Question about Alpine IMPRINT Audio Processor - PXAH100
Hi I have a Alpine W900 ans I just install the imprint pxa-h100. I have two amps with one sub. After tuning I can barely hear the sub ? Do you if I have the select 3 way or 2 way ? Let me know
Check Sub Setting, could be turned of.
Posted on Aug 21, 2011
  • eric_lopez30 Aug 21, 2011
    Mine is set to front / rear /sub...... if this does not work check hardware.
Alpine INA W900 and pac tr7 installed.
Connect your
Alpine INA-W900 to your iPod via Bluetoot and do the setting from your Alpine dash receiver as per instructed
May 31, 2010 | Universal Remote Control Pac Tr 7...
I have an alpine player in my car and im trying to install imprint but when i try to measure with the mic it gives me an error code -3(cannot detect front left speaker) how can i fix that?
Hello drmer17,
You do not say which Alpine head unit you are trying to use Imprint to adjust. If the receiver has the Ai-NET input and you are using Alpine's KTX-H100 tuning kit, make sure the Imprint crossover switch setting matches up with your speaker/subwoofer configuration. Also, I'd check the cables and remove and reseat them. Try switching the left/right channels and measure again. If the problem then switches to the right front speaker, you probably have a defective Imprint.
Hope this helps.
Jun 12, 2009 | Alpine MRD-M501 Car Audio Amplifier
PXA-H700 optimum set up...
The way the EQ is hooked up is correct.
You set the factory radio to a set level, then use the volume on the EQ for everyday adjustments.
I believe your problem lies in the amplification.
Your BOSE amplifier was made to run a 4 channel 8ohm stero load.
Low powered - high in sound quality.
You have swapped the factory 8 ohm speakers (15W) for 4 ohm power hungry ones.
Now the amplifier is working harder to produce the same output.
You would be best served eliminating the factory amplifier and getting 1 good 4 or 5 channel amp to power your speakers.
a 4 channel amplifier could be used stereo (left and right) on channels 1 and 2, (2ohm stereo load)
and bridge channels 3 and 4 for your subwoofer.
For a true surround sound - a 5 channel amplifier could run each speaker individually, and the 5th channel is reserved for the subwoofer.
a small dedicated 75wx4 channel amplifier with built in crossover, and level gain controls - would blow your socks off. It is 200x better than the factory 12Watt amplifier. Your ears will love you for it :D
If you need more help - just let me know.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 23, 2009 | Alpine PXA-H700 Car Video Player
Alpine PDX 1.1000 low power output - sub not loud
system not configurate properly go to a pro and let them do for you you have good equipment just need to put together rite.for wht you have you can get better sound than that,,good luck
Mar 30, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
CDs and Ipod wont play with Alpine CDA-9885
The Alpine has two tigger wires when it turns on. One is an AMP TURN ON wire (blue/white) and a PWR ANT wire (blue) and that wire only comes on when using the radio or an optional HD radio unit ... When it was installed/connected . someone hooked your amp turn on wires for your "full range amps" to the PWR ANT wire. And the sub amp trigger is either hooked correctly to the AMP TURN ON WIRE or somewhere else, it probably shouldn't be... Check it. Amp triggers should all be to the blue/white wire from your alpine. Warning: Alpine trigger wires, are very easy to mess up they supply a very limited amount of power.
Apr 28, 2008 | Alpine CDA-9885 CD Player
Cannot Set the Treble & Bass
I have an Alpine 9887 you have a different eq than just trebel and bass the only way to get you bass an trebel setings are to install the imprint stoftware now if thats the route you go it tunes your radio to what it thinks it should sound like it's for sound quality not for alot of bass been there done that I have the software but you need to take it to a good alpine dealer to have it installed good luck
Jan 05, 2008 | Alpine CDA-9887 CD Player
Alpine IMPRINT Audio Processor - PXAH100 Logo
167 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
