Question about Dell Latitude E4300 Notebook
When I turned my computer on this morning it said that it could not recognise the power cable and gave a number of options: reset power cable F1 to continue F2 I believe was reconfigure computer to attached power cord and there were a couple of other options I unplugged the computer so it was running off its battery and hit F1. Now it gets to the Guardian Edge smiley man screen asking you to press CTRL ALT DEL to get to logon screen. Pressing these keys does nothing. I have rebooted the computer and it gets to the same point although now gives no errors about the power cord.
Eddie333
  • 176 Answers
SOURCE: Latitude D600 beeps twice
Sounds like you have a video card problem.
To run the Dell diagnostics perform the following steps:
  1. Shutdown the computer.
  2. Press and hold the <Fn> key (next to the <Ctrl> key), then press and release the power button.
    Release the <Fn> key when:
    • The keyboard lock symbol lights begin to flash AND/OR
    • In the upper left corner of the screen shows Diagnostic boot selected
  3. The diagnostics testing automatically begins.
    It may take a few minutes before any alert tones are heard.
  4. Watch the screen for images such as the Dell logo, progress bars,or lines of text and/or listen for beep tones that sound similar toMorse code.
  5. If the screen does show an image, write down the codes that appearon the screen. If the screen does not show an image, write down thebeep tones that you are hearing.
    • Before going further, please click the link to listen to an example of a beep code. Sample Beep Code
    • The beep codes will begin with a quick series of high pitched beep tones, then a pause, then 3 sets of beep codes.
      Write down the 3 sets of beep codes that you hear.
    • If an error code is recieved, scroll back to the top to "Choose an option"and choose "A beep code is heard or an error code is seen. The beep code is not 3-3-3 or 3-3-4."
    • If there is no error code, continue with step 7.
  6. After approximately 2 minutes the system produces a single alert tone and should display colored bars with the prompt Were color bars displayed? (y/n).
    The alert tone is repeated 6 times, once every five seconds for 30 seconds, then the second test automatically begins.
    Press the <N> key on the keyboard to skip the timeout and immediately start the second test.
Posted on Jan 04, 2009
Geekman
  • 32281 Answers
SOURCE: A disk read error occurred. the comp. said press ctrl+alt+del
The computer cannot find the operating system, the disk error message means it cannot find the hard disk, you most likely have a faulty hard disk or less likely a faulty disk controller.
You can test the hard disk by removing it and connecting it to a USB hard drive adapter and plug it into a working computer's USB port. If this computer cannot detect this drive as an external drive then you will know your hard drive is faulty ad you need to buy a new one and install Windows and programs etc..
Posted on Jan 25, 2009
rasengan79
  • 138 Answers
SOURCE: windows XP won't load - black screen
Refresh all the connection on your motherboard like ATX power supply, HDD and CD/DVD ROM cables, and specially the RAM. You may have to clean the RAM as shown in the image below. c4d62f6.jpg
then hopefully your computer will return to normal. Hope this helps.
Posted on Sep 24, 2009
  • 979 Answers
SOURCE: cant reboot
Good day sir/maam, the reson why it froze is caused by a bad memory module, you may need to replace it. Open up your computer and locate the memory modules, remove all memory modules and bring it to a computer vendor for testing. or if you have the cash, better buy a new one. make sure that what you install on your PC be it tested or new is good.
Posted on Sep 28, 2009
  • 235 Answers
SOURCE: cant get 4600i started. powers up but will not get
you need to go to cmos or bios setup, set all the date and time and proper boot setting there save and exit, it is a cmos or bios failure that causes these problems try replacing the cmos battery if the message still continues
Posted on Nov 22, 2009
Pc cant recognise keyboard and mouse it says press any key or press f1 for setup
Try another mouse or keyboard. If symptoms persists, reset the motherboard by:
1. turning it off. 2. unplugging it from the power outlet. 3. open the side panel (check your manual on how to do it.) 4. once the panel is opened, locate the coincell battery from the motherboard and remove it. you can use a pen to remove the battery. 5. let the computer boot without the batt. -6. turn it back off then reinsert the battery.
Apr 13, 2011 | AMD Computers & Internet
RESETING THE PHONE CODE
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Apr 08, 2011 | Samsung Cell Phones
Your chassis has been opened. Press F1 to continue How to clear warning
hi
press f1
then go to pc health on bios, chassi option press enter key .choos e reset the press f10 save yes
Feb 22, 2011 | Acer Veriton M661 PC Desktop
New Cartridge recognisation problem
Hi there not know if it will work so you go to come back to let us know pleas.
Also if you are using the Refillable ink cartilages stop they always cause major issues
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off)
then turn it on again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Apr 03, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Many issues, ie, Everything is flashing!
Hi there
yOU CAN ONLY TRY.
button pressing
Mar 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Saying it doesnt recognise my ink cartridge but they have not been changed since last printed and were fine before...
Hi
Try this it may work but Please come back let us know how you got on.
and holding
move into a
Stop/Reset button 4 times, the specified number of
alternately in
orange and green, starting with orange.)note: press 4
button pressing
5) Turn off the printer.( it must be turn off)
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Feb 06, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Hi, Im having problem booting my COMPAQ PCs
hi , your first machine needs a hard drive disc error check performed (C drive/properties/tool/error check and tick the 2 boxes ).
the second machine needs the bios battery replaced .
hope this helps
Jan 22, 2010 | HP Compaq EVO D5S PC Desktop
Dell Dimension E520 has "NO BOOT DEVICE AVAILABLE" message. Pressing F1 F2 doesn't help. What should I do?
Shutdown the system and disconnect the power cable.Disconnect external peripherials.Hold the power button for 10 secs to drain static power.connect the power cable to the computer.turn on the computer and hit the F2 key to boot in bios.If you are in the bios turn on the caps lock,scroll lock, and numlock key.then Hold the Alt key + E, then Alt key + F, Alt key + B. Computer will restart check for hdd or boot device.If hdd is detected it should boot to desktop.If issue persist .Shut down the system.disconnect power cable.Hold power button for 10 secs.Open the tower and disconnect the hdd from the sata or ide cable.Connect hdd in a different sata or ide connector.Connect power cable and turn on the computer and follow steps 1.If still getting same error possible hdd gone bad.Good Luck.
Sep 03, 2009 | Dell Dimension 8400 PC Desktop
No signal on startup
if monitor is gave no siganl .Firstaly Check monitor Signal Cable For connected of ur system vga port. if Siganal cable is connected ur pc then Check ur System IF system is gave the Display anthore monitor . Then Proble is ur monitor signal Cable .So Plz Change Monitor Signale Cable.
Dec 29, 2007 | Princeton Digital VL2018W Monitor
Freecom 160GB Hard drive not recognised
Drives do fail Nick. Is it powering up [power supply problem?] Plug it in and go to Start/Control Panel/Admin tools/computer management/storage/ removable storage and disk management. See if the disc is recognised there. If it is not, and if the disk is spinning Try putting it into the deep freeze overnight. Plugging in next morning and if it fires up get as much off as possible before it goes down again.
May 20, 2007 | Freecom (24358) 160 GB Network Hard Drive
Dell Latitude E4300 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
