Question about Garden
I have an old (25-30 years) JC Penney tiller. The rubber has come off the drive pulley. It should be sort of like the rubber drive on the Snapper mower. There is a pulley used for connecting to the tines on the outside of this drive pulley. I can't get either off using a puller. I wondered if there was some way that the fine threaded bolt used to go though the bearing was the way to get it off--by using a longer fine threaded bolt that would push against theshaft on the insider and push the pully off by tigthening that bolt. When I try to use a puller, it just bends the pulley on the outside in the three places where the puller puts pressure.
  • wes11 Mar 21, 2011
    I agree that this is the best way to get the thing off. I am doing some checking as to the possibility of ever finding the part needed for this old tiller, so I am going to leave it sitting until I can find a part.
    Thanks for your help.
    Weston Ware
  • 43,501 Answers
The way to get old stuff like that off is this....
Use a torch... oxy-actelelyene if possible but a small map gas torch will work, just takes longer....
heat the hub of the pulley but not the shaft till it glows red if possible... the hotter the better...of course not melting it..
Then walk away from the thing and let it cool down... then if possible turn it with the shaft up and soak it down with PB Blaster or another good quality penetrating spray....then let it soak in for 24 hours...
Then take a large pin or bar and a big hammer and rap the hub towards the outside of the shaft,,,if you have already swelled the shaft, you may have to file it down so the pulley can come off...a few raps with the hammer and the pulley will start to move...then lubricate ahead of it as you hammer it off the shaft....
You could also apply some pressure with the puller before you rap on the backside... any and all pressure will help...
I have used this method to remove pulleys from fans used in pig barns many times and is the best way I have found to remove them...patience is the key...
heatman101
Posted on Mar 18, 2011
Need manual for JC Penny sewing machine model 6955
Try Googling (JC Penney)(6955)(manual) without parens. Note spelling of Penney.
Jul 22, 2017 | Sewing Machines
I want to pay my JC penney bill on line.
You need to contact JC Penney directly or work through your bank.
Jan 19, 2017 | Sewing Machines
JC Penney ultra sewing machine 5102 free arm
go google and type in---operators manual for jc penney eltra sewing machine model no (not given) and if there is one it will appear as a pdf version down load on a site
Nov 29, 2015 | Sewing Machines
I have a jc penney serger that I bought probably 20 years ago. It has been at least 10 yrs since I have used it, and now I can't find the power cord for it, and it has lost one of the colored knob
try these sites--some of these sites you may have to email them about the parts
ebay
sewingpartsonline.com
sew4less.com
sewvacdoctor.com
a1sewingmachines.com
Apr 30, 2012 | Sewing Machines
Need to replace filter basket drip spout rubber ring
After searching for the replacement basket on web took whole coffee maker back to jcp and they replaced the 12cup coffee maker with a new item.
Jul 28, 2009 | Coffee Makers & Espresso Machines
Snapper comet rubber drive
Get a new drive wheel.
Put mower in neutral.
Stand mower on rear supports.
Remove the four bolts holding the old wheel.
install new wheel.
Jun 15, 2009 | Garden
Need assembly instructions for JC Penney ''melanie'' crib
I have the assembly instructions for this crib. Maybe I can scan it and e-mail it, or just copy and mail it to you. Send me an e-mail at
s i n g h v i n @ y a h o o . c o m
Feb 07, 2009 | Baby Gear
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
