Question about Refrigerators
The light is on when you open the door ,but fridge is not working
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 18, 2011
Light not working in fridge. Replaced bulb but still not working?
Probably the door switch. With the fridge unplugged, remove the door switch (pry out with a screwdriver), short the two wires (leave the door open). Plug in the fridge and if the light is on, it's the switch.
Aug 02, 2017 | Refrigerators
New integrated baumatic fridge freezer installed yesterday but the door sensor alarm keeping going off..door is def shut. As baumatic gone into administration has anyone got any ideas plse?
It's telling you it has a fault, you have to find out who is doing the warranty work for Baumatic now, by law they have to honor the warranty.
Nov 30, 2013 | Baumatic Refrigerators
Fridge light won't turn off..does that mean the fridge has stopped working or only the light needs to be fixed? Can tell it's not cooling as much as it used to.
The light is usually a seperate circuit to the fridge compressor and it staying on is more likely to be a faulty switch than the fridge not working. Open the door and look around the perifery of the door opening, there should be a spring loaded plastic part that pushes in when the door is shut and springs out as you open the door. Try manually pushing it in and see if the light goes off, if it doesn't then the switch behind it may have become dilogded in it's housing or broken. Turn off the power to the fridge, unscrew the housing, re-position the switch or replace it, re-fit the housingturn on the power and test.
Jul 02, 2013 | Frigidaire Refrigerators
Fridge not working since i replaced door
Hi I would be checking the switch that starts the light when door opens. good luck
May 18, 2010 | Candy CPCA220K Bottom Freezer Refrigerator
Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Apr 19, 2010 | Refrigerators
Refrigerator just delivered lights were on, after filling fridge with food the lights dont come on when door is opened im talking the big lights on top of fridge
A lot of refrigerators now use the control board to time how long the lights are on. If the door is open for an extended period, the control will turn the lights off to pervent them from overheating. I suspect you have discovered by now that the lights are working again.
Nov 09, 2009 | Samsung RF265AA Bottom Freezer French Door...
Freezer has frost building and the refridgerator is too warm.
make sure the evaporator fan is working, open door and push switch in if fan works make sure opening from freezer to fridge is not blocked. if door was removed make sure light in fridge is shuting off if temp in fridge is in the 50 degree range your light switch is not being deactivated check spacers between door and hinge . sometimes when door is removed a spacer will fall on floor and light switch is not hitting door
Jan 26, 2009 | KitchenAid KTRC22EL Top Freezer...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
