Question about Frigidaire Washing Machines
E20 message code no water comes in just hums ? Please help
    Brigadier General:
  • 6,277 Answers
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Posted on Mar 18, 2011
Electrolux washer ewf1084 error code e20
Hello - Error code "E20" typically indicates that the water is not draining properly or not pumping out fast enough. Is the washer making a humming noise? If so, either the drain hose may be kinked or the household drain is clogged. Otherwise the unit can be experiencing more serious issues, like a faulty pump or Main Control Board. If I was in your position, I will personally consult a certified technician for a proper diagnosis and to move forward accurately.
Feb 19, 2013 | Washing Machines
Error code E20
Hello igor_lyub - Typically error code E20 means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Jan 12, 2013 | Frigidaire ATF6000ES Front Load Washer
What does the error message E20 on the frigidaire front load washer GLTF2940FS mean?
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
My machine had been giving E20 error code - cleaned out filter and pressed start button and it started again ok. During wash it jammed and all lights went on (except spin speeds) and it wouldn't...
E20 is a general error code to get to the real problem try this.. Reading ErrorCodes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
Machine had been giving E20 error code - filter cleared and it re-started ok. When wash was in progress - jammed at rinse stage and all lights came on (except spin speeds) and humming noise and nothing...
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa
Washer did not spin out message E20 appeared on panel. Attempts to start just humming noise.
is the humming comming from the motror trying to run or is it just a humming sound if the machine has washed correctly upto that point then check water pump for faults and or blockage machine will not advance if water trapped in machine the humming sound could be the water pump either free spinning indicating a blockage or humming as it is trying to run indicating a faulty pump
NEVER OPEN MACHINE CASE WHILST STILL CONNECTED TO MAIN POWER SUPPLY
Jan 17, 2010 | Frigidaire ATF6000ES Front Load Washer
Water won't drain, error message: E20
error code E20 means that the coin trap/drain pump hose needs cleaned out.It can be done by the owner with a friend helping.
1. Unplug the unit.
2. Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure the unit is propped up safely.Or you can lay the unit on its back side.
3. Now that the unit is propped up look inside the hole on the bottom of the unit - on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
4. Clean the drum out with as much water as possible and have towels ready. The next step you will have the remaining water come out.
5. At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
5. Reach inside the coin trap and clean what is inside of it out.
6. Put the unit back together following the same steps backwards
Of course, if your washer is setting on top a drawer/pedestal then you will need to take out the screws that connect the two and then you can lay the washer down on its back onto the pedestal
Jan 16, 2010 | Frigidaire Affinity ATF7000E Front Load...
Code E20
my cloths will wash but will not spin out the drum stop turning when it comes to the spin cycle makes a humming noise
Mar 30, 2009 | Frigidaire GLTF2940ES Front Load Washer
Error message on washing machine E20
E20 is "A problem with water draining"
Solutions:
The drain hose may be squashed or kinked
the drain pump may be blocked
or possible your filter is totally blocked. Clean out the filter everything will work again. Put a large bowl under the filter as you unscrew it; a fair amount of water could be there.
Good luck.Please rate the solution if accepted, also do post comments in case of any doubts.
Jan 23, 2009 | Zanussi Washing Machines
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
