Question about U-Line 75R Refrigerator
Uline 75R refrigerator thermostat stopped working I am reposting Don Willis's EXCELLENT but hard to find tutorial on how to replace a thermostat on a Uline 75R. Since he spelled "refrigerator" incorrectly (Refidgerator), Google cannot find it easily! I followed these instruction and finished in about an hour. Got the thermostat part on eBay (Part Peddler) (2766-S) from eBay for about $30. Don's post follows: The light worked so it was getting power. I used a electrical tester (pencil like device I bought at lowes) to figure out that power was making it to the thermostat (black wire) but not after the switch (blue wire). To change the thermostat. 1) take covers off the front bottom (one flathead 1/4" hex screw) and back panel (about 10 flathead 1/4" hex screws) of fridge. 2) unscrew the old thermostat (2 screws). leave black and blue wires on it so you will know where to put them on the new one. 3) take out glass shelves on inside. Unscrew back panel {note: there are spacers that will fall out} . There are 2 phillips screws {on nuts} that hold the end of the thermometer to back panel. {I removed one and loosened the other to free the "coil" thermostat) reach hand under it and feed the thermometer back through hole and out back of fridge.You will notice a putty like substance that fills in the hole in the back where the thermometer gets fed through. Make sure you keep it to fill in the hole in the back. 4) feed new thermometer end through hole in the back {I found that using a Phillips head screwdriver to guide it through was useful} and install to back panel {using those two Philips screws and nuts). Put the putty back in the hole to insulate around it. 5) feed the electrical end of thermostat through bottom of fridge 6) take the wires off the old one and attach to the new one. 7) attach the thermostat to its mounting location 8) reinstall all the screws in the front and back and you are in business. Had a hard time finding someone to service it. They wanted $200 to come out to the house + parts and labor. The new thermostat cost $33 at All Brand appliance. I am from Mass and picked it up in Brockton. I emaile dU-line and they sent me the new part number. The allBrandappliance site had the old part number (2766-s) I am not an electrician and this was a few hours work.
  • Phil
    Phil Mar 18, 2011
    Ugh, this formatting was totally messed up.
    Trying again
    Don's post follows (with some of my edits):
    wire).
    business.
    picked it up in Brockton. I emailed U-line and they sent me the new part
3 Suggested Answers
  • 286 Answers
SOURCE: small refrigerator stopped working 75r
You have 2 wires. Unplug and put wires together. Plug unit back in and check to see if everything is running. Doesnt matter where the wires go with a 2 wire thermostat
Posted on Oct 13, 2009
SOURCE: Uline 75R refridgerator stopped working
This was soooo easy. I'm a women Engr. and with the schematic and this help took me about a half hour to complete. Thank!
Posted on Sep 19, 2010
Tip
U-Line 75R: Replacing Thermostat when unit will not run
<span>I am reposting <b>Don Willis's</b> EXCELLENT but hard to find tutorial on how to replace a thermostat on a <b>U-line 75R</b> as a HOW-TO Since he spelled "refrigerator" incorrectly (Refidgerator), </span><span>Google cannot find it easily! I followed these instruction and finished in about an hour. </span> <span><br /></span> <span>Got the thermostat part on eBay from a venfor called Part Peddler.</span> <span>The U-Line part number is 2766-S, cost me about $30,shipped.</span> <span><br /></span> <span>Don's post follows, my comments in {} brackets: </span> <span><br /></span> <span>The light worked so it was getting power. </span> <span><br /></span> <span>I used an electrical tester (pencil like device I bought at Lowe's) to figure out that power was making it to the thermostat (black wire) but not after the switch (blue wire). </span> <span><br /></span> <span>To change the thermostat. </span> <span><br /></span> <ol> <li><span>Take covers off the front bottom (one flathead 1/4" hex screw) and back panel (about 10 flathead 1/4" hex screws) of fridge.</span></li> <li><span>Unscrew the old thermostat (2 screws). Leave black and blue wires on it so you will know where to put them on the new one.</span></li> <li><span>Take out glass shelves on inside. Unscrew back panel {note: there are spacers that will fall out} . There are 2 phillips screws {on nuts} that hold the end of the thermometer to back panel. {I removed one and loosened the other to free the "coil" thermostat) reach hand under the back panel and feed the thermometer back through hole and out back of fridge. You will notice a putty like substance that fills in the hole in the back where the thermometer gets fed through. Make sure you keep it to fill in the hole in the back. </span></li> <li><span>Feed new thermometer {coil} end through hole in the back {I found that using a Phillips head screwdriver to guide the coil through was useful} and install to back panel {using those two Philips screws and nuts}. </span></li> <li><span>Put the putty back in the hole from the back to insulate around it. </span></li> <li><span>Feed the electrical end of thermostat through bottom of fridge</span></li> <li><span>Take the wires off the old one and attach to the new one. </span></li> <li><span>Attach the thermostat to its mounting location </span></li> <li><span>Reinstall all the screws in the front and back and you are in business.</span></li></ol><span>Had a hard time finding someone to service it. They wanted $200 to come out to the house + parts and labor. The new thermostat cost $33 at All Brand appliance. I am from Mass and picked it up in Brockton. I emaile dU-line and they sent me the new part number. The allBrandappliance site had the old part number (2766-s) I am notan electrician and this was a few hours work.</span>
on Apr 10, 2011 | U-Line 75R Refrigerator
My uline keeps running and soda in cans freeze. Thermostat setting is at lowest but I also tried midway. Model ULN-CO75FWH-00
your thermostat is bloked or didn't see the reeal temperature, it must be replaced whit similar new one.
Feb 21, 2010 | U-Line Uline Origins Series...
U-line 75R was not cold. Shorting the two wires at the thermostat, the motor runs and starts to get cold. Replaced the thermostat, but it didn't run at all. Please help. Thanks
There is a slight possibility that the unit's defrost timer just happen to be in defrost when you replaced the temperature control. Try advancing the defrost timer (or just let it sit for about 1/2 an hour and see if it comes back on). If you have more questions, let me know. Hope this helps!
Dec 11, 2009 | U-Line 75R Refrigerator
Small refrigerator stopped working 75r
Oct 09, 2009 | U-Line Uline Origins Series...
Please send a repair man
If you need a tech please visit U-lines website www.u-line.com and under customer service you will see service locator. That should give you a list of companies.
Feb 26, 2009 | U-Line 75R Refrigerator
My uline drawer fridge quit working. Who should I call to fix it?
I would call Uline directly and allow them to recommend someone in your area that does warranty work for Uline. In this fashion, you are assured professional results and OEM parts....
Good Luck, Eric Campion
Sounds like you did everything right
Jan 24, 2009 | U-Line 75R Refrigerator
Lighns on - nothing else
well i have a 75r also with the same symptoms but there's no freezer in this model so I don't know how it could be the defrost timer.
Dec 03, 2007 | U-Line 75R Refrigerator
U-Line 75R Refrigerator Logo
452 people viewed this question
Top U-Line Refrigerators Experts
billconfused
Ilia Bichin
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
