My fan works but compresor wont turn on unit is 8 months
    Sergeant:
  • 259 Answers
When you turn the air conditioner on make sure you are getting voltage to the compressor itself by using a voltmeter 110 volts. If you are you probably have a faulty compressor.
Posted on Mar 18, 2011
Stopped working. clicking sound when it wants to start up. Is it the compressor or the relay switch model 8 yrs old old.
You.have to check if the compresor is working or damage. Try starting direct the compresor, Generali should be the electric part outside the compresor just change at the electric parts and should work. If you send a picture of the position on the connectors I will help you to try the compressor
May 29, 2015 | LG LFX25960ST Stainless Steel French Door...
Pelonis model ylrso.7-5v the water does not get cold
cooling fan is not turning. it is a 12 volt fan and can only be bought from the manufacturer. the unit has been discontinued and parts are not available. if you could find the cooling fan, you would have to disassemble the entire unit to replace it and it takes about 3 hours. but it will work again for maybe 6-10 months before it goes out again. the average fan life is 8 months.
Sep 18, 2010 | Kitchen Appliances - Others
Compresor wont start and when it does it cycles on and off
Does the condenser fan come on? I am assuming the evaporator fan (inside) is blowing? The way these units are wired is that the power goes the the inside unit and the controller inside sends power to the compressor and condenser fan. But if the controller detects that the condenser fan is not turning (via no ground return) it will not send power to the compressor. This to protect the compressor. Did you notice it trip a breaker? When it is on, do you have 240 on the unit outside but not 120 to ground from each leg?
Jun 15, 2010 | Sanyo CMH2472 Air Conditioner
Fans on both indoor and outdoor units are running but compressor wont restart, even after turning power on and turning back on. also, if compressor resets and runs, it'll run for a few minutes then trips...
the compresor have delay protection and this wil not alow compresor to run only after few minits (turn off the unit and disconect from the main power suply, wait 30 minits and after that turnit on) or the refrigerant gas in the plant missing. in this case you must call specializated personel to find the leack and fixit, after that they wil refil whit refrigerant gas (r404, r 134, or what your unit have)
Feb 14, 2010 | Heating & Cooling
Fridge and freezer stopped working lioghts still work
check if the compresor still working first then the fan next to the compresor ...then the fan in the freezer , then see if there is frosting inside the freezer evaporator, but the main part is the compressor starter unit next to it... that might be the problem :)
Dec 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ruud 10 compressor not working
First make sure there's power to the unit outside , if yes set the theermostat on cold ,auto and to the lowest degrees ,then look the outside unit contactor, it should be pulled in (sometimes it takes to 5 minutes beacause a time delay) , if not the problem is in the thermostat , but if yes and there's power on the other side of the contactor ,either the compresor running capacitor is bad or the compresor itself went bad .Try replacing the capacitor first (the cheaper option) and adding a startting booster in paralel with the capacitor ,if still the compresor doesn't start you nedd to replaced it.All this counting that the fan in the outside unit works ,if doesn't replaced it.
Aug 05, 2009 | Ruud Matching Split Air Conditioner
My dur therm air conditioner fan turns on but compresor does not
it could be the (LP) low pressure switch which would shut the unit down
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
The compresor wont start and it's getting very hot!
Check the capacitor. It is in the outaside unit. Siver with three terminals on top. If it is swollen it is bad. Check for burnt wires. You can repair these yourself. Compressor maybe stuck. If it is an old unit you will have to replace it. Rusty
Jun 08, 2009 | Heating & Cooling
Condensor fan runs but the compressor wont start
Either you have abad comoresor or abad compresor relay ,i will try to replace the relay first(if you don't have away to check the compresor) wich is cheaper (about $20 for the part)If doesn't work the compresor is burned or stuck.
Apr 20, 2009 | Refrigerators
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
