Question about Sony Handycam HDR-XR520 High Definition Camcorder
There is a continual mark that appears on all playback of video and pictures. Lens and playback screens both have no marks or scratches. Mark appears slightly lower on pic playback. Which leads me to believe there is a fault within the lens itself as there is a reduction in screen size between video and pictures. The mark is at the top of the screen left of center and is best described as a slight darkening in a semi circular shape that is approx 6mm across on the camera screen.
    Sergeant:
  • 162 Answers
Do you find the same thing happen when you connect to regular tv. or is this all the time no matter where you view the picture.
Posted on Mar 18, 2011
How to fix canon 5D mark 2 error #30?
On the 5D error code 30 appears to be shutter related and general advice is to get a professional repair or send it back to Canon.
Aug 04, 2014 | Canon EOS 5D Mark II Digital Camera with...
One yellow, one pink, and one blue spots appeared on my tv screen.
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Dec 23, 2012 | Mitsubishi WS-55315 55" Rear Projection...
My s8000 has got a problem with it.there is no scratch visible. but still a black dot mark is appearing on the fotos.when the zoom is increased,the size of the dot mark decreases. i've cleaned the lens...
This is not something that you can clean from the outside. It is probably on an inside element of the lens, close to the CCD. I would send it back under guarantee, along with some prints of photos showing the mark.
Dec 02, 2010 | Nikon Cameras
5D-Mark II screen flashes with reflecting objects
No. It's simply a menu setting to show you where potentially overexposed highlights in the final image will be. The function can be set to show shadows or highlights.
I don't currently have a manual to hand, but if you can't find how to turn it off in your own manual then report back and I'll have a thorough rummage for one.
May 25, 2010 | Canon EOS 5D Mark II Digital Camera with...
Error 99 on screen cant take picture intermitant
Error 99 is known as Abnormal Mirror operation. Follow the link for help;EOS-1D Mark III/EOS-1Ds Mark III: AF Accuracy Adjustment
EOS-1D Mark III/EOS-1Ds Mark III: Abnormal Mirror Operation (Err 99)
It should be noted that the AF accuracy adjustment advisory is in addition to the previous EOS-1D Mark III AF mirror adjustment service notice. Free repairs are being offered for customers affected by the "Err 99" mirror problem, and Canon is also providing free AF accuracy checks and adjustments for customers experiencing problems with soft focus when using any but the central AF point.
Finally, Canon Japan has published a new manual entitled "EOS-1D Mark III AI Servo Auto Focus Manual" aimed at helping owners understand and get the most from their AF system.
Jan 01, 2010 | Canon Cameras
Burn mark on pictures
Bad CCD imager, Most likely unless you repair yourself with a parts camera not worth repairing.
Jul 01, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Can't copy pictures from sd to frame
Follow these steps, Selecting all:
1. Press whenever pictures/videos are displayed (slide show, video, single picture). 2. Press to highlight Select all, then press OK. A confirmation screen appears, then your picture display reappears. A check mark is displayed on all pictures/videos in your current location. 3. To remove all check marks, press , highlight Select / Unselect all and press OK. 4. Highlight Unselect all and press OK. A confirmation screen appears, then your picture display reappears. All check marks are removed. Also, you may download the user's guide at www.kodak.com/go/manuals
Jan 22, 2009 | Kodak EasyShare SV811 (8858946) Digital...
My lens has marks on it will this affect the picture?
The cobweb marks are either
1. adhesive between elements failing
or
2. Fungal growth inside the lens barrel.
As to usability-
It is surprising what one can away with glass damage - scratches and the like
All you can do is to try it and see
Dec 08, 2007 | Nikon D70s Digital Camera
DVD player stops frequently during playback
Yes first try to clean the laser with a lens cleaner. If that does not work you can then try to take off the cover and clean off the lens manually with a slightly damp cotton swab and alcohol. After that turn around the swab and dry the lens with the dry side of the swab. If that doesnt work then it Probably is out of alighnment or the spindle motor is bad, and is most likly not worth the bench charge for an estimate.
Sep 27, 2006 | Panasonic SC-HT900 System
When i turn the camera to take a photo, no image appears in the LCD or the eyepiece. this just happened all the sudden. I am able to view pictures that I've already taken in the LCD and the LCD will also...
there may be two reasons for this problem. 1. may be a defective or broken CCD. 2. the shutter is not working may be due to broken flex circuit cable. in any of the case you have to get it fixed from a professional camera repairer
Aug 02, 2006 | Fuji FinePix S5000 Digital Camera
Sony Handycam HDR-XR520 High Definition Camcorder Logo
53 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
