Question about Frigidaire Refrigerators
Flsc238055 side by side water on floor on freezer side wipe it up 2 or 3 times daily how do I fix?
  • 604 Answers
There is typically a water evaporator catch pan under the fridge. if it is full it will overflow, usually the water evaporates into the air, but for some reason yours is full, pull it out and empty it
Posted on Mar 18, 2011
Water is leaking on floor from left hand front corner (freezer side) I noticed it does it on the right hand corner at times also
On my fridge like this one, on the freezer side, down at the bottom (below the doors, where the vents are, there's a turn knob there. If you turn it counter clockwise, it'll unscrew filter. It's white and about 2" round and 10" long. It's the filter that goes to the water supply and ice maker. Mine had stopped up, I just pulled it out, went to home depot and got another just like it and re-plugged it in.. No more leaks for me!
Dec 07, 2012 | Frigidaire FRS26R4A Side by Side...
I have a Maytag Plus side by side Refrigerator MSD2756GEQ. Every couple of days there is a puddle of water on the floor on the freezer side door. What can I do to fix this problem?
ck the bottom of freezer and if ice is there . the drain is pluged and water is running out the door on floor . every 8 hr of compressor run time the unit will defrost and water on froor .
Aug 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Viking side-by-side -- Condensation
It really sounds like the defrost timer is staying on all the time.Have the timer checked.This must be a on going problem with this brand,I am getting a lot of them.So many things could be the problem,but the defrost timer is what really stands out,the defrost timer,does just that,it defrost only a certain short period of time,or it is supposed to.That is how you get frost free.If I can help any more please ask,but have the defrost imer checked ,or replaced.
Jul 24, 2009 | Viking 42 in Built In Professional...
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water water everywhere
Hi: I don't think your defrost water is even getting to the drip pan. It just flows where it can get out with the least resistance. You are on the right track though. Your defrost drain is probably plugged, with mold (as it's not refrigerated) or a tid bit from the freezer. You should not have to remove any parts but the bottom bin in the freezer. Look behind it you will see a rectangular shallow funnel at the very bottom of the freezer. There is a hole in the center of it. Snake it with a pipe cleaner or just pour a strong solution of water and clorox in it (about 1/2 cup) or both. That will give the defrost water back its normal path to the tray instead of leaking of your floor. I hope this helps, Jeff
Jun 02, 2009 | Whirlpool ED5VHGXM Side by Side...
So water leaks out onto floor-Jennair side by side
THERE IS A DRAIN LINE HEATER ON MOST UNITS now days, if yours is an older one what you need to do is make sure that it's level, and that the drain line is cleared so that the water has a place to go when it thaws during the defrost cycle.
Jan 27, 2009 | Refrigerators
GE Frig mod#TFX26KPDA
More likely, the defrost system has failed.
There are three components: Defrost timer, a defrost heater, and a defrost bi-metal.
The timer can be located either in the food compartment, on the rear of the unit, or behind the kickplate. The heater and bi-metal are located behind the freezer rear wall (or freezer floor, depending on design). It's easiest to unplug the fridge overnight, with the freezer door open, to melt all the ice that has developed. PRIOR to doing all this, please ensure that there IS ice forming on the wall of floor of the freezer! Let me know. I hope this helps!
Jul 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is building up in the bottom of my side by side freezer and freezing.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
May 07, 2008 | Freezers
Refrigerators Logo
146 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
