Question about HP OfficeJet J4580 All-In-One Laser Printer
The scanner is saying that i do not have the WIA driver for my Hp officejet j4580 printer and i'm not sure where to get this driver at, i've tried downloading it from HP directly, but it's still not working.
  • 35 Answers
SOURCE: printer, fax ,scanner,copier hp officejet 4255
hi....
pls click this link below. this is a link where you can get the software to download and select your operating system first.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=351125&lc=en&cc=us&dlc=en&lang=en&cc=us
Posted on Aug 01, 2008
micromaster
  • 3614 Answers
SOURCE: HP Officejet J4580 paper jam
Paper can jam inside the printer for a number of reasons.
  • Open the cover to the printer and look inside to see if there are any pieces of paper or debris that may be blocking the print path.
  • Be sure to unplug the printer before touching anything internal to avoid electric shock. If there is something blocking the print path, remove it, close the printer, and try printing again.
  • You can also check inside the printer to see if any components have come loose.
Posted on May 28, 2009
  • 54 Answers
SOURCE: hp j4580 scanner not working properly need help.
If you technical. Open glass top . Check the slides, clean it with clean cloth an reconect. Will be fine.
Posted on Jul 11, 2009
adnanbhatti
  • 1188 Answers
SOURCE: how to use scanner on HP officejet J4580 all in one?
Click here to visit the HP support page for this model. You will find an online manual with complete instructions for download free of charge.
Posted on Nov 27, 2009
  • 5 Answers
SOURCE: When trying to scan to my HP J4580 Officejet J4580
this means the printer has not been configured to the computer,,
1st check the connection of the printer and the computer,,
then check if all the software like the basic print and scan drivers, hp solution center and the hp imaging device function had been installed or not,,
if all the above things had been checked then
open hp solution center,,
click settings,,
go to scan settings,,
select scan to set up.....,,
you will get two columns there,,
the left will be for the solution center and the right one will be for the printer,,
you will see two arrows in between the columns,,
populate the entries on the printer that is on the right column using the arrowes,,
once done click update device,,
then close the olution center and restart the printer,,
then check it will work................
Posted on Feb 16, 2010
Wia hp officejet 6110xi
uninstall and reinstall driver for your printer scanner and try
May 20, 2012 | HP Office Equipment & Supplies
I keep trying to scan a document on my hp officejet j4580 all i n one that i just installed and itkeeps saying refer to device documents, no scan option.. what should i do i cant find ne thing about it in...
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 29, 2010 | HP OfficeJet J4580 All-In-One Laser...
I LOST MY Hp OFFICEJET J4580 ALL IN ONE PRINTER DRIVER CD. SO THAT I CAN NOT INSTALL MY Hp OFFICEJET J4580 PRINTER IN MY ANOTHER COMPUTER. SO I WANT TO DOWNLOAD THE DRIVER.
You can download the drivers for any of your HP products from HP's support site (www.support.hp.com)
For your HP J4580 AIO officejet printer you can download the driver from the following link by selecting your Operating system.
Driver for HP J4580 AIO officejet
Thank you for choosing Fixya
May 27, 2010 | HP OfficeJet J4580 All-In-One Laser...
I just downloaded and installed a driver for HP Officejet J4580. When I try to scan it says there are not scan options. What do I need to do?
If you are not getting scan options, make sure you have installed the scanning software along with your drivers.
Check in Control Panel / Scanners and Cameras and try to scan from there.
Thanks,
Pat
May 22, 2010 | HP OfficeJet J4580 All-In-One Laser...
How to use scanner on HP officejet J4580 all in one?
Nov 27, 2009 | HP OfficeJet J4580 All-In-One Laser...
It says "No Scan Options" when I try to scan on my HP Officejet J4580 All in One.
Please open the scanner and camera wizard and check if scanner is showing there if it is showing then”
Please click on start/all programs/accessories and click on paint”.
When it open click on file and then click on “scanner and camera wizard”, if printer detected then it will show the option after that you will get the option for scan, please click on the scan tab without do anything and once when scan get complete save the file on your computer. This is the easiest way to scan the document.
If it is not showing then insert the printer driver disk select the option add a device and add the scanner or install the scanner driver.
Oct 26, 2009 | HP OfficeJet J4580 All-In-One Laser...
My HP officejet J4580 All in one scanner is not working, when i go to scan it tells the computer does not reconise a scanner, i have lost the disc for it, where do i go for the down load.
Here is the main support page for your printer:
HP J4580 Support
For documentation click on Manuals. For the driver and other software click on Software & Driver Downloads. Then click on your operating system for available software.
Thanks for using Fixya.
Oct 07, 2009 | HP OfficeJet J4580 All-In-One Laser...
Comp freezes and "no scan options" message
try downloading the 2 firmware patches fro hp. go to www.hp.com select support, drivers and downloads, enter your printer model, and select your os. Halfway down the next page is the firmware section. Download and install.
Aug 08, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP OfficeJet J4580 All-In-One Laser Printer Logo
488 people viewed this question
Seeker5211
Seeker5211
