Question about Samsung HLR5667W 56" Rear Projection HDTV
Keeps cutting off, also humming noise - Samsung HLR5667W 56" Rear Projection HDTV
  • Samsung Master
  • 8,617 Answers
Most likley cause is the color wheel is broken.
Posted on Mar 18, 2011
Humming in my radio
Hi, Mike for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
installed sound system buzzing noise from speakers
Stereo and hum noise Harley Davidson Forums
https://www.installdr.com/TechDocs/999501.pdf
How to fix buzzing engine whine in your car audio system
Apr 27, 2016 | Motorcycles
Light Vibration and Humming sound in cabin
no posts on this old post. but no year, so .... as an example
to others posting, NO year?, NO answers.
but... here you go.
NOISE MOVING, ONLY !: (dangerous tests)
NO noise , in neutral, guning throttle like mad man.
or doing same in drive, all brakes set, wheels chocked,
DO the FSM A/T trannny Stall test. 5seconds max !, at 0MPH this puts full load on most the parts, MAKE NOISE NOW?
moving.....
cutting the engine , depends? in neutral? or coasting in gear.
risk 2, accidentally hitting park doing the test.
risk1:
selecting neutral and cutting the key (danger if the steering locks ) do so only off road, and no people about, no turns., no cliffs, no trees, no rocks. (flat desert or parking lot, at early hours..etc.)
Safety first.....
"and it goes off."<<< meaning the noise stops? key off?
btw:
the wheel bearing are under full load, now.
in turns the wheel bearing are under more load (huge in fact)
and the CVs run all the time.
but, if goes off means. no sound , it can be. (sure not wheel bearings)
1: exhaust parts, rattling. (running)
2: engine noise. (lots of possible) , but see test above.
3: A/T trans noise (its A/T right?) bad front, A/T pump? or TC?
or 150 other vastly complex A/T parts. bad.
when coasting , the CV do turn all the rear planetary gears ( and axle gears)
so they are not bad, as the quiet sound ending , proves.
keep in mind most parts, under torque love to make noise.
so cutting the engine, cuts most that torque, and hides the bad parts, with silence.
i use and remote electronic ear to find moving noise.
electronic stethoscope.
it has small microphones that clamp to suspected parts.
this removes most the danger in testing.
good luck finding it, if it still makes noise.
Aug 28, 2013 | Honda Civic Cars & Trucks
Car makes humming noise gets loud and cuts off
SOUND LIKE FUEL PUMP.CHECK PUMP PRESSURE BUT MOST OF THE TIME WHEN FUEL PUMP GOING OUT YOUR HEAR HUMMING OR LITTLE WHINING NOISE.FUEL PUMP MOTOR BEARING WORN OUT.
Apr 04, 2010 | 1999 Oldsmobile Alero
Carrier Compressor Issues?
When you shut it off and back on it slugged the compressor if you turn it off and back on before the pressures equalize between the high and low sides it will slug the compressor and it will not run should let sit for five minutes or so before restarting. The humming is either the compressor making noise usually common for the compressor to make some noise or the fan motor bearings are getting bad on the outside unit. If the unit works normal probably not much you can do till it breaks if it is the compressor it is more economical to replace the whole unit if it is just the fan motor it is worth changing. You could take an amp draw on the fan motor and the compressor to see if the are within the limits on the name plate of the outside unit.
Jan 25, 2010 | Heating & Cooling
Humming noise comming from around the ice maker
If you had your water cut off to the ice maker and didn't have the ice maker turned off, it was your ice maker. You turn it off by lifting the wire arm and leaving it in the up position.
Please rate solution
Sep 10, 2009 | Frigidaire FRS26R4A Side by Side...
The noise is a hum or buzz. We've narrowed it
By chance have you tried making sure the laptop is not too close to the speakers? Sometime you will get feedback when the source is to close to high powered speakers. Also, check your jack cord and make sure no splits/cuts are visiable and the plugs are fully inserted.
Good Luck and keep making great music. Aloha.
C2Solutions
Sep 02, 2009 | Dell Inspiron 6000 Notebook
Humming noise under the hood
It could be the ABS. MY HONDA DOES THE SAME THING.
I took it to PepBoys yesterday and they could not connect to the
computer interface.They said I need to take it to a honda dealer
so they can connect and determine what is wrong with the
Automatic breaking system. The noise is the ABS motor
turning on and off.
Apr 29, 2009 | 1997 Honda Accord
Humming noise when i press the start putton
When I push the start button it would hum if I hold the button to long and then it would cut off.
Jan 27, 2009 | Whirlpool LER5636P Electric Dryer
Samsung HLR5667W 56" Rear Projection HDTV Logo
233 people viewed this question
Jerry Greenberg
Jerry Greenberg
