Question about Peerless Industries Peerless& Single Handle Tub & Shower Faucet
My showerhead leaks when I fill up the bath tub, do you have any suggestions as what will correct this?
  • 7,482 Answers
Hi nanbooboo...
Sorry
Your problem shower control valve is ok, but the shower pull that turns on the shower is non-repairable.
Replace your shower controller with a new one if you want to solve this leakage problem.
Please take time to rate me
Posted on Sep 14, 2011
Why does my geberit bath waste plug leak water?
It's adjustable. Remove the drain lever from the side of the tub. Now you can withdraw the whole drain assembly. Clean it well, then reinsert it to see if that fixed the problem. If not, try adjusting it longer.
Dec 24, 2013 | Geberit Bath Waste and Overflow Tub Drain...
I have a delta 1400 series bath/shower and for the life of me, I can't figure out how to get the shower to work. I turn the knob to the left to adjust the temperature. However, I don't have an...
I had the same problem. My building manager showed me that you have to yank the circular portion at the end the of spout where the water comes out downward and the water will be diverted to the showerhead.
Aug 29, 2011 | Delta T13420 Chrome Classic Single Handle...
Installed new tub/shower valve, water comes out of showerhead when water is turned on even though spout is open
the diverter valve is probably bad. put a new one in. the valve cuts off the water to shower, while running bath water.
Nov 23, 2010 | Delta Faucet Plumbing
On my showerhead the thing that you pull up to take a shower and you have pull it back down to take a bath it is stuck and won't come up at all
Look under-neith to see if there is a allen screw,if not you can just replace this ,tub spout,remove the chaulk and unscrew
Apr 16, 2010 | Home
When I run water through this tub spout (diverter in down position) I still have water leaking from the showerhead. I have seen water from a tub spout when the shower is on, but not the other way around....
After you turn water off in about 30 secs pull the diverter up and leave for a few minutes This should allow the water left in shower piipe to drain out the spigot
Feb 17, 2010 | Speakman S-1555 Versatile Bath...
Kohler KT12007 Showerhead
The device which directs the water up or down is called the diverter. Your diverter is not fully up or fully down. Rather forcefully push and pull the diverter a few times and your problem may be solved. good luck.
Jan 24, 2009 | Kohler K-T12007-4s-BV Brushed Bronze...
Shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Jan 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Grohe Atrio Bath Shower Mixer Flow Problem
Check for a flow restrictor in the showerhead, also a clogged intake screen or filter in the showerhead. or hose or pipe...
Nov 25, 2008 | Plumbing
Peerless Industries Peerless& Single Handle Tub & Shower Faucet  Logo
150 people viewed this question
Top Peerless Industries Home Experts
Joe Lamb
Joe Lamb
john h
Steve Wood Plumbing...
Level 1 Expert
Are you a Peerless Industries Home Expert? Answer questions, earn points and help others
