | Toshiba Satellite A60 Notebook
Drivers for Toshiba satellite A75-S226
here ya go
http://www.officialdrivers.net/toshiba-drivers.php?gclid=CJip5OKvpJsCFQ4MDQodWCAtCg
Jun 25, 2009 | Toshiba Satellite A75-S226 Notebook
Toshiba Satellite A200-1M4 When I start my laptop i can hear a long peep sound and my DVD ROM auto opening. My DVD ROM PC detect but It can not read the CD always showing inset the CD. Please help me in...
dvd burners or rom drive have 2 lens inside, one for DVD read, the other for cd read. I see it often where one fails out in the drive but the other works. With one working fine and the other not, I would replace the drive. If still under warranty send it to manufacturer. If not do a search on Ebay for a replacement drive, or get a local laptop repair shop to do it for you.
May 11, 2009 | Toshiba Satellite A200-16J01D Notebook
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    Toshiba Satellite 1415-S173 Notebook Logo
    145 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
