Question about Kenmore Side by Side Refrigerator
2002 side by side. Circuit board relaced. Freezer and fridge set on "4". Freezer at steady 10 degrees and fridge at 40 degrees. Fan in the freezer seems to run 24/7. Repairman says that's just the way it is, but it never did that previously. Filled freezer with stuff for a load as instructed. Nothing different, runs forever. Its in the garage in a mild climate and worked perfectly for about 10 months. Very low usage. Anything I can do?
  • Kenmore Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 18, 2011
Kenmore 596.69142992 bottom freezer temp fluctuating from 10 to 40 degrees. Refrigerator maintains steady 40 degrees. No ice on coils.
The freezer temps fluctuate that much, I am thinking your cold control is going bad... Kenmore Refrigerator Temperature Control Thermostat W10752646
You can clean the fridge with warm soapy water and/or a hand steamer
Jun 29, 2016 | Kenmore Refrigerators
Kenmore elite refrigerator freezer and fridge too cold
947f1e38-158a-4e1c-9e57-08343605a6a0.jpgKenmore uses a model number like this example=> 321.1234567 and can be found around the fresh food section door frame. I need that model number to see what parts may be causing the refrigerator to be too cold. Let me know and I will do my best to help solve this, Thanks Sea Breeze
May 03, 2013 | Refrigerators
I had ge refrigerator and the fridge is not cooling well
For starters a year and model number would be helpful. Do you have turn dials to contol temp of freezer and fridge or electonic pushbuttons? The fridges with manual rotating dials use a "dampner" between the freezer and fridge section. In short the freezer evap fan blows air in the freezer but also has a passage from the freezer to the fridge section which aloows a controled amount of air from the feezer section to cool the fridge section. IThis passage may be obstructed by ice build up or some other blockage. Units prior to 2002 are not controled by circuit boards and the ones after 2002 are. For more specific help give me the GE fridge model please.
Sep 24, 2012 | GE Refrigerators
Compressor overheated and shut down.
Pleas put setting in the middle and give it 24 hrs and check temps
freezer would be good at 0 to 10 f
I thing you have the damper door closed.
May 24, 2010 | Whirlpool GS6NBEXR Side by Side...
Temp in refridgerator is 40 degrees on bottom shelf with temp gage turned to coldest setting. Is this right?
the normal temperature for a refrigerator is 35-40 degrees F, so 40 at full cold setting is not correct.
If this is a side-by-side or top-freezer, make sure that the air vents between freezer and fridge are not blocked by food items or ice.
Make sure defroster operation is working normally as ice will block airflow.
Also, there is a circulating fan in most models that moves cold air from freezer to fridge. make sure that's working.
Oct 21, 2009 | Refrigerators
Freezer won't go below 10 and fridge goes between 40 and 60 degrees
Ensure the condenser is not clogged with dust or other debris.
Ensure the condenser fan (usually found in back) is turning when the fridge is running.
May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Freezer cold not frozen, fridge cool but not cold enough.
HI, simply replacing the thermostat and air diffuser assembly will fix this cold control issue you are experiencing.
May 24, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Freezer freezing great, Fridge running warm
Hello Murr9,
The number 1 reason a freezer "SEEMS" to be working... but the refrigerator isn't cutting it... is PROPER AIR FLOW...
look through the vents in the back of the freezer section...
If you see thick frost or ice... you have found your trouble
If the evaporator fan (behind the freezer wall is operating at ANY speed your REFRIGERATOR section would be adequate...
You had a repair person out... but
while that ought to mean something to me... I would rather
you do some simple checks...
- Look through those vents
- You need to check the defrost pan... DRY means you have
troubles... put a piece of fresh typing paper inside the pan...
fold it over the edge... if it is still dry the next day...
Your defrost circuit is broken...
It only has three components:
- heater element
- defrost thermostat (opens at room temperature)
- Printed Circuit Board
Your refrigerator DOES NOT have a defrost timer... but rather a PC Board...
($152, see below... plus how to video)...
Most expensive part but easiest to replace...
Important - Important - Important
TAKE PICTRES OF ALL THE WIRE
connections BEFORE you start.
http://www.appliancepartspros.com/whirlpool-timer-defrost-4388932-ap3109394.html
Get on AMAZON and buy yourself a couple of the TAYLOR REFRIGERATOR thermometers...
zero Fahrenheit is fine for the FREEZER...
REFRIG should be just above 32 degrees
Fahrenheit...
Amazon com Taylor Freezr Refrig Thermometer 1 pack of 3 items Home Kitchen
partsselect
PartSelect Appliance Parts and Repair Help
repair clinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Mar 04, 2017 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frige and freezer are not cooling!!! Help
chances are the fan motor has quit have a tech replace it if this is not the problem it could be a sealed system issue or a defrost problem
Dec 14, 2008 | Maytag MFD2560HES Bottom Freezer French...
5 year old Maytag Wide by Side Refrigerator side not cooling
Same issue with my 6 yr old Maytag side-by-side model #MSD2756GEW. Turned out it was caused by a faulty circuit board. This circuit board is located in the upper right fridge section. Apparently these boards are sensitive to power surges (which we have here in central Texas from time to time.) When the circuit board is fried, it makes a noise like a fan blade malfunctioning and it stops the auto defrost feature in the freezer from working. So the freezer ices up at the back, and the ice prevents the cold air from reaching the fridge section.
Our circuit board (which we thought was a fan) made ominous noises for a few months. (The noise would last only a minute or so and stop shortly after we opened a door). Eventually we noticed that the fridge wasn't as cold and the freezer had snow in it. Finally the board stopped making noise and about a week or so afterward we noticed that the milk had spoiled and the fridge wasn't very cold. The food in the freezer side pretty solidly frozen, thankfully.
In addition to replacing the circuit board, the fridge had to be de-iced or it would not work properly. I put it all frozen into a large camping cooler where it stayed for several hours. I opened the freezer doors and put table fan and pointed a hobby light which gets quite hot, at the back of the freezer. Within 3 hours, the ice had melted significantly so I could see through the grate at the back of the freezer. This really great technician named Tracy, made a special trip to the parts store to get the circuit board and came back within a couple hours, bringing with him a steamer. He removed the back panel inside the freezer section (the coils are behind there) and used the steamer to melt the rest of the ice before he left.
Tracey, who works for a local appliance repair company, told me that about 4 years ago, Maytag started making their fridges with built-in surge protection, so the circuit boards apparently don't get fried on the newer models as they do on my 6 yr old model. He recommended that we put plug the fridge into a heavy-duty surge protector - which we are definitely going to do.
TR
Feb 13, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Kenmore Side by Side Refrigerator Logo
51 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
