Question about Riccar R751
What size bobbin does a R751 use - Riccar R751
What size bobbin for White 915?
On sewing machines with the removable metal bobbin case the bobbin size will be a class 15, very common and inexpensive.
Dec 10, 2015 | White Sewing 915
Need Bobbin size for Janome Jemsilver model 662
There are three sizes (classes) of bobbin that most machines use. If you have the old bobbin and can measure it this link will help you determine which class you need.
What Size Bobbin
Jul 19, 2014 | Janome Sewing Machines
Bobbin tension to loose and flips
Hai, I think you put the big size bobbin. So only jumping the bobbin. Please try to put the correct size bobbin.
Apr 03, 2014 | Brother PE770 Computerized Sewing Machine
Settings are not right
Since you have provided almost no information, the best I can offer is the instruction manual for your model. I hope it helps you.
http://www.riccar.com/ftp/whitepapers/R751-Instruction-Manual.pdf
Aug 18, 2012 | Riccar R751
What type of bobbin should I use in my Memorycraft 4000.. Plastic or metal..I have been using metal, is this ok?
You should be using plastic bobbins for the MC4000, see: http://content.janome.com/index.cfm/Machines/Accessories/All/Bobbin_-_Plastic . Usually the machine comes with a handful of the correct size and type bobbins. Using the wrong bobbin could result in the needle hitting the bobbin and damage may occur. (Broken needles are the most likely possibility; damage to the bobbin case or timing could occur and would require the machine be serviced.)
When you buy more bobbins, make sure that they are labeled for Janome or a machine that takes the same size bobbin. See this site for a list of machines that also take this size bobbin: http://www.sewingmachinesplus.com/102261103%20-20pk.php
I hope this helps.
Mar 01, 2011 | Janome Memory Craft 4000 Sewing Machine
I purchased a new machine that did not have the Riccar R751 manual included because it was a display model. That business no longer carries the product. I need to find and instruction manual before I can...
in the search engine put riccar manuals
the search should bring up riccar product manuals-click on it
go to sewing machine owners manuals
your model number is ( 9 from the bottom)
Nov 27, 2010 | Riccar R751
Bobbin problems
Are you using a size "A" (Class 15) bobbin? If you are using pre-wounds and they are not this size... they will jump around alot. The size of an "L" is very similar, but they are not as tall (height off the table when laying flat on the round side... like when sitting in the bobbin case.) There are tricks to using the thinner bobbins... See if you have a "taller" size "A"/Class 15 and if that corrects the trouble. tjsews2008@gmail.com
Feb 04, 2009 | Janome Memory Craft 10000
Bobbins for viking emerald 118
The Emerald 118 takes a bobbin that is very close in size to a Singer Class 15 bobbin, but it is slightly different.
Don't buy green bobbins for a standard Husqvarna machine. They will not work.
Any Husqvarna dealer can get the Emerald bobbins for you.
Oct 03, 2008 | Husqvarna Viking 1
Riccar R751 Logo
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Joseph Mueller
Joseph Mueller
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
